Periodic spiral graph interpretation
17 replies · 3K views · last reply
DaveC426913
2025 Award
TL;DR
Is this graph spiral or merely polar?
Could someone explain the geometry of this graph?
  • Why does the radial distance vary non-uniformly? To-wit: Distance from origin to Nov 2020 is much larger than Nov 2020 to Nov 2021
  • Why are there two areas - one above and one below - the centre line?
https://www.nytimes.com/2022/01/06/opinion/omicron-covid-us.html
Polar spiral chart of New Covid-19 cases in the United States from 2020 to January 2022, with a shaded band around a 7-day average line; the radius grows as the spiral advances through each year, with a 150K cases scale key.
DaveC426913 said:
Summary:: Is this graph spiral or merely polar?
It's spiral, and the only reason for doing it this way is to convey the information in less space than a linear graph would take. The radial distance varies, I believe, to leave room for the bulging sections.
To display the data for 1) Apr to Oct of 2020, and 2) for Apr to Oct of 2021.
Don't overthink this...
No, I mean why is it symmetrical about the centerline? This is common in graphs that differentiate gender - having male on one side and female on the other, but I doubt that the case here.
Except it doesn't do that. :))
I think that is just a decision that the graph-maker made. It may have no significance at all, except that someone thought the graph looked better that way (and I tend to agree).
Because that's how the person who made the graph wanted it.
Sure it does -- look how fat the sections for January are.
Again, don't overthink this.
Yet the biggest gap between 2020 and 2021 is in October.Anyway, I grant your point. So much visualization opportunity lost. I will just have to out this rendering down as an affront to the god of graphs.
It's weird. The width of the path is the daily cases, the angle is the time in the year, the distance to the origin seems to have no significance.
IMO, it looks like some intern at the NYT had way too much time on their hands, and basically hand-drew a graph to try to visualize the data. There are clear non-symmetries that suggest the hand-drawn aspect. Whatever.
Pink shaded band curving across the image with a dark curved line through its center, labeled 2021 with an arrow and 7-day average at the top.
Are you sure that's an asymmetry? The curve on the bottom will have will appear to have an amplified amplitude, because its ... er ... x-axis is compressed.
Diagram of a pink curved band with a thin grey centre curve and a fan of radiating black lines converging to a point at the bottom, with a label reading 2023 in the middle of the band.
Whelp, if I were an intern trying out different graphing schemes and saw that apparent misinformation in my graph, I'd change to a single-sided representation... Interns, kids, what'cha going to do...
I added an analysis, above.
Wait, so YOU are the intern?
What? No.
I just Photoshopped the diagram.
When you see the lines that are perpendicular to the curve, the asymmetry disappears.
These circles are centred on the central black line. Their radii touch both red curves. So upper and lower red curves are symmetrical about the black central line.
Diagram of a curved pink band with a black centre line, with circles centred on the centre line touching both red edges and straight black lines fanning across the curve, with the label 2021 written on it.
Comparing their graph to an Archimedean spiral(r = aθ + b), I found that if I shift their graph to the right by ≈58 pixels, it comes out pretty close.
Plot of three spirals on x-y axes from -600 to 600: a blue Archimedean spiral, a yellow NYT original spiral, and a red NYT spiral shifted 58 pixels right, with a second small chart of r against x beside it.
Huh. I guess the asymmetry of the spiral is also an optical delusion.
Possibly. I notice that if I fiddle with the constants for the Archimedean spiral, I get an even closer fit, and an apparent stretching in the quadrant 1 and 3 directions displays itself.
Graph in x-y coordinates of a blue spiral curve with dots along it, overlaid with a black curve, with axis ticks at 500 and -500; the parametric equations r = -37.381t + 176.56 and θ = t for t from π/2 to 3.5π are shown above.
I'm not sure I've ever smooshed something diagonally, mathematically.
I might be able to get a perfect fit, if I can figure that out.
Off the top of my head, it looks like a pain in the butt.
I could rotate everything 45° counter clockwise and then smoosh it in the y direction.
Perhaps I'll try googling this for a better method. My brain is just too old.
Sunuvagun. I would not have believed it if I hadn't seen it.
Spiral diagram with a red-shaded band following a black curve that winds outward, with dashed radial guide lines and faint circles, labeled 2020, 2021 and 2022 at successive turns.
I think two things threw me.
1. There's a missing quadrant:
Polar plot of a closed loop with dashed radial guide lines from a central point, a red dashed arc marking a missing quadrant, and a label reading 2020 with an arrow on the outer curve.
2.
The slope varies wildly along the slope.
Polar plot of a closed loop with a pink shaded band around a grey curve, dashed radial guide lines from the centre, short blue tangent marks along the curve, and the label 2020 with an arrow near the upper right.
