Physic (kinematics) — Displacement of an accelerating car
7 replies · 3K views
Liszzy
Member has been warned not to delete the template.
Question: A car accelerates from rest at a rate of 2.0m/s^2 [N]. What is the displacement of the car at t=15s?
I tried
(2m/s^2 [N])(15s)=30m/s [N]
(30m/s [N])(15s)
=450m [N] but guess wrong :(
*Because the answer is 230m [N]
How to solve this? anyone
I tried
(30m/s [N])(15s)
So what you did was the following. First: ##v=at##, then: ##s=vt##.
In universities, when they teach this subject. They usually derive a set of equations before doing such a problem. But, since you did what you did, for now, where do you think your mistake is? Is ##s=vt## all the time?
Hint: we know that the actual equation is ##v=\frac{ds}{dt}## ||| ##a=\frac{dv}{dt}## (the second won't be really necessary, but you can use it)
You used the final speed for 15 sec.
You might ask "What was the average speed during those 15 sec.?"
I tried
(30m/s [N])(15s)
I think that your line of reasoning implies that the displacement is linear to time. However, since there exists an acceleration a, then the distance traveled at one moment in time is different than the distance traveled in the next moment. There are three equations you should think of when you are considering kinematics. For this problem, you should consider this equation.
s = si + vit + ½(a)(Δt)2
I tried
(30m/s [N])(15s)
Do you have a textbook? Does it solve similar problems?
I tried
(30m/s [N])(15s)
The answer should not be 230m - it should be 2.3 x 10^2 m
The numeric answer is 225, but, should be expressed to 2 significant figures due to the precision in the supplied information.
