Peculiar Acceleration: Solving a Massless and Frictionless Pulley Problem
3 replies · 2K views
Vibhor
All pulleys are massless and frictionless and string is massless . Find the acceleration of the two masses and the two pulleys .
I will call the left mass A and right mass B and left pulley P and right pulley R .
Acceleration of B is same as pulley R .
From the string constraint , the relationship between accelerations is ##a_P = a_A+2a_B##
Consider the forces on pulley P . Since it is massless , tension in the string has to be 0 .
Since tension is zero , accelerations of both A and B is ##g## downwards .
Acceleration of pulley P comes out to be ##3g## downwards .
The results look quite strange , especially the acceleration of left pulley .
How is left pulley P accelerating downwards with acceleration greater than g ?
Cam someone point out the mistake .
Many thanks
I don't see why it should not. Even if it had mass, it would be possible to construct a pulley arrangement with other, larger masses that would make it drop faster than g.
OK. So the result that acceleration of pulley P is ##3g## downwards is correct ?
Your reasoning all looks right to me.
