Perceived Height and actual height
  • Level: Undergrad
  • Thread starter Howlin
    Height
21 replies · 5K views · last reply
Howlin
Hi all,
I want to calculate the perceived height of a number of mountains.
I know the height and distance from one of the mountains.
If the hieght of the mountain is 925 metres and the distance is 20000 metres away, is there a method of calculating the perceived height for this mountain and then using that, can the perceived height of mountain heights adjacent to it be calcualted also?
PS I know a mountain height if 925 metres does not seem that high but in a country where the highest mountain is just over 1000 metres, it is considered one here
Thank for you help.
How are you defining "perceived" height?
For your situation the math is not too difficult. Knowing the range to a peak, and the curvature of the Earth, you can calculate the angle between the horizontal and the peak.
The heights of the Himalayan peaks were all sighted with a theodolite from various known positions in India. The position of the peaks could then be found by triangulation, then the range and elevation angle gave the height of the peak above the observer and so above sea level. All computations were done using an elliptical Earth model.
@Howlin
You could use Google Earth. Identify your position as observer. Draw lines from there to each peak of interest. Right click on the line, then select “show elevation profile”. Check that the peak is visible and not obstructed by intermediate topography. Read off the average slope of the line.
That will not allow for atmospheric refraction of the line of sight, which will usually raise distant objects.
https://en.wikipedia.org/wiki/Atmospheric_refraction
See also; Prominence; https://en.wikipedia.org/wiki/Topographic_prominence
Try this link if you don't like sums.
  • Skeptical
Piltdown effect. The missing link in your post.
My PM to you is blocked.
  • Haha
Howlin said:
Hi all,
Thank for you help.
NOTE:
The January 2002 issue of National Geographic magazine printed an interesting confirmation of the validity of Meier's claims. In that issue, I found a newsbrief which acknowledges that, just as Meier claimed back in the 1970s, Mt Everest is not the highest mountain on Earth.
Meier, in his writings, stated the Pleiadians told him that Mt Chimborazo in Ecuador was higher than Mt Everest by 2,150 metres because the Earth is not perfectly round but, rather, bulges in the middle-thus, measuring mountains from sea level is not an accurate way of assessing the true height of a mountain.
National Geographic states that scientists have now determined that the Earth bulges around the middle because of the spinning action of the Earth's rotation, and thus, when measured from the center of the planet, Mt Chimborazo is actually higher than Mt Everest by 2,200 metres. Measured from sea level, Mt Everest is 2,540 metres higher than Mt Chimborazo. The newsbrief states that when measured from the centre of the Earth, Mt Chimborazo is 6,384,450 metres high and Mt Everest is 6,382,250 metres high.
I am also more than 6,000 kilometres high, when measured from the center of the Earth.
The question was about the perceived height of a mountain, viewed from the surface, not measured from the centre of the Earth.
Mt Chimborazo is higher than Mt Everest in terms of both air temperature and barometric pressure.
And what is "perceived height"?
It is difficult for a person to judge the actual distance to a far off mountain. Since range is unsure, the perceived height would need to be measured as an elevation angle, above the observers horizontal. The perceived height would vary with the location of the mountain relative to the perceptor.
The changing refraction of light in the Earth's atmosphere makes the computation more complex.
So this perceived height is the angular elevation above the horizont?
Is this a terms used in a specific field?
When I look it up with Google I get quite different meaning, referring to people's height.
No, the OP question was poorly worded. The OP has not returned to explain their meaning, so we must read between the lines to reduce the possibilities.
Then you should try different search terms.
The OP refers to the perceived height of a number of mountains. Only an angular measure can work when the mountains vary in range from the observer.
Given the height and location of some mountains, how would you predict what the mountains would look like on the horizon, from the observers point of view? A small near-by mountain could appear to be the same angular height as a tall far-off mountain.
I believe that we should rather find out what the question is before answering what we guess it may be the question. :smile:
The OP is the one who should explain what he means by "perceived height".
Since the OP has not returned in the last two weeks with an answer we can but take a well educated guess.
I considered prominance in post #4. But I think we may be looking at the gently rounded hills in Ireland, 44 km South of Dublin. The area has been covered by an ice sheet, so it has lost it's peaks.
Lugnaquilla Mountain, 925 m, Ireland, is the highest peak in the Wicklow Mountains.
Carrauntoohil in Co. Kerry is famous for being the highest peak in all of Ireland as it stands at a whopping 1,038 metres in height.
I remember seeing a film, once, about a village in Wales and the inhabitants transported a vast amount of rock and stone to make their local mountain the height in the whole -( or some part ) of Wales.
Not the best film I ever saw, I'm afraid but it did lodge in my memory.
I missed the mention of Prominence, which would seem to fit the use of 'perceived' or 'apparent'. Height and distance are always measured between two points, one being a reference.
Coincidentally, I've been watching Secrets of the Irish Landscape on Amazon Prime.
Book - https://www.amazon.com/dp/1782050108/?tag=pfamazon01-20
Video - https://www.amazon.com/dp/B01LG65CAO/?tag=pfamazon01-20
I have to visit Clare Island, among other places. My ancestry goes back to the area around Sligo, as well as the Hebrides and Highlands.
