Photoelectric Effect: Will Photoelectrons be Emitted?
The discussion revolves around the photoelectric effect, specifically examining whether photoelectrons will be emitted from a metal surface when irradiated with light of varying wavelengths. The original poster presents two scenarios involving a metal with a specified work function and different wavelengths of light, questioning the emission of photoelectrons based on energy calculations.
  • The original poster attempts calculations to determine the energy of photons based on given wavelengths and compares these energies to the work function of the metal. Some participants question the calculations and assumptions regarding the wavelengths, particularly the use of 180 mm versus 180 nm.
Participants are actively engaging with the original poster's calculations, with some suggesting that errors may exist in the interpretation of the wavelength units. There is a recognition that if the wavelength is indeed in millimeters, it would not lead to photoelectron emission, while the calculations for the 550 nm wavelength are acknowledged as correct. The discussion is exploring the implications of potential typos in the problem statement.
There is uncertainty regarding the correct interpretation of the wavelength for the first question, with suggestions that it may have been intended to be in nanometers rather than millimeters. This distinction is critical to the understanding of the photoelectric effect in this context.
zebra1707
Hi there. I have two questions and in both I believe that no photoelectrons will be emitted from the surface.
Question 1
A metal with a work function of 9 x 10^-19 J is irradiated with UV radiation of wavelength 180 mm. Will photoelectrons be emitted from the surface?
E = hf
f = c/λ
E = hc/λ
E = 6.63 x 10^-34 x 1.67 x 10^9
= 1.10 x 10^-24 J
The energy required to release the an electron from the metal is E0 = 9 x 10^-19
Therefore, the energy contained in the light, is insufficient to overcome the forces holding the electron to the surface of the metal.
The second question is that the same metal is used but this time irradiated by 550 nm
I come up with the following - which again indicates that nothing is released.
E = hf
f = c/λ
E = hc/λ
E = 6.63 x 10^-34 x 5.45 x 10^14
= 3.61 x 10^-19 J
Can someone please check, as the next question asks
Determine the maximum kinetic energy and velocity of any photoelectrons emitted in the above questions. But my calcs indicate that no photoelectrons are emitted. (The electrons rest mass is 9.1 x 10-31 kg.).
Cheers and thanks in advance
For 180nm light, electrons are emitted, you must have made an error in your calculation. I found the photon to have an energy of 1.1x10^(-18) J
For 550nm light, you seem to have done the calculation correctly. No electrons are emitted.
You know that smaller the wavelength, higher the energy of the photon right? How have you managed to calculate an energy for the 180nm light to be 5 orders of magnitude less than that of the 550nm light?
The first question has the wavelength at 180 mm not nanometers. Convert that to meters is 0.18 m.
Cheers
well ok! If that's the case then you're right on that one too... does make asking the electrons kinetic energy redundant. I've never known to be asked about the PE effect for anything other than nm wavelength light, it could be a typo in wherever the question came from and they did in fact mean nm? The whole question would make more sense if this was the case... :D
Electromagnetic radiation with a wavelength of 180mm would be described as microwave, not ultraviolet! Suspect a typo.
I agree, it does making asking about the kinetic energy redundant - I think it is a typo..
Many thanks for all your help on this one.
  • · Replies 25 ·
  • · Replies 35 ·
