Perturbation Theory: Calculating 2nd Approx of E in Hydrogen 2s State
The discussion revolves around applying perturbation theory to calculate the second approximation of energy for hydrogen atoms in a 2s state. The key point is that when summing over states, one must exclude the state corresponding to n and consider all other states, which may include various quantum numbers. It is clarified that in cases with degeneracies, such as the van der Waals interaction between different states, a different approach is needed, specifically degenerate perturbation theory. The participants express confusion about when to sum over all quantum numbers versus when to restrict the sum due to degeneracies. Understanding these distinctions is crucial for correctly applying perturbation theory in different scenarios.
Gavroy
hi
i want to calculate the second approximation of the energy by a potential V between two hydrogen atoms in a 2s state, but I do not know how to apply pertubation theory correctly?
Landau Lifgarbagez says:
E_n^2= \sum_m ' \frac{|V_m_n|^2}{E_n^0-E_m^0}
(where the prime means that the term with m=n is omitted from the sum)
my problem is, that if i take n=2, as it is a 2s-state, shall I start with the term m=1, leave out m=2 and go on with m=3, m=4, m=5... in the sum
or does this in a 2s-state mean, that i leave out the m=1 and m=2 state and start with m=3, m=4, m=5...
Gavroy said:
hi
The sum is over all m distinct from n. The labeling of the states is the same as how you label them in the unperturbed case (where you have a free choice).
okay thank you
do you know whether it should only be summed over all principal quantum numbers or do i need to sum over all principal, azimuthal and magnetic quantum numbers?
i am not quite sure about this, cause this kind of pertubation theory deals with the undegenerated case, doesn't it?
Gavroy said:
okay thank you
If your system has degeneracies in the unperturbed system but fewer in the perturbed system then this simple formula simply doesn't apply anymore,a nd you need to use the formulas for degenerate perturbation theory.
If your perturbed system has the same symmetries as the unperturbed one, you can restrict to a subspace where all quantum numbers corresponding to the symmetry group are fixed, and then solve the eigenvalue problem on this subspace. In this case, you only sum over the eigenvalues distinct from n with these quantum numbers fixed.
thank you for your explanation, but actually, i should have referred to my real problem, sorry
http://galileo.phys.virginia.edu/classes/752.mf1i.spring03/vanderWaals.pdf"
it is on page 3
in this example, they calculate the van der waals forces between two hydrogen atoms in the 1s-state.
so my question is: why are they allowed to sum over all quantum numbers n,l,m (and for the other hydrogen atom n',l',m') ?
however, in the case of van der waals interaction between the 1s and 2p-state they solve the secular equation(page 5)?
sorry, that i behave that stupidly, but could you explain to me the reason why they :
in the first case, are able to sum over all quantum numbers
and in the second case have to use a different kind of pertubation theory?
actually, i assume, that i just do not know, what is necessary that the amount of degeneracies is reduced.
(and by the way: sorry for my english, but i am from germany and I still go to school)
it is on page 3
They are not anly allowed, they have to!
This is because they only treat here the degenerate part..
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 49 ·
