PF Photography: Tips, Tricks, & Photo Sharing
1,418 replies · 242K views
Geez, I feel like a bozo now. I saw these posts this morning at home, so I took some more pictures with white paper in the background and foreground. Then left the camera at home. <sigh>
So I will post the pictures tomorrow. Sorry!
But to answer the camera question, I have an Olympus E500 and am using the f3.5 macro (zuiko) to take the pictures. My macro had been stolen a while back, and I finally decided the person was never going to replace it, so I just bought a new one last weekend. In the meantime, my camera shop went out of business, so I went to one of the chain camera stores. Needless to say, I should have paid more attention. I just noticed this morning that my UV filter is some unheard of brand. Almost ALL of my filters are Tiffen or Hoya. So maybe its a crappy filter? I have not taken the filter off yet to try the picture, maybe tonight I can play around again. I never had problems with colors before with my stolen macro, but I can't remember what filter I had on it. I had owned that filter for nearly 30 years...
And Borek, to sortof answer your question, the dark purple flowers definitely turned out darker with the white paper next to them (I knew they were overexposed), but still blue. But you will have to wait till tomorrow!
From looking at your EXIF data on the second image, it says the camera is in "Creative Mode" and the saturation is set to "High". Have you tried the shot using "Manual Mode" and with normal saturation instead of high?
Edit...Also, can you shoot RAW and see if you get the same results prior to processing?
That went completely over my head... what is EXIF? And how were you able to get the information from my photo? I know how to do it on my camera and computer, but I don't know how to do it on an image from the internet... Did you have to download it?
When you say "2nd image" do you mean the flowers? Or the glass? The 2nd flower picture was taken on auto per Borek's request, and I don't remember what I did for the 2nd picture of the glass. It may have been on the macro setting, but I am not sure as I was just goofing off because I was tickled to have my macro lens again. But I do often use manual mode, although I don't have that "down pat" yet. Still learning!
And if it is truly set to high saturation, that could be my problem. I loaned my camera out (long LONG story) to someone that really screwed it up (on top of "losing" my macro lens), and I have been trying hard to get it back to normal, so that very well could be part of my problem. I haven't heard of an option on the Olympus to reset it back to factory settings, but the book said what factory settings are. I'm not sure it caught everything this person changed...
I will try RAW soon, but I think I need to find a factory reset first...
http://en.wikipedia.org/wiki/Exchangeable_image_file_format"
I collected the camera data using a free program called Opanda IExif. If you can shoot RAW, then none of the camera presets will be applied to the image and if the color turns out in the RAW image the way it ought to look, then my guess is the the factory reset would work.
Here is the Exif data from this photo:
[Image]
Image Description = OLYMPUS DIGITAL CAMERA
Make = OLYMPUS IMAGING CORP.
Model = E-500
Orientation = top/left
X Resolution = 314
Y Resolution = 314
Resolution Unit = inch
Software = Version 1.2
Date Time = 2009-04-09 14:18:09
YCbCr Positioning = co-sited
Exif IFD Pointer = Offset: 290
PrintIM Data = 528 Byte
[Camera]
Exposure Time = 1/80"
F Number = F3.5
Exposure Program = Creative program
ISO Speed Ratings = 100
Exif Version = Version 2.21
Date Time Original = 2009-04-09 14:18:09
Date Time Digitized = 2009-04-09 14:18:09
Components Configuration = YCbcr
Exposure Bias Value = ±0EV
Max Aperture Value = F3.5
Metering Mode = Pattern
Light Source = unknown
Flash = Flash fired, auto mode
Focal Length = 35mm
Maker Note = 2198 Byte
User Comment =
Flashpix Version = Version 1.0
Color Space = sRGB
Exif Image Width = 3264
Exif Image Height = 2448
Interoperability IFD Pointer = Offset: 758
File Source = DSC
Custom Rendered = Normal process
Exposure Mode = Manual exposure
White Balance = Manual white balance
Digital Zoom Ratio = 1x
Scene Capture Type = Normal
Gain Control = None
Contrast = Normal
Saturation = High saturation
Sharpness = Normal
[Interoperability]
Interoperability Index = ExifR98
Interoperability Version = Version 1.0
[Thumbnail Info]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 72
Y Resolution = 72
JPEG Interchange Format = Offset: 12820
JPEG Interchange Format Length = Length: 10456
[Thumbnail]
Thumbnail = 160 x 120
[MakerNote (Olympus)]
JPEG Quality = High Quality
Macro = Normal
0203 = 0
100F = 0
1017 = 268, 64
1018 = 148, 64
1029 = 1
102A = 0
102C = 0, 0
102D = 0
102E = 3264
102F = 2448
2010 = 17, 00, 00, 00, 07, 00, 04, 00, 00, 00, 30, 31, 30, 30, 00, 01, 02, 00, 06, 00, 00, 00, 82, 1A, 00, 00, 01, 01, 02, 00, 20, 00, 00, 00, 88, 1A, 00, 00, 02, 01, 02, 00, 20, 00, 00, 00, A8, 1A, 00, 00, 03, 01, 05, 00, 01, 00, 00, 00, C8, 1A, 00, 00, 04, 01, 04, 00, 01, 00, 00, 00, 02, 12, 00, 00, 01, 02, 01, 00, 06, 00, 00, 00, DA, 1A, 00, 00, 02, 02, 02, 00, 20, 00, 00, 00, E0, 1A, 00, 00, 04, 02, 04, 00, 01, 00, 00, 00, 08, 11, 00, 00, 05, 02, 03, 00, 01, 00, 00, 00, 9D, 03, 00, 00, 06, 02, 03, 00, 01, 00, 00, 00, 9D, 03, 00, 00, 07, 02, 03, 00, 01, 00, 00, 00, 23, 00, 00, 00, 08, 02, 03, 00, 01, 00, 00, 00, 23, 00, 00, 00, 0A, 02, 03, 00, 01, 00, 00, 00, 9D, 03, 00, 00, 0B, 02, 03, 00, 01, 00, 00, 00, 03, 40, 00, 00, 01, 03, 01, 00, 06, 00, 00, 00, 38, 1B, 00, 00, 02, 03, 02, 00, 20, 00, 00, 00, 3E, 1B, 00, 00, 03, 03, 02, 00, 20, 00, 00, 00, 5E, 1B, 00, 00, 04, 03, 04, 00, 01, 00, 00, 00, 00, 00, 00, 00, 00, 10, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 01, 10, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 02, 10, 04, 00, 01, 00, 00, 00, 00, 00, 00, 00, 03, 10, 02, 00, 20, 00, 00, 00, 8C, 1B
2020 = 29, 00, 00, 00, 07, 00, 04, 00, 00, 00, 30, 31, 30, 30, 00, 01, 04, 00, 01, 00, 00, 00, 00, 00, 00, 00, 01, 01, 04, 00, 01, 00, 00, 00, 00, 00, 00, 00, 02, 01, 04, 00, 01, 00, 00, 00, 00, 00, 00, 00, 00, 02, 03, 00, 01, 00, 00, 00, 02, 00, 00, 00, 01, 02, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 02, 02, 03, 00, 01, 00, 00, 00, 05, 01, 00, 00, 00, 03, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 01, 03, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 02, 03, 03, 00, 01, 00, 00, 00, 01, 00, 00, 00, 03, 03, 03, 00, 01, 00, 00, 00, 01, 00, 00, 00, 04, 03, 04, 00, 40, 00, 00, 00, CC, 1B, 00, 00, 00, 04, 03, 00, 01, 00, 00, 00, 01, 00, 00, 00, 01, 04, 0A, 00, 01, 00, 00, 00, D0, 1C, 00, 00, 02, 04, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 00, 05, 03, 00, 01, 00, 00, 00, 00, 01, 00, 00, 01, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 02, 05, 08, 00, 02, 00, 00, 00, 05, 00, 00, 00, 03, 05, 08, 00, 03, 00, 00, 00, E2, 1C, 00, 00, 04, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 05, 05, 08, 00, 03, 00, 00, 00, EA, 1C, 00, 00, 06, 05, 08, 00, 03, 00, 00, 00, F0, 1C, 00, 00, 07, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 08, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 09, 05, 03, 00, 01, 00, 00, 00, 06, 00, 00, 00, 0A, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 0B, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 0C, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 0D, 05, 05, 00, 01, 00, 00, 00, 00, 1D, 00, 00, 0E, 05, 03, 00, 01, 00, 00, 00, 01, 00, 00, 00, 0F, 05, 08, 00, 03, 00, 00, 00, 0A, 1D, 00, 00, 20, 05, 03, 00, 01, 00, 00, 00, 01, 00, 00, 00, 21, 05, 08, 00, 03, 00, 00, 00, 14, 1D, 00, 00, 22, 05, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 23, 05, 08, 00, 03, 00, 00, 00, 1C, 1D, 00, 00, 24, 05, 08, 00, 03, 00, 00, 00, 22, 1D, 00, 00, 25, 05, 08, 00, 01, 00, 00, 00, 00, 00, 00, 00, 26, 05, 08, 00, 01, 00, 00, 00, 00, 00, 00, 00, 00, 06, 03, 00, 03, 00, 00, 00, 2C, 1D, 00, 00, 03, 06, 03, 00, 01, 00, 00, 00, 02, 00, 00, 00, 00, 08, 03, 00, 01, 00, 00, 00, 00, 00
2030 = 0E, 00, 00, 00, 07, 00, 04, 00, 00, 00, 30, 31, 30, 30, 00, 01, 0A, 00, 01, 00, 00, 00, 40, 1D, 00, 00, 01, 01, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 02, 01, 08, 00, 01, 00, 00, 00, 00, 00, 00, 00, 03, 01, 03, 00, 03, 00, 00, 00, 4C, 1D, 00, 00, 04, 01, 08, 00, 03, 00, 00, 00, 52, 1D, 00, 00, 05, 01, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 06, 01, 08, 00, 03, 00, 00, 00, 5A, 1D, 00, 00, 07, 01, 08, 00, 03, 00, 00, 00, 60, 1D, 00, 00, 08, 01, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 09, 01, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 0A, 01, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 0B, 01, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 0C, 01, 03, 00, 01, 00, 00, 00, 00, 00
2040 = 1A, 00, 00, 00, 07, 00, 04, 00, 00, 00, 30, 31, 31, 31, 00, 01, 03, 00, 02, 00, 00, 00, 0C, 01, 94, 00, 1F, 01, 03, 00, 01, 00, 00, 00, 00, 01, 00, 00, 00, 02, 03, 00, 09, 00, 00, 00, D8, 1D, 00, 00, 00, 03, 03, 00, 01, 00, 00, 00, 80, 04, 00, 00, 10, 03, 03, 00, 01, 00, 00, 00, 80, 04, 00, 00, 31, 03, 03, 00, 08, 00, 00, 00, B4, 23, 00, 00, 00, 06, 03, 00, 04, 00, 00, 00, 60, 24, 00, 00, 10, 06, 03, 00, 01, 00, 00, 00, 00, 01, 00, 00, 11, 06, 03, 00, 02, 00, 00, 00, 00, 00, 00, 00, 12, 06, 03, 00, 02, 00, 00, 00, 1B, 00, 00, 00, 13, 06, 03, 00, 02, 00, 00, 00, 1F, 00, 00, 00, 14, 06, 04, 00, 01, 00, 00, 00, C0, 0C, 00, 00, 15, 06, 04, 00, 01, 00, 00, 00, 90, 09, 00, 00, 17, 06, 03, 00, 01, 00, 00, 00, 01, 00, 00, 00, 00, 08, 0B, 00, 09, 00, 00, 00, AC, 24, 00, 00, 01, 08, 03, 00, 10, 00, 00, 00, D0, 24, 00, 00, 02, 08, 05, 00, 01, 00, 00, 00, F0, 24, 00, 00, 00, 10, 03, 00, 02, 00, 00, 00, 00, 00, 96, 39, 01, 10, 03, 00, 02, 00, 00, 00, 00, 00, 00, 00, 02, 10, 03, 00, 02, 00, 00, 00, 00, 00, EF, BE, 03, 10, 03, 00, 01, 00, 00, 00, 09, 00, 00, 00, 04, 10, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 10, 10, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 11, 10, 03, 00, 01, 00, 00, 00, 00, 00, 00, 00, 12, 10, 03, 00, 01, 00, 00, 00, 00, 00
Ms Music,
It looks like you are having trouble correcting white balance. If you're using flash, you need to set the camera to "flash" white balance, and use a strong enough flash to drown out any other light sources that have a different white balance. (Flashes are balanced to be very close to daylight, at noon.)
If you're using ambient light, you either need to guess (using the "tungsten" or "fluorescent" or "shade" settings), or you need to use a white reference and use your camera's manual white-balance function.
The UV filter will have very little effect except outside in strong sunlight, when UV reflection can add a bit of haze. Indoor lights just don't produce any significant UV, and you won't notice the effects of UV reflection over short distances like those in your home.
- Warren
Edit scratch that post comparing the exif data you may have received in the email notice.
See next post
WOW! I wonder if they have that for the mac? I will have to look into that! So cool, thanks for sharing.
I see now why I should try RAW. Probably won't do it tonight, still feeling rather puny and sick. Flowers are still looking pretty good, so I think I have a few days. So I will try that soon and let you know? Although that shot WAS taken in auto mode...
Chroot: just saw your post, I did manually adjust the wb specifically for that shot... which actually worked better than using any of the presets for lighting. And I think I said this earlier, but I have compact flourescent lights in my house.
Gotta run folks...
Comparing the Exif data between the two glass shots show a change in ISO from 400 to 100 in the new shot and the gain control in the old shot is "high gain up" compared to "none" in the new shot.
Here is the Exif for the old glass shot followed by the new shot Exif.
[Image]
Model = E-500
X Resolution = 314
Y Resolution = 314
Date Time = 2006-11-12 16:24:16
[Camera]
F Number = F8
ISO Speed Ratings = 400
Date Time Original = 2006-11-12 16 24 16
Date Time Digitized = 2006-11-12 16:24:16
Focal Length = 35mm
User Comment =
Color Space = sRGB
File Source = DSC
Exposure Mode = Auto exposure
White Balance = Auto white balance
Gain Control = High gain up
Contrast = Normal
Sharpness = Normal
[Interoperability]
New shot Exif:
[Image]
Model = E-500
X Resolution = 314
Y Resolution = 314
Date Time = 2009-03-28 14:50:54
[Camera]
F Number = F8
Date Time Original = 2009-03-28 14:50:54
Date Time Digitized = 2009-03-28 14:50:54
Focal Length = 35mm
User Comment =
Color Space = sRGB
File Source = DSC
Gain Control = None
Contrast = Normal
Sharpness = Normal
[Interoperability]
One more thing to note: it looks like some of your white references are actually overexposed. If you overexpose a white reference, you will saturate the sensor, and it'll look perfectly white, even when it isn't. Make sure you use the blinkies or histogram to prevent that.
- Warren
There is something similar for the Mac.
http://www.macupdate.com/info.php/id/19758"
or
http://homepage.mac.com/aozer/EV/"
Anyway, my daughter was counting the coins in her piggy bank, when she found this coin of about 9mm diameter:
Camera Canon 450D Lens 100 mm EF Macro at 32 cm distance magnification 0.98, shrunk to 25%
Life size crop of the crown (W-side)
It's a half cent of a Dutch guilder. She is now trying to find out if it has some value.
Thanks, larkspur. I will print those and go home and go through the comparisons line by line. I'm just now starting to realize how much this person screwed up my camera. And who knows why... But I will learn a lot having to get it back to normal!
But what I think is funny, is I found a tiny bug crawling on the couch last night, so I picked it up and put it on an envelope, and started taking pictures. They turned out fine. But other times I can't get a decent shot for anything... I just need to find some time to take a class. And I need to get that camera working the way it used to...
And thanks for the links. I am still amazed at how much information you can pull from an internet photo.
Andre: Cool coin!
OK, here's a really dumb mistake that could have been avoided. I stopped off at the scenic lookout in back of my property and snapped some pictures. Only after I started playing with them them today did I think that I should stitch them in a panorama, and of course, I should have metered, averaged, and set the exposures manually. I took the lazy way and ended up cloning the sky to get rid of really objectionable banding due to exposure changes in the pan. Duh! Note to self: if you are going to take scenery shots, expose them manually. Warning: Fairly big file. As you can see, there is still plenty of snow on the East slopes of the Western mountains, but we're in a warm dry stretch and the rivers are behaving so far with gradual melting.
http://i183.photobucket.com/albums/x318/turbo-1/pan.jpg
Cloning or not, I really like that. Beautiful shot, even if you had to get it the hard way.
Thanks. I can get a similar shot from the hill that I live on, though foreground trees, etc obscure some. This was shot from a smaller hill less than a mile in back of my place, and it has a nice view over the Kennebec river valley. If you look to a larger complex of mountains to the right, you'll see ribbons of show here and there - that's the Sugarloaf ski resort.
Pretty small I would say, perhaps you have linked some sized down version?
Big version please, small one was interesting enough :smile:
Strange, I think I remember much larger picture (in terms of resolution) that you took in Autumn.
Thanks :smile:
I can try to prepare a panorama from my roof one day, but it will be boring flat and full of boring flats :frown:
Larkspur, I did take the picture the other day under the exact same lighting conditions, but in RAW, and the flowers still turned out very very bright blue. I will post if you want to look at the numbers, but so far I keep forgetting to upload the picture.
And then hope to remember to change it back, so as I don't fill my card with only 10 pictures... hah.
~christina~ said:
Nice panorama, turbo
Thanks, ~~! Next time I get a clear day, I'll take the 5-minute trip over to that hill and shoot it again with manual settings and my new Manfrotto 808RC4 tripod head. I've had a really nice, heavy Bogen tripod sitting around unused for almost 20 years. I robbed the head off it to mount on a Gitzo Pro Studex that I picked up for $75 at an insurance-salvage store and sold the Gitzo when I went digital (back when digi-cams were all tiny). Finally had to spring for a real tripod head instead of messing around with jury-rigged alternatives.
Did you change the white balance later? I think most Raw files appear with the white balance set to some default level, but allow you to edit it later.
Your lucky to have such a view after just taking a 5 min trip. I think you should try making a HDR shot. It would be great.
Interesting, I got a tripod for Christmas, and want to use it to take pictures of a sunset.
I haven't use it yet because it would look pretty funny to see me at the zoo, carrying a large tripod around as I'm not too tall. People already gave me funny looks when they saw me with a 300mm lens on my camera...imagine tripod too? lol
A random castle from a 'frog perspective' to make it more interesting. But on the belly again.
Anybody care naming the landmark?
I will have to sit down with my book to figure out how to edit the WB. I'll see if I can here soon, as the flowers are starting to get REALLY sad looking if I need to take more pics. My daughter also found a bunch of purple stuff (crayons, markers, a flower, etc) and the pic of even those came out blue. I thought it might be the flowers, but its like my camera can't see the color purple.
Lovely castle Andre. I'd love to go to Europe some day and see castles.
Wow, I love the bridge there. Nice castle, dirty moat.
Thanks, ~Christina~ about the moat, it's in the eye of the beholder. Actually the water is clear and there is no trace of pollution. What you see is a body of floating water plants, holding an abundance of life.
