Verifying Solution for PDF to CDF and Inverse CDF Calculations
  • Thread starter Thread starter zzmanzz
    Cdf Inverse Pdf
The discussion focuses on verifying the solution for the probability density function (PDF) and its corresponding cumulative distribution function (CDF) and inverse CDF calculations. The provided PDF is defined as p(x) = 0 for x < 0, 4x for 0 ≤ x < 0.5, and -4x + 4 for 0.5 ≤ x < 1. The CDF derived is CDF = 0 for x < 0, 2x² for 0 ≤ x < 0.5, -2x² + 4x - 1 for 0.5 ≤ x ≤ 1, and 1 for x > 1. The inverse CDF was noted to have an error in the root selection for the interval 0.5 ≤ x ≤ 1, which could yield values greater than 1.
  • Understanding of probability density functions (PDFs)
  • Knowledge of cumulative distribution functions (CDFs)
  • Familiarity with inverse functions in probability theory
  • Basic algebraic manipulation and solving equations
  • Review the properties of probability density functions (PDFs)
  • Study the derivation of cumulative distribution functions (CDFs) from PDFs
  • Learn about inverse CDF calculations and their applications
  • Explore common errors in probability calculations and how to avoid them
Students studying probability theory, statisticians verifying statistical models, and educators teaching concepts of PDFs, CDFs, and inverse functions.
zzmanzz
I was hoping someone could just verify this solution is accurate.
p(x) =
0 , x < 0
4x, x < .5
-4x + 4 , .5 <= x < 1
Find CDF and Inverse of the CDF.
CDF =
0 , x < 0
2x^2 , 0 <= x < .5
-2x^2 + 4x - 1 , .5 <= x <= 1
1, x > 1
Inverse of the CDF
0 , x < 0
sqrt( x / 2) , 0 <= x < .5
1 + sqrt ( 1 - x) / sqrt ( 2 ) , .5 <= x <= 1
1, x > 1
Thanks[/B]
p(x) =
0 , x < 0
4x, x < .5
CDF =
0 , x < 0
2x^2 , 0 <= x < .5
1, x > 1
Inverse of the CDF
0 , x < 0
1, x > 1
Thanks[/B]
You chose the wrong root for ##.5 \leq x \leq 1##. Can you see why?
Thanks for pointing that out. The value for that should also be between .5 and 1, and with that root, it can be greater than 1?
Yes, just look at it: you have ##1 + \text{something positive}##.
Thank you!
10K
12K
  • · Replies 105 ·
