Perturbation to Flat Space Metric: Geodesic Equation
The discussion focuses on the perturbation of the flat space metric and its implications for the geodesic equation in a non-relativistic context. The participants analyze the metric tensor's components, particularly how the perturbation, denoted as hμν, affects the calculation of the inverse metric tensor gμν. They establish that for small perturbations where |hμν| << 1, the inverse metric can be approximated as gμν ≈ ημν - hμν. The conversation also explores the implications of non-zero off-diagonal terms in the general case, emphasizing the need for careful consideration of matrix formulations in these calculations.
  • Understanding of the geodesic equation in general relativity.
  • Familiarity with metric tensors and their properties.
  • Knowledge of perturbation theory in the context of physics.
  • Basic matrix algebra, particularly involving inverses and products.
  • Study the derivation of the geodesic equation in general relativity.
  • Learn about perturbation methods in general relativity, focusing on metric perturbations.
  • Explore the implications of off-diagonal terms in metric tensors.
  • Investigate the matrix formulation of tensor operations in the context of general relativity.
This discussion is beneficial for theoretical physicists, graduate students in general relativity, and researchers focusing on gravitational theories and metric perturbations.
Apashanka
From the geodesic equation
d2xμ/dΓ2μ00(dt/dΓ)2=0,for non-relativistic case ,where Γ is the proper time and vi<<c implying dxi/dΓ<<dt/dΓ.
Now if we assume that the metric tensor doesn't evolve with time (e,g gij≠f(t) ) then Γμ00=-1/2gμs∂g00/∂xs.
If we here assume that the metric components of the curved part is a perturbation on the flat part
Then gμϑμϑ(flat part)+hμϑ(perturbation)
After which I got stuck in calculating the inverse components of the metric tensor gϑμ which is needed in Γμ00 above.
Can anyone please help me in sort put this.
Thank you.
because all components of ##h## are assumed to satisfy ##|h_{\mu \nu}| <<1## and also off diagonal terms are zero. Then the inverse is just $$g^{\mu \nu} = \frac{1}{\eta_{\mu \nu} + h_{\mu \nu}} \approx \eta_{\mu \nu} - h_{\mu \nu}$$ This follows from the observation: if ##a^2 - b^2 = (a + b)(a-b) = \approx 1## then ##1 / (a+b) \approx a-b##.
Yes it is but if the off diagonal terms are non-zero for the general case what will be it??
For the general case, consider that $$g_{\kappa \sigma}g^{\sigma \rho} = (\eta_{\kappa \sigma} + h_{\kappa \sigma})(\eta^{\sigma \rho} \pm h^{\sigma \rho}) = \delta_\kappa{}^\rho \pm \eta_{\kappa \sigma} h^{\sigma \rho} + \eta^{\sigma \rho} h_{\kappa \sigma} + \mathcal O (h^2) \approx \delta_\kappa{}^\rho \pm h_\kappa{}^\rho + h_\kappa{}^\rho$$ this will be equal to ##\delta_\kappa{}^\rho## only if we use the minus sign.
(indices are raised and lowered with ##\eta##)
From matrix formulation if matrices A,B and C are given with their inverses $$A^{-1},B{^-1 }$$and $$C^{-1}$$ and given A=B+C
If $$A^{-1}=B^{-1}+C^{-1}$$ ,then $$I=2I+BC^{-1}+CB^{-1}$$$$I_{ik}+b_{ij}c^{jk}+c_{ip}b^{pk}$$$$\delta_{i}^{k}+\eta_{ij}h^{jk}+h_{ip}\eta^{pk}$$$$\delta_{i}^{k}+2h^k_i=0$$
Similarly for $$A^{-1}=B^{-1}-C^{-1}$$ then $$CB^{-1}-BC^{-1}=I$$$$h_{ij}\eta^{jk}-\eta_{ip}h^{pk}=I_{ik}$$ $$h_i^k-h_i^k=\delta_i^k$$...(1)
Now if $$g_{ij}=\eta_{ij}+h_{ij}$$ and $$g^{ij}=\eta^{ij}-h^{ij}$$( where ##\eta^{ij}## is the inverse element of ##\eta_{ij}## and similarly for h also),to satisfy equation (1) that hij is not the inverse element of hij? Is it??
The notation ##h_{\kappa \sigma} h^{\sigma \rho}## means ##h_{\kappa \sigma} \eta^{\sigma \lambda} \eta^{\rho \mu} h_{\lambda \mu} = h_\kappa{}^\lambda h_\lambda{}^\rho##.
This means you are multiplying ##h## with itself: the ##\kappa##-th colunm of ##h## is being multiplied with the ##\rho##-th row of ##h##.
However ##\eta_{\kappa \sigma} \eta^{\sigma \rho} = \delta_\kappa{}^\rho## because ##\eta^{\sigma \rho}## is really the inverse of ##\eta_{\sigma \rho}##.
I'm not sure what you want to calculate, but for static solutions you can always diagonalize the metric such that the line element is invariant under a time reflection. Then the inverse of the metric is easily found.
  • · Replies 22 ·
  • · Replies 71 ·
  • · Replies 17 ·
