Phase constant vs amplitude in uniform plane wave problem
3 replies · 4K views · last reply
FrogPad
I don't understand something on this problem:
Q: A uniform plane wave with [itex]\vec E = \hat x E_x[/itex] propagates in a lossless simple medium ([itex]\epsilon_r = 4 \,\,\,\, \mu_r = 1 \,\,\,\, \sigma = 0[/itex]) in the +z-direction. Assume that [itex]E_x[/itex] is sinusoidal with a frequency of 100 (MHz) and has a maximum value of [itex]+10^{-4}[/itex] (V/m) at [itex]t=0[/itex] and [itex]z = \frac{1}{8}[/itex] (m)
Write the instantaneous expression for [itex]\vec E[/itex] for any t and z.
A:
Using [itex]\cos \omega t[/itex] as a reference, we find the instantaneous expression for [itex]\vec E[/itex] to be:
[tex]\vec E(z,t) = \hat x E_x = \hat x 10^{-4} \cos ( 2 \pi 10^8 t - kz + \psi)[/tex]
Since [itex]E_x[/itex] equals [itex]+10^{-4}[/itex] when the argument of the cosine function equals zero, that is when:
[tex]2 \pi 10^8 - kz + \psi = 0[/tex]
we have at [itex]t = 0[/itex], [itex]z = \frac{1}{8}[/itex]
[tex]\psi = kz = \frac{4 \pi}{3} \frac{1}{8} = \frac{\pi}{6}[/tex]
My question follows from this:
Why do we introduce the phase unknown phase [itex]\psi[/itex] and set [itex]E_x[/itex] according to this. Why couldn't we do this instead,
A:
[tex]\vec E(z,t) = \hat x E_x = \hat x E_0 \cos ( 2 \pi 10^8 t - kz)[/tex]
Set the according t=0, z=1/8 so that,
[tex]\hat x E_0 \cos ( 2 \pi 10^8 (0) - k(\frac{1}{8}) = 10^{-4}[/tex] and meet the initial condition of a max of 10^-4 with [itex]E_0[/itex] instead of setting E_0 originally and changing the phase.
I forget -- what is k in terms of lambda? It seems like the phi and the kz can influence the final equation under different constraints -- I could be wrong of course.
A:
A:
If you used
the maximum would not be 10^-4 and at t = 0 the maximum would be at z = 0.
OlderDan said:
If you used
oooooooooooooooooohhhh :)
Thanks man, that definitely makes sense! I really appreciate it.
berkeman:
[tex]k = \omega \sqrt{\mu \epsilon}[/tex]
