Photo Contest - Science and Engineering (2/25-3/2)
  • Thread starter Thread starter ZapperZ
    photo contest
11 replies · 4K views
Staff Emeritus
Homework Helper
Insights Author
Science and Engineering[/color][/size]
Since this is technically a Physics/Science forum, we should periodically have themes that reflect that topic. This is one of them.
Your photo must have clear presentation of something related to science and/or engineering. Please note that your photo must be taken using a regular camera, not using scientific instruments.
Good luck.
Zz.
Contest Rules:
Zz
Not trying to be pedantic, but I don't understand what you mean by 'regular' camera- are you referring to light imaging as opposed to (say) AFM, electron microscopy, etc? For example, is a DSLR body on a microscope or using the body with a microscope objective a 'regular camera'? What about putting a 35mm lens on an EMCCD camera? What about an infrared camera? etc. etc.
Correct. If you use it as part of scientific instrument, then it cannot be used.
I have many spectroscopic images obtained from a CCD. I cannot use those. However, CCDs are certainly used in the standard digital cameras, which are acceptable for this contest.
The key thing here is that it must be taking using an equipment that is available to the masses, not something either a part of, or attached to, a scientific instrument. If you regular digital camera that you bought at Best Buy has an IR sensor and you took a photo with it, then yes, it can be used.
Zz.
Light reading.
Ferrofluid over some neodymium magnets that I play with once in a while.
Taken using a Nikon 60mm 2.8D Micro lens.
http://img23.imageshack.us/img23/7383/ferrofluid.jpg
