Pendulum with horizontal spring
1 reply · 7K views · last reply
mountainbiker
A 5kg sphere is connected to a thin massless but rigid rod of length L=1.3 m to form a simple pendulum. The rod is connected to a nearby vertical wall by a spring with a spring constant k= 75N/m, connected to it at a distance h=1.1 m below the pivot point of the pendulum. What is the angular frequency (in rad/s) of the system for small amplitude oscillations.
[tex]\alpha[/tex] = [tex]\omega[/tex]2*[tex]\theta[/tex]
I=m*r2
Torque=f*d*sin[tex]\theta[/tex]
or small oscillations, sin[tex]\theta[/tex]=[tex]\theta[/tex] and cos[tex]\theta[/tex]=1
sum the torque and set them equal to [tex]\alpha[/tex]I
gravitational torque= Lmg[tex]\theta[/tex]
if theta is the angle between the rod and its equilibrium position, the angle of the spring torque is (theta + [tex]\pi[/tex]/2), so the spring torque is
f*d*sin(theta + [tex]\pi[/tex]/2). The force is k*[tex]\Delta[/tex]x, or h*sin(theta + [tex]\pi[/tex]/2) and the distance is h, giving
torque from spring =k*h2*sin[tex]\theta[/tex]*sin(theta + [tex]\pi[/tex]/2)
or k*h2*[tex]\theta[/tex]*(theta + [tex]\pi[/tex]/2)
My final equation is
mL2[tex]\omega[/tex]2tex]\theta[/tex] = Lmg[tex]\theta[/tex] + k*h2*[tex]\theta[/tex]*(theta + [tex]\pi[/tex]/2)
The problem is that this gives me a [tex]\omega[/tex] that is dependent on [tex]\theta[/tex], which isn't possible. It should be constant. Can someone please tell me where I'm going wrong?
  • Diagram of a simple pendulum with a horizontal spring: a ceiling bar with a vertical rod hanging from it to a sphere at the bottom, a zigzag spring attached to the rod and a wall on the right, with dimension arrows labelled L (rod length) and h (height of spring attachment below the pivot).
sin(theta+pi/2)= cos(theta). For small angles, cos(theta) =1.
ehild
