Photon entanglement: why three angles?
185 replies · 15K views
Jabbu said:
To be more specific instead of hypothetical piece of paper it's better to attribute hidden variables as properties of actual entities, in this case photons and polarizers.
But that would be a silly thing to do. We know that the classical theory of polarization cannot explain the results of the EPR experiment for entangled photons. We already know that. Malus' law does not describe the situation. That's completely clear.
The issue is whether some other law describes the EPR experiment in terms of local interactions. That's the question that Bell was interested int.
I don't know why you keep bringing up Malus' law. We know that Malus' law doesn't work in the case of entangled photons.
Then it's easier to realize real conditions these variables have to satisfy. So to answer your question, unless the paper says "cos^2(theta)" it would be refuted by every other experiment with known relative polarization different than 45 degrees.
In the case of entangled photons, there is no polarization angle of the photons. It's completely unknown. QM actually says that the photons don't have a polarization.
As I said, you keep bringing up Malus' law when it has nothing to do with the argument that is being made. If you don't know the polarization angles, then you can't apply Malus' law.
What you can do is to assume that there is some variable associated with the pair of photons that determines whether it is absorbed or transmitted by a polarizing filter. In the case of a single polarization angle, that is possible. In the case of 3 different possible angles, it is not possible.
You ask a question: Why 3 angles. Then you don't pay any attention to the answer. It's very frustrating.
Jabbu said:
1. How else do you compare experimental results with classical physics prediction?
2. I'm talking to RUTA. See the paper he posted, or please ask specific questions about whatever it is unclear to you.
1. There are no classical predictions for entanglement. There is no such thing as entanglement in the classical world. EPR (1935). We have discussed this in the other threads that are now closed. In this thread, I showed you in great detail how any classical attempt to achieve the entangled state statistics would fail. Rather than stop there, you have kept on and wasted the time of others.
2. No, you are arguing with RUTA, me, atyy, Nugatory, bhobba, stevendaryl and probably a few others. I am sorry, but you are going around in circles again and clearly have no question out on the table to get answered.
atyy said:
Bell's theorem can also rule out any modification of the classical laws that are local, so it doesn't just rule out Malus's Law acting on classical photon pairs, but all local alternatives.
Yes, and look at it from the other side. As much as the inequality sets the boundaries from one side, so do classical physics laws set their own limits on the other side, as usual. The hidden variable is in a very tight spot, it has to sneak in between the both, and it doesn't really make sense to suggest local theories if they describe reality more bizarre than non-locality itself.
Nonetheless, if you would like to try to see if how close Malus's Law and classical photon pairs can come to mimicking the quantum entangled pairs, you can try this. First consider that each side receives 50% vertical and 50% horizontal photons, and that when their polarizers are both vertical, both sides always get the same result. In this case, you can imagine that this result is obtained because the classical source sends out 50% classical pairs with both photons are vertically polarized, and 50% classical pairs with both photons horizontally polarized.
The paper posted by RUTA says this:
- "In each pair, the signal and idler photon have the same polarization Ls = Li = L. As successive pairs are produced, L changes in an unpredictable manner that uniformly covers the whole range of possible polarizations. The quantity L is the ‘‘hidden variable,’’ a piece of information that is absent from quantum mechanics."
It seems L (lambda) directly corresponds only to unknown photon polarization, and since they say it uniformly covers the whole range, that should be the same as unpolarized light. Malus can make predictions only if photon polarization relative to the polarizer is known, or known to be uniformly random, as the paper suggest, in which case the probability is 50-50% as you said. That's 0% correlation for any Alice and Bob polarizer settings. Classically then, there is simply no reason for two separate uniformly random events to be correlated, at all.
Jabbu said:
But if you insist your hidden variable can fake experimental results for a single theta setting, then you need to realize S = E(a,b) - E(a,b') + E(a',b) + E(a',b') is defined by independent results of four separate theta settings from four separate experiments. Therefore, if your hidden variable can fake each of those experiments individually it will automatically fake the value of S.
No, that's not true. I'm getting very frustrated with you, because you keep asking questions, and don't seem interested in the answers.
Let me try one more time to see if I can explain to you why 4 angles (or 3) makes a difference.
We can come up with a hidden-variables model that reproduces the QM predictions for angles [itex]a[/itex] and [itex]b[/itex]. We can come up with a DIFFERENT model that reproduces the predictions for angles [itex]a[/itex] and [itex]b'[/itex]. We can come up with a third model that reproduces the predictions for angles [itex]a'[/itex] and [itex]b[/itex]. We can come up with a fourth model that reproduces the predictions for [itex]a'[/itex] and [itex]b'[/itex].
What we can't do is to come up with a SINGLE[/itex] model that works in all 4 cases. That's the point! There is no way to combine the 4 models into one.
The way that a hidden-variables model of EPR would work is the following:
  1. When the pair of photons is created, there is some hidden information [itex]\lambda[/itex] associated with each photon. This extra information is NOT polarization angle, because it's easy to see that Malus' law is not sufficient to explain EPR.
  2. When Alice's photon reaches her filter, her filter is at some angle [itex]\theta_A[/itex].
  3. We assume that whether it passes or not is a function: [itex]f_A(\lambda, \theta_A)[/itex] that depends on both the extra information in the photon, [itex]\lambda[/itex], and on the angle of Alice's filter, [itex]\theta_A[/itex]. The function [itex]f_A[/itex] returns either [itex]+1[/itex] (meaning the photon passes) or [itex]-1[/itex] (meaning the photon is blocked).
  4. Similarly, when Bob's photon reaches his filter, whether it passes or not is dependent on a different function [itex]f_B(\lambda, \theta_B)[/itex]
The point is that the hidden variable [itex]\lambda[/itex] has to be chosen BEFORE[/itex] it is known what angles Alice and Bob will choose. That makes it a lot harder. If Alice and Bob's angles are known ahead of time, then it's easy to come up with a [itex]\lambda[/itex] that works.
That's why multiple angles is harder: You have to choose [itex]\lambda[/itex] that works with any possible choice made by Alice and Bob.
DrChinese said:
...and clearly have no question out on the table to get answered.
We are not going in circles, we came all the way to talk about these two equations:
E(a,b) = Pvv(a,b) + Phh(a,b) - Pvh(a,b) - Phv(a,b)
My questions are clearly marked with question marks: - So how cos^2(theta) fits in? When a= -30 and b= +30 QM predicts correlation = cos^2(60) = 25%, right? So isn't E(-30,30) supposed to be that same "correlation" value?
No, [itex]E(a,b)[/itex] is defined to be (you've got the definition right there):
[itex]E(a,b) = P_{vv}(a,b) +P_{hh}(a,b) - P_{hv}(a,b) - P_{hv}(a,b)[/itex]
The relationship with [itex]cos^2(\theta)[/itex] is this:
[itex]P_{vv}(a,b) +P_{hh}(a,b) = cos^2(a - b)[/itex]
[itex]P_{vh}(a,b) +P_{hv}(a,b) = 1 - cos^2(a - b) = sin^2(a-b)[/itex]
So [itex]E(a,b) = cos^2(a-b) - sin^2(a-b)[/itex]
"Bizarre" is a matter of taste. Also, maybe one day quantum mechanics will be falsified, and we will have to look for a new theory. Bell's theorem says that even if one finds quantum mechanics too bizarre, or if quantum mechanics is experimentally falsified, the theory that replaces quantum mechanics must also be nonlocal. (Caveat: there remain a couple of loopholes in the experimental implementations of the Bell tests.)
In that paper http://arxiv.org/abs/quant-ph/0205171, the local hidden variable theory they propose does not assume Malus's Law, instead they replace it with their own law (Eq 18), because they want to propose a local hidden variable theory that achieves the limit allowed by one of the Bell inequalities (Eq 22). If we used Malus's Law (instead of Eq 18), then we would have PV(γ,λ) = cos2(γ-λ). When I put Malus's Law into their Eq 19 for both polarizers vertically oriented, I get PVV(0,0) = 3/8. If there were no correlation between Alice and Bob, then I would expect PVV(0,0) = 1/4. I'm not sure I did that right, but it seems that with their local hidden variable theory does produce more than 0% correlation between Alice and Bob. This correlation is due to a local hidden variable, which is built in at the source - although the polarization of the photons is random, both photons in each pair have the same correlation.
Jabbu said:
I'm talking about those terms in equation 20, in an experiment they are not calculate but counted.
Yes, there are coincidence counts for data in the next part of the paper, but I didn't see that what you wrote had anything to do with experimental data of that type.
Jabbu said:
If by "cos2(x)" you don't mean to say "cos^2(x)" I think 2 should go inside brackets like this "cos(2x)".
I meant cos(2x) per the trig identity I showed you.
Jabbu said:
Ok. So how cos^2(theta) fits in? When a= -30 and b= +30 QM predicts correlation = cos^2(60) = 25%, right? So isn't E(-30,30) supposed to be that same "correlation" value?
No, you're confusing PVV with E.
That doesn't answer why would they test 4 cases in the same experiment, instead of individually in four separate experiments.
Let so called "Bell test angles" be known ahead of time: 0°, 45°, 22.5° and 67.5°. How that makes it any easier to come up with a single [itex]\lambda[/itex] function that works for each combination: E(a,b), E(a,b'), E(a',b), and E(a',b')? What time has to do with any of it?
We're comparing coincidence rates at various angles. Thus we need a setup that gives us a series of measurements in which everything is the same except the angles. The most practical way of doing that is to run one experiment in which only the angle varies.
it doesn't, and that's why we use multiple angles. It's easy to come up with a ##\lambda## function that matches the quantum mechanical prediction if we know the two angles that any given photon pair will encounter, but impossible if we only know up front that the pair will encounter some combination of two of those four angles.
If you know the angles ahead of time, it is easy to reproduce the predicted correlations using a local hidden-variables model.
If you know ahead of time that Alice's filter is set at angle [itex]a[/itex] and Bob's filter is set at angle [itex]b[/itex], then a model that reproduces the predictions of QM is the following:
  1. With probability [itex]\frac{1}{2} cos^2(a-b)[/itex], send a photon to Alice that is polarized at angle [itex]a[/itex], and send a photon to Bob that is polarized at angle [itex]b[/itex].
  2. With probability [itex]\frac{1}{2} cos^2(a-b)[/itex], send a photon to Alice that is polarized at angle [itex]a+90^o[/itex], and send a photon to Bob that is polarized at angle [itex]b+90^o[/itex].
  3. With probability [itex]\frac{1}{2} sin^2(a-b)[/itex], send a photon to Alice that is polarized at angle [itex]a[/itex], and send a photon to Bob that is polarized at angle [itex]b+90^o[/itex].
  4. With probability [itex]\frac{1}{2} sin^2(a-b)[/itex], send a photon to Alice that is polarized at angle [itex]a+90^o[/itex], and send a photon to Bob that is polarized at angle [itex]b[/itex].
We can independently verify that if a filter is aligned in the same direction as polarized light, then it passes 100% of the time, and if it is aligned at a 90 degree angle, relative to the polarized light, then it is blocked 100% of the time.
This trivial model reproduces exactly the predictions of QM for the twin-photon EPR experiment.
It's clear that the model could not work if you don't know Alice's and Bob's filter orientations ahead of time.
What is the point of randomly switching angles and taking measurements "simultaneously" little by little, instead of to test each angle completely and separately one after another?
In the Bell inequalities, it is assumed (1) that Bob's result only depends on his choice and the local hidden variables, and it is also assumed (2) that Bob's result cannot depend on Alice's choice. The idea behind making the choices randomly at each side is that the choice is only made at the "last moment" before the the result is obtained, so that if we assume that the speed of light is an upper limit to the speed of communication, Alice's choice cannot be communicated in time to Bob to affect his result.
There is nothing wrong with that. Most Bell tests do just that.
The purpose of those that do fast switching is to demonstrate that there is no additional sub-lightspeed action in play that might affect the results. But we already know that from experiments such as Weihs et al, so that is no longer relevant. atyy's post above covers this issue.
Those are four different functions. As you said the whole point is to come up with a single model, can you do that?
You can not use (a-b) for a local hidden variable, that's exactly what makes QM equations nonlocal. In local reality properties and interaction of photon B and polarizer B are of no consequence to photon A and polarizer A, and vice versa. For local reality a hidden variable must fit a single function that applies separately to each side.
For each photon pair:
[itex]\lambda(photon_A, polarizer_A) = V|H[/itex]
[itex]\lambda(photon_B, polarizer_B) = V|H[/itex]
...which integrated over many pairs sums up to yield:
[itex]VV + HH - VH - HV = cos^2(A-B) - sin^2(A-B)[/itex]
It's not 4 different functions, it's 4 different values for the hidden variable [itex]\lambda[/itex]. If [itex]\lambda = \lambda_1[/itex], both Alice's and Bob's photons pass their filters. This value is chosen with probability [itex]\frac{1}{2} cos^2(a-b)[/itex], etc.
That was the point I was making. If [itex]a[/itex] and [itex]b[/itex] are known ahead of time, then there is nothing nonlocal involved in taking those values into account. It only becomes nonlocal if you allow Alice and Bob to choose [itex]a[/itex] and [itex]b[/itex] while the photons are in flight.
I should say: If the values of [itex]a[/itex] and [itex]b[/itex] are known ahead of time, it's not necessarily nonlocal.
FTL question is addressed by placing the two polarizers far enough apart so the time difference between when "signal" and "idler" photon meet with their polarizers is less than the speed of light would require to go from one to the other.
Let signal photon A go vertical through polarizer A at time t= 0. Let idler photon B be one light year away from photon A and one meter away from polarizer B at time t= 0. Photon B now has to assume the same polarization as photon A before it meets with polarizer B, that's the trick regarding FTL. But what angle polarizer B is set to, and when, is of no consequence to this speed of correlation/information between photon A and photon B.
Proposing different models for each angle is invalid to begin with. Plus, you can not use (a-b) to define a hidden local variable. It does not qualify, it does not compare.
Angles are always known and deliberately chosen ahead of time. Are you saying there is some difference if we randomly switch angles and take measurements "simultaneously" little by little, instead of to test each angle completely and separately one after another?
Take a look at stevendaryl's post #71. If the settings are known ahead of time, then his variable (a-b) can be a local hidden variable, ie. although (a-b) is associated with distant apparatuses, there's plenty of time to propagate the detector settings back to the source.
Sigh. You're coming into the middle of a long discussion, and your points are not relevant to the particular point I was discussing. If the order of the events is the following:
(I'm saying IF it takes place in the following way---I'm not saying that it does, and I'm not
saying that Bell allowed for it, or whatever. This is simply a hypothetical explanation for a particular thought experiment.)
  1. Alice chooses her filter angle [itex]a[/itex]
  2. Bob chooses his filter angle [itex]b[/itex]
  3. A hidden variable [itex]\lambda[/itex] is generated taking into account [itex]a[/itex] and [itex]b[/itex].
  4. A pair of photons is generated that somehow encode this value
  5. Whether Alice's photon passes or not is a deterministic function of [itex]\lambda[/itex] and [itex]a[/itex]
  6. Whether Bob's photon passes or not is a deterministic function of [itex]\lambda[/itex] and [itex]b[/itex].
My claim is that it is possible to implement the above scenario, using local hidden variables, in a way that reproduces the predictions of quantum mechanics. If the choice of [itex]\lambda[/itex] depends on the settings [itex]a[/itex] and [itex]b[/itex], then there is no proof of nonlocality (or nonrealism, or whatever it is that Bell's theorem talks about).
To get Bell's proof to go through, you have to assume that the hidden variable [itex]\lambda[/itex] is NOT dependent on Alice's and Bob's filter settings. If you don't make that assumption, then there is certainly a local hidden-variables explanation.
If the settings are chosen ahead of time, then that leaves a loophole for local hidden variables theories. It might not be a plausible loophole, but it's a loophole.
johana,
Just to make sure everyone is on the same page: no one is arguing that it makes a difference if there is fast switching or not. However, that is something we know now that was not known 100% prior to experiment (Aspect, Weihs, etc.). If you want to rule out a local action so that the settings A and B are provably independent, use fast switching. So stevendaryl is simply saying that a local realistic model was technically viable prior to that because there might be time for subluminal communication from one measuring device to the other (crazy as it seems). But now we know better.
DrChinese said:
johana,
Exactly. Thanks.
Yes, loophole. But what loophole are you talking about? FTL loophole is addressed by separating polarizers far enough apart relative to the time interval between when signal and idler photon are supposed to meet with their polarizers. It works for any individual angle when tested separately, so that's not it.
time0: photons A & B emitted with unknown/undefined polarization
time1: photon A goes through 0° polarizer A and acquires 0° polarization
time2: photon B acquires 0° polarization, for some reason ( time1 = time2 ?? )
time3: photon B with 0° polarization interacts with 0° polarizer B, so it too goes throughNow, if polarizer B was at 90° and switched to 0° just a moment before time3, what difference does it make?
johana said:
Now, if polarizer B was at 90° just a moment before time3, what difference does it make?
Not much. But suppose that polarizer A was at 90° until just a moment before ##t1##... In fact, for such a short moment that both ##t2## and ##t3## have come and gone before a light signal from polarizer A's flip to 0 degrees could have reached photon B... That makes B's flip to zero much harder to explain.
It is accepted by both sides time2 is less than time3, otherwise causality would be acting backwards in time, and that's not really kind of thing local realists are hoping for. Each subsequent time is greater or equal to previous time:
->time0.7: polarizer A set to 45°
->time0.8: polarizer B set to 90°
time0.9: polarizer A set to 0°
->time1.7: polarizer A set to 15°
->time1.8: polarizer B set to 75°
->time2.7: polarizer A set to 90°
->time2.8: polarizer B set to 45°
time2.9: polarizer B set to 0°
Please note those time events marked with arrows, are they anyhow relevant to what happens at time1, time2, or time3?
Isn't it when the photon is detected by an apparatus, it is then that the system takes on the polarisation of the polariser?
atyy said:
To add to Nugatory's point, you can read more discussion of the issue in:
http://physics.aps.org/synopsis-for/10.1103/PhysRevLett.105.250404
http://arxiv.org/abs/1007.5518
http://arxiv.org/abs/1008.3612
http://arxiv.org/abs/1303.2849 (section B.2 "Locality loophole")
They do talk about it, but they don't explain it. Try to answer the question in your own words, with a sentence or two, and maybe you'll see the same paradox I see. Or maybe you'll see an explanation, that's even better.
