- 2,802
- 605
I've read that gauge invariance leads to a fundamental phenomenon.What is that?
Thanks
Thanks
The discussion centers on the physical significance of gauge invariance, particularly in the context of gauge theories and Noether's theorem. Participants clarify that gauge symmetries differ fundamentally from global symmetries, with gauge transformations representing redundancies in physical descriptions rather than true symmetries. The electromagnetic field exemplifies U(1) gauge symmetry, where configurations related by gauge transformations are physically identical. The conversation highlights the importance of understanding these distinctions to grasp the implications of gauge invariance in modern physics.
PREREQUISITESPhysicists, particularly those specializing in theoretical and particle physics, as well as students seeking to deepen their understanding of gauge invariance and its implications in modern physics.
it is a very broad field now.see hereShyan said:I've read that gauge invariance leads to a fundamental phenomenon.What is that?
Thanks
LastOneStanding said:algebrat, that answer is totally wrong. Gauge symmetries are fundamentally different from global symmetries, not just a name we use for symmetries when associated with particle physics. Spatial translation is definitely not a gauge transformation.
Shyan, generally speaking gauge symmetries don't have a conserved current associated with them because Noether's theorem applies to global symmetries. A Gauge symmetry is sort of the opposite of physically significant: it means part of our description is not physically significant and hence can be changed (even locally) while describing the same physical situation. That said, a gauge symmetry will generally have a global symmetry as a special case of it, in which you are actually looking at a different physical configuration. For instance, the electromagnetic field has U(1) gauge symmetry. This means that, in general, you can do a different U(1) transformation at every spacetime point and still get the same physics. The EM gauge potential transforms under U(1) in the way you state above, and the way you become familiar in introductory EM classes when you first encounter gauge freedom. If you do the same U(1) transformation at every point, you're actually doing a global transformation—which, by Noether's theorem, corresponds to conservation of charge.
The physical significance of gauge invariance is that two configurations that are related by a gauge transformations are the exact same configuration—they don't just behave the same way as with global symmetries, they are physically the same.
Shyan said:So you say two configurations A and B are the same if they are related by a gauge transformation which is a symmetry of both of them and this has,as an special case,a global symmetry.
But the statement that A and B treat the same way with respect to some aspects has as an special case the statement that A and B are the same.
Now if we apply your interpretation of gauge and global symmetries,we reach to the conclusion that gauge symmetry is a special case of global symmetry and also vice versa!
LastOneStanding said:The physical significance of gauge invariance is that two configurations that are related by a gauge transformations are the exact same configuration—they don't just behave the same way as with global symmetries, they are physically the same.
Yes, it is called interaction between matter fields and the gauge field.Shyan said:I've read that gauge invariance leads to a fundamental phenomenon.What is that?
Thanks
samalkhaiat said:Yes, it is called interaction between matter fields and the gauge field.
Sam
Sam is talking about local gauge invariance which leads to interaction between matter field and gauge field.it is the basis of modern treatment of gauge theory.Electromagnetism for example arises directly due to local gauge invariance.it comes from the work of yang and millsLastOneStanding said:I think maybe that's putting the cart before the horse a bit. Yes, imposing gauge invariance on a non-interacting theory turns it into an interacting theory but it's perfectly possible (in theory) to have an ungauged interacting theory to begin with. I think a better way of putting it is that imposing gauge invariance severely limits which interactions are possible. Maybe it's splitting hairs, but I wouldn't say, "We have gauge theories, therefore interactions," even if it's a formally valid logical statement. I would say, "We have interacting theories, and they are gauge invariant." But then, maybe I'm just looking at it from the historical perspective of how these theories were developed, rather the more natural perspective of what's fundamental to nature...hmm...
LastOneStanding said:I am well aware of how Yang-Mills theory works, which I think was pretty clear from my post since I described that exact process.
LastOneStanding said:[...]Maybe it's splitting hairs, but I wouldn't say, "We have gauge theories, therefore interactions," even if it's a formally valid logical statement. I would say, "We have interacting theories, and they are gauge invariant." [...]
Actually, what is gauged in the case of General Relativity is not the Lorentz group but the translation group. An infinitesimal coordinate transformation is a position-dependent translation*As a field theory, GR can be derived from gauging the global Lorentz symmetry of a flat-spacetime
So are they talking about Einstein-Cartan theory instead of GR??He [Utiyama] gauged the Lorentz group SO(1, 3), inter alia. Using some ad hoc assumptions, like the postulate of the symmetry of the connection, he was able to recover GR. This procedure is not completely satisfactory, as is also obvious from the fact that the conserved current, linked to the Lorentz group, is the angular momentum current. And this current alone cannot represent the source of gravity. Accordingly, it was soon pointed out by Sciama and Kibble (1961) that it is really the Poincare' group R4 ⊃× SO(1, 3), the semi-direct product of the translation and the Lorentz group, which underlies gravity. They found a slight generalization of GR, the so-called Einstein-Cartan theory (EC), which relates – in an Einsteinian manner – the mass-energy of matter to the curvature and – in a novel way – the material spin to the torsion of spacetime.
Bill_K said:[...]So are they talking about Einstein-Cartan theory instead of GR??
the_pulp said:Hi, I asked something like this in another thread and the idea I got from that was that if you want a Conservation Law you need a Global Symmetry in the Lagrangian. If you want that Conservation Law to be Local you need that Symmetry to be a Gauge Symmetry. Since this idea has not been precisely state in this thread, Id like to know if you agree with this or if you think that I am wrong.
I cannot see it.Can you be more specific.thanks.GR can be derived from gauging the global Lorentz symmetry of a flat-spacetime
andrien said:I cannot see it.Can you be more specific.thanks.
