Physical meaning of Laplace transform
In summary, the Laplace transform is an analytical extension of the Fourier transform which is used to transform a function from time domain to frequency domain. The Fourier transform can be thought of as the limiting case of the Fourier Series, where the original x(t) is truncated and periodically extended so that x_T(t) = x_T(t-nT). The fundamental Fourier transform pair is \delta(t) and 1, indicating that the spectrum contains sinusoids of all frequencies. The fundamental Laplace transform pair is H(t), the Heaviside step function, and 1/s, its spectrum of damped sinusoids.
pixel01
688
Hi every body,
I am not so sure this kind of question is suitable here. In styding maths, I have some difficulties with the Laplace transform. The formulas are OK, I can apply them, but I still do not understand the physics meaning behind that. Can anyone can explain to me a little bit more abou this. Thanks
pixel01 said:
Hi every body,
Well I have a math degree, and I still couldn't tell you what the physical meaning of the Laplace Transform is. I don't think there is any. But maybe this will help: the Laplace Transform transforms a function into an entirely new variable space (traditionally called s). Since derivatives of all orders are eliminated, this turns a calculus problem into an algebra problem.
I realize this answer is insufficient, but I'm not sure there exists any good answer to your question. We physics people often get the idea that math was invented by physicists and for physicists, and that every mathematical idea has some physical basis. But I can't think of any obvious physical analogy for an integral transform.
pixel01 said:
Hi every body,
are you good with the Fourier Transform? the Laplace Transform is an "analytical extension" of the Fourier Transform. and the Fourier Transform can be thought of the limiting case of the Fourier Series where the original [itex]x(t)[/itex] is truncated and periodically extended so that:
[tex] x_T(t) = x_T(t-nT) \ \ \ \forall \ \ \mathrm{integer} \ \ n [/tex]
and
[tex] x_T(t) = x(t) \ \ \ \mathrm{for} \ \ |t|< \frac{T}{2} [/tex]
and, in the limit, [itex] T \rightarrow \infty [/itex].
if you have this Fourier Series down solid, and then get an understanding of how the Fourier Transform generalizes the Fourier Series (to non-periodic [itex]x(t)[/itex]), then generalizing further to the (bilateral) Laplace Transform is a cake walk.
Because
[tex]s=\sigma + i\omega[/tex]
the Laplace kernel exp(-st) is more general than the Fourier kernel. Laplace transforms can readily handle dissipative systems; [tex]\omega[/tex] gives the angular frequency, and [tex]\sigma[/tex] the time constant, of a damped sinusoid.
The fundamental Fourier transform pair is [tex]\delta(t)[/tex] an infinite impulse excitation, and 1, indicating that the spectrum contains sinusoids of all frequencies. The fundamental Laplace transform pair is H(t), the Heaviside step function, and 1/s, its spectrum of damped sinusoids. Note that the spectrum is weighted towards low frequencies (1/abs(s) goes to zero as abs(s) goes to infinity), as one would expect for an excitation that begins but is never turned off.
Likes prasad
marcusl said:
Because
I barely remember any of it, but in the dim past I recall having to learn about LaPlace transforms for a course in "Feedback and Control Systems". We would be figuring out the critical damping for things like robot arms, where the object was to get the arm into some new position as quickly as possible, yet slow it down as it approaches the end position in such a way that it doesn't overshoot. Then build the electronic circuit that controlled the servomotor. What a nightmare that was.
Thank you all for reply the thread. I think I ve got to read more about this and hope come back to this topic not very long.
pixel01 said:
Hi every body,
From what I know, the Laplace transform let's you transform something from time domain to frequency domain. Doing this allows you to look at the behavior of that something (signal, circuit, etc.) in terms of freqency.
I hope this helped.
i think the thread is pretty stale, but i thought the OP's question was more about whether the Laplace Transform of a function (say a function of time) that represents a physical quantity that varies in time (a physical "process", let's call it "x(t)"), if the value of the X(s) for some complex value of s represents a physical quantity that is some component of "x(t)". it can be answered more clearly if they OP was asking about the continuous Fourier Transform, of which L.T. is a generalization of that. i suppose there is an icky answer to the question by considering the closed-form expression of the inverse Laplace Transform with some fixed values of [itex]\mathrm{Re} \left\{ s \right\} [/itex]. but it's an icky answer.
Well, in my opinion, there is no clear physical meaning of Laplace transform. Laplace transform is introduced as a utility tool to solve differential eqations more easily. As you know every dynamic behavior can be described as a set of differential equations. System's behavior is often described with set of linear differential equations with constant coefficients (linear systems or approximation of nonlinear systems).
Also Laplace transform is used to describe linear systems (relationship between input and output) in control theory.
On the other hand,
Fourier transform have physical meaning. If you apply Fourier transform to some signal x(t), you'll get that its frequency domain, i.e. picture of signal in frequency domain (base and higher harmonics).
It's easy to see the "physical meaning" of time-domain differential equations, because you have been using algebraic variables to represent time, velocity, etc for many years already.
The s-plane (and the z-plane for digital signals) are just as "physically real", once you get familiar with them. Having different ways of looking at the same physical system is very valuable. If you use the s-plane for long enough, it becomes just as "real" as Euclidean space or Relativistic space-time.
Micko, The Fourier transformation is a bit simpler than the Laplace, but I don't see how you can claim that the frequency domain has a physical interpretation, but the s-plane does not. The imaginary axis in the s-plane IS the frequency domain!
However since you said "base and higher harmonics", perhaps you are only thinking about Fourier transformations of periodic functions? Or, you are confusing "Fourier Analysis" of periodic functions with "the Fourier Transform", which can be also used with non-periodic functions?
Well, I'm not confusing Fourier transforms for periodic and aperiodic signals. I wasn't enough precise.
If signal is periodic, then Fourier transform becomes Fourier series (base and higher harmonics). For me, Fourier transform in contrast to Laplace has physical meaning because frequency response methods of analyzing systems are relying on Fourier transform. When system is described with Fourier transform it's easier to see how it is behaved (for example as low pass filter).
If for example I do Fourier transform of periodic (say rectangular) signal I can immediately see how this picture looks like in frequency domain, i.e. what are amplitudes of harmonics and similar...
The Laplace transform have physical meaning.
The Fourier transform analyzes the signal in terms of sinosoids, but the Laplace transform analyzes the signal in terms of sinousoids and exponentials.
Traveling along a vertical line in the s-plane reveal frequency content of the signal weighted by exponential function with exponent defined by the constant real axe value.
Traveling along a horisontal line reveal the exponential content of the signal weighted by sinousoids function with frequency defined by the constant imaginary axe value.
In particular, traveling along the imaginaly axe reveal frequency content of the signal weighted by 1 which is equivalent to the Fourier transform of the signal.
abj
1. What is the Laplace transform and why is it important in science?
The Laplace transform is a mathematical tool used to convert a function from the time domain to the frequency domain. It is important in science because it allows us to analyze and understand complex systems and phenomena by transforming them into simpler equations that can be solved using algebraic methods.
2. How does the Laplace transform relate to differential equations?
The Laplace transform is closely related to differential equations because it can be used to solve them. By transforming a differential equation into an algebraic equation, we can easily find a solution and then transform it back to the time domain. This allows us to solve differential equations that would otherwise be difficult or impossible to solve using traditional methods.
3. Can you provide an example of a real-world application of the Laplace transform?
One example of a real-world application of the Laplace transform is in electronic circuit analysis. By using the Laplace transform, we can analyze the behavior of circuits in the frequency domain, which is useful for designing and troubleshooting electronic devices.
4. What is the physical meaning of the Laplace transform?
The physical meaning of the Laplace transform is that it represents the frequency content of a function. In other words, it shows how much of a function is made up of different frequencies. This information can be used to understand and predict the behavior of systems and phenomena.
5. Is the Laplace transform only used in physics or does it have applications in other fields?
The Laplace transform is used in a variety of fields, including engineering, mathematics, economics, and biology. It is a versatile tool that can be applied to a wide range of problems, making it an essential tool in many scientific and technological fields.
  • Differential Equations
  • Electrical Engineering
9K
  • General Math
  • Other Physics Topics
