Path of a projectile from a cannon
The discussion focuses on calculating the projectile path of a cannon fired at different angles, specifically 0 degrees and 12 degrees. Key calculations include initial velocities (Vix = 4.02 m/s, Viy = 0.85 m/s, Vo = 4.11 m/s) and the time of flight (t = 0.5163 seconds) under the influence of gravity (ay = -9.8 m/s²). The projectile's path is analyzed through three rings, with calculated heights at each ring and the target. The discussion also addresses the need for clarity on the distance of the rings from the cannon and the impact of different firing angles on the projectile's trajectory.
  • Understanding of projectile motion equations
  • Familiarity with kinematic equations
  • Basic knowledge of trigonometry for angle calculations
  • Experience with quadratic equations for solving time of flight
  • Study the derivation of projectile motion equations
  • Learn how to apply the quadratic formula in physics problems
  • Explore the effects of air resistance on projectile motion
  • Investigate the relationship between launch angle and range in projectile motion
Students in physics courses, educators teaching projectile motion, and anyone interested in the practical applications of kinematics in real-world scenarios.
kLPantera
Part 1
We fired a cannon 0 degrees to the horizontal line and had to calculate Vo. We then measured Delta x and Delta Y.
Part 2
We were then given a degree in which to fire the cannon at, which was 12 degrees. We then had to calculate the projectile's path through 3 rings and then hit a target.
We we used were what we got from part 2 (Vo, Delta x, and Delta y).
Data:
Delta y = -0.87m (from a counter top to the ground)
Calculated Data:
Vix = 4.02 m/s
Viy = 0.85 m/s
Vo = 4.11 m/s
Known Data:
ax = 0 (we are operating under the scenario that there is no air resistance)
ay = -9.8 m/s2
Delta y = Viyt + (1/2)gt2
Delta x = Vixt + (1/2)at2
Vfy = Viy + gt
Theta = tan-1 = (Viy/Vix)
First I calculated time:
-0.87 = (0.85)t + (1/2)(-9.8)t2
t = 0.5163 seconds ( I used quadratic formula)
Second I calculated Delta x:
Delta x = (4.02)(0.5153)
Delta x = 2.07
There are three rings placed at equal intervals throughout Delta x so:
x1 = 0.5175(ring 1)
x2 = 1.035 (ring 2)
x3 = 1.5525 (ring 3)
x4 = 2.07 (target)
Time to reach each target:
Ring 1: 0.129075 seconds
Ring 2: 0.25815 seconds
Ring 3: 0.387225 seconds
Target: 0.5163 seconds
Height of each ring:
Delta Y1 = (0.86)(0.129075) + (1/2)(-9.8)(0.129075)2 + 0.87 = 0.898
Delta Y2 = (0.86)(0.25815) + (1/2)(-9.8)(0.25815)2 + 0.87 = 0.76
Delta Y3 = (0.86)(0.387225) + (1/2)(-9.8)(0.387225)2 + 0.87 = 0.464
Delta Y4 = (0.86)(0.5163) + (1/2)(-9.8)(0.5163)2 + 0.87 = 0.008
Angle For Each Ring:
Ring 1: Vy = (-9.8)(0.129075) + 0.85 = -0.41493
theta = tan-1 = (0.41493/4.02) = 5.89 degrees
Ring 2: Vy = (-9.8)(0.25185) + 0.85 = -1.67987
theta = tan-1(1.67987/4.02) = 22.67 degrees
Ring 3: Vy = (-9.8)(0.387225) + 0.85 = -2.944805
theta = tan-1(2.944/4.02) = 36.21 degrees
With these calculations my lab group and I attempted to shoot through Ring 2 and hit the target. Our ring 2 fell short of the projectile, however the projectile still hti the target close to the bullseye. We also have to shoot through ring 3.
Could someone help?
Much Appreciated.
Is there a specified distance from the cannon for each of the 3 rings?
Also, what were \Delta[/tex]X and \Delta[/tex]Y for the projectile when fired at 0 degrees?
Fired at 0 degrees:
Delta x:
For 1 click: 1.28 meters
For 2 clicks: 1.68 meters
For 3 clicks: 2.28 meters
Note* clicks means how much we compressed the spring within the cannon
Delta y = 0.87 meters
Each of the three rings are set at equal intervals of 1/4 of delta x.
kLPantera said:
Calculated Data:
Vix = 4.02 m/s
Viy = 0.85 m/s
Vo = 4.11 m/s
How did you come up with these values?
(This appears to be the beginning of your problems).
kLPantera said:
Fired at 0 degrees:
Delta x:
How many clicks did you use when you fired the cannon at 12^\circ[/tex]?
Delta x = 2.07
...but you already calculated \Delta[/tex]x:<br /> <br /> <blockquote data-attributes="" data-quote="kLPantera" data-source="post: 2995755" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> kLPantera said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Fired at 0 degrees:<br /> <br /> Delta x:<br /> <br /> For 1 click: 1.28 meters<br /> For 2 clicks: 1.68 meters<br /> For 3 clicks: 2.28 meters </div> </div> </blockquote>
First we fired at 0 degrees, which we then used to find Vo
Vix and Viy were found after he gave us the angle of degree to fire it at.
For Delta x we had a Delta x for when it was 0 degrees. We then were given an angle to fire at. We have to find the Delta x for when it will be fired at 12 degrees.
We used 2 clicks when firing at 12 degrees.
So, for 2 clicks at 0^\circ[/tex], you had a \Delta[/tex]x of 1.68 meters.&lt;br /&gt; Also, at 0 degrees, Vi&lt;sub&gt;y&lt;/sub&gt; is 0 m/s&lt;br /&gt; Therefore, using \Delta y = V_{iy} t + \frac{1}{2}a_y t^2[/tex], we get&amp;lt;br /&amp;gt; -0.87 = \frac{1}{2}(-9.8)t^2[/tex]&amp;amp;lt;br /&amp;amp;gt; Solving for t, we get 0.421 sec.&amp;amp;lt;br /&amp;amp;gt; &amp;amp;lt;br /&amp;amp;gt; Now, using \Delta x = V_{ix} t[/tex], we get (for 2 clicks):&amp;amp;amp;lt;br /&amp;amp;amp;gt; 1.68 = V_{ix} (0.421)[/tex]&amp;amp;amp;amp;lt;br /&amp;amp;amp;amp;gt; Solving for V_{ix}[/tex], we get 3.99 m/s&amp;amp;amp;amp;amp;lt;br /&amp;amp;amp;amp;amp;gt; &amp;amp;amp;amp;amp;lt;br /&amp;amp;amp;amp;amp;gt; Therefore {V_o}^2 = {V_{iy}}^2 + {V_{ix}}^2[/tex] and, thus V_o[/tex] = 3.99 m/s&amp;amp;amp;amp;amp;amp;amp;lt;br /&amp;amp;amp;amp;amp;amp;amp;gt; &amp;amp;amp;amp;amp;amp;amp;lt;br /&amp;amp;amp;amp;amp;amp;amp;gt; &amp;amp;amp;amp;amp;amp;amp;lt;br /&amp;amp;amp;amp;amp;amp;amp;gt; Use this value of V_o[/tex] for any angle of projection using 2 clicks.
Thanks again!
