Pauli Matrices and orthogonal projections
clumsy9irl
Ok, I'm working with the Pauli Matrices, and I've already gone through showing a few bits of information. I've got a good idea how to keep going, but I'm not exactly sure about this one--
say M= 1/2(alphaI + a*sigma)
where alpha E C, a=(ax, ay, az) a complex vector, a*sigma=ax sigmax+ay sigmay+ az sigmz, and I is the identity matrix.
So, an orthogonal projection means that for a matrix P, P^2 and P dagger are both equal to P, right?
Supposedly alpha and a can beonstrained so that M is an orthogonal projection.
How would I go about doing that? :confused:
Thanks muchly!
Some hints
Hey there !
Here are some hints on a was to do it :
You will only use the fact that M^2 = M...
1) Compute M^2 :
M^2 = \cfrac{1}{4}\left(\alpha I + \sum_i a_i \sigma_i \right)^2 = ...
You will find a term like \sum_i \sum_j a_i a_j \sigma_i \sigma
In order to reduce this term, use some common identities :
\sigma_i \sigma_j = I \delta_{ij} + i \epsilon_{ijk} \sigma_k
and
\sigma_i \sigma_j + \sigma_j \sigma_i = 2 \delta_{ij} I
If you applied them correctly, you should get something quite simple. You then use the fact that M^2 = M and you will find by identification :
\alpha = 1 \text{ and } ||a|| = 1, which is your final answer (Hopefully, I didn't mess up).
If you're not confident with the use of the Levi-Civita symbol, another (more tedious) way is to write all in matrix notation (2x2), compute M^2 and put this equal to M... You will get 4 equations, which will reduce to the answer given above.
Hope this helps,
Cheers,
Florian
i must've screwed something up, for I'm getting a sqrt(2) for my alpha?
maybe i screwed up something with the identities...
oh, and i almost forgot, THANK YOU VERY MUCH!
can we solve the particle in a box problem using schrodingers equation?
Sure, it's easy; they do it in Halliday and Resnick.
(But not with the Pauli spin matrices.)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
