Photons emitted from a light bulb problem
fishh
A 100 W incandescent light bulb converts approximately 2.5% of the electrical energy supplied to it into visible light. Assume that the average wavelength of the emitted light is λ = 530 nm, and that the light is radiated uniformily in all directions. How many photons per second, N, would enter an aperture of area A = 3 cm2 located a distance D = 6 m from the light bulb?
https://online-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?courses/phys214/fall08/homework/03/photons/05.05.gif
Energy of photon = h x c / lambda (wavelength)
Power = change in energy / change in time
Surface area of sphere = 4πr
I basically used the formula above to calculate the energy of the photons being emitted:
E = 1240 eV nm / 530 nm = 2.3396 eVm
The total power emitted by the light bulb should be 2.5% of what is put in - 2.5 watts. I know that if I have a sphere of radius 6m, the surface should "pick up" all of the power emitted. Therefore, I can set up a ratio of W/m2 : 2.5 / (4π x 6) W/m2 (not sure if this is a valid reasoning, because the aperture is not necessarily curved). Since the element(aperture) I am looking at is 3 cm2 :
Power through element = 2.5 / (4π x 6) x 0.0003m2 = 9.947183943 x 10-6 W
This power should be equal to the number of photons per second (n) multiplied by the energy of one photon, simply because both quantities represent the energy per second.
9.947183943 x 10-6 W = n x (2.3396 eV x 1.602 x 10-19 J / eV)
n = 2.653970093 x 1013 photons per second
When I enter this answer (the homework is online), it is wrong. I'm pretty sure the problem lies with how I found the power through the aperture; I'm not sure what is wrong.
on Phys.org
The fraction of light that enters the aperture is the area of the hole 3cm^2/the area of the sphere (2*pi*600*600) be careful to tuse the same units for radius and area.
Surface area of a sphere is 4*Pi*r^2 not 4*Pi*r. I am in the same physics class at UIUC as you and i was able to get the correct solution with this method.
Thanks, I got the right answer using 4 pi r^2. I guess I should review my geometry...
