Photons - the smallest building block?
The discussion revolves around the idea of whether photons could be the fundamental building blocks of all matter, including quarks and electrons, and if fundamental forces could also be manifestations of photons. Participants explore the implications of this hypothesis, including the nature of mass, charge, and the behavior of particles at high energies.
  • Some participants propose that everything, including quarks and electrons, could be made up of photons of varying wavelengths that group together to form mass under certain conditions.
  • Others argue that photons, as they are understood, cannot account for properties such as mass and charge, and that particles are not fundamental but rather excitations of quantum fields.
  • A participant mentions that while photons can transform into particle-antiparticle pairs, this does not imply that particles are made of photons, as conservation laws must be considered.
  • There is a suggestion that massive particles might be seen as a way of packaging energy, as indicated by the equation E=mc², but photons alone do not explain the additional properties of massive particles.
  • Some participants discuss the idea of modeling a binary photon system, but express concerns that such models would involve distances smaller than a Planck Length, where current laws of physics may not apply.
  • One participant speculates that photons could bind together through constructive interference or other mechanisms, but acknowledges the need for experimental data to support such ideas.
Participants express a range of views, with no consensus reached on the idea that photons could be the fundamental building blocks of matter. There are competing perspectives on the nature of particles and the role of photons in fundamental physics.
Limitations include unresolved questions about the nature of mass, charge, and the fundamental properties of particles. The discussion reflects a variety of assumptions and interpretations regarding quantum mechanics and particle physics.
Raap
Forgive my ignorance if I'm missing something obvious; although I try to stay informed my interest in physics is rather casual. However, I do like to think and speculate about such things based on the knowledge I already have.
So with this in mind, I thought I'd just get some feedback on some of these thoughts. What I'd like to know is if there is anything that dismisses the possibility that everything, quarks, electrons, etc., could be made up of photons of varying wavelengths, that when certain conditions are met photons will group together to form what we know as 'mass'.
Taking this further, I'd like to know if it is possible that even the fundamental forces could actually be photons; perhaps of such wavelength and properties that we cannot ( yet ) perceive of them?
Any thoughts on this? Is there anything that contradicts this completely?
Well, these "properties we cannot ( yet ) perceive" would mean that the fundamental particles aren't photons as we know them.
Physicists tend to like models which simplify things, and having a zoo of particles be different excitations of a single particle is appealing. However, we know that particles themselves aren't fundamental and that quantum field are the fundamental entities. Particles are only seen because we build particle detectors =)
This may not be up your alley, but two places where different particles emerge from a single entity is a) string theory, as vibrational modes of the string, and b) supergravity, as components of a superfield.
But these are only theories. It's up to experiments to decide.
Since photons travel at the speed of light and mass does not, it is not clear how the photons could be given inertia. Also, where would charge come from, since photons have no charge?
You might be able to classically model a binary photon "system" orbiting around one another like a binary star, but I believe the distances would be much smaller than a Planck Length and therefore the laws of gravity would break down.
Also, one of the fundamental forces is electromagnetism, whose carrier is the VIRTUAL photon, but it's not a real photon. It's not like we detect photons emanating from electrons and call that charge. So there's no reason to think that any of the forces, let alone all of them, are really just photons being exchanged.
But it was my understanding that when, for instance, an electron and a positron collided, they would actually "transform" into photons. I suppose then that the reverse is also possible? Meaning something without a charge, photons, could be made into something with a charge?
As for the 'why doesn't mass then travel at light speed' thing, couldn't that simply have to do with the photons being tied to each other? Let's say a stationary particle consisted of 10 photons. 5 of those had momentum in direction x, the other 5 had momentum in direction y - exact opposite of direction x. So you add another photon with momentum in direction x and the whole thing starts moving in that direction. You add another and it moves even faster. Add more and more and it goes faster and faster in that direction; however, you will never quite reach c because there will always be those 5 other photons with momentum in the other direction.
A major, major problem with photons is that they have no electric charge. Also there's no way any number of photons can make a spin 1/2 electron.
Interesting question? Of course.
Regards,
Reilly Atkinson
Pair production, i.e. where photons become particle-antiparticle pairs, does not necessarily mean that one is made up of the other. All that says is that one can be converted into the other. A photon alone cannot turn into an electron because of conservation laws. So already you can see that one simply cannot say that an electron is made up of photons.
Zz.
well, it is convenient to say that massive particles are just nature's way of packaging energy in greater quantities, and the basic equation E=mc^2 certainly indicates that any mass can be equally correctly designated as its equivalent amount of energy (photons). that said, photons alone do not account for the other properties we recognize in particles which have mass, such as charge. it is not clear where these additional properties arise, but the comment above seems correct to me, that it is actually fields, rather than particles, which are the fundamental entity. now, if we could just figure out what a field is...
It's conceivable photons of constructively interfering wavelengths, properties, or some other ad hoc mechanism would allow for photon binding. Intuitively signs point to the photon as a fundamental constituent of nature. I suppose all we can do is wait for experimental data.
As I understand immediately proceeding the big bang photons 'decayed' into elementary particles. I also understand throwing sufficient energy into the vacuum will generate particles.
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 58 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 46 ·
