Physics Current Problem (I1,I2,I3)
  • Thread starter Thread starter buddy72192
    Current Physics
The discussion focuses on calculating the currents I1, I2, and I3 in a circuit with given internal resistance for batteries. The user attempted to solve the equations derived from two loops but arrived at incorrect values. Another participant suggests that the results might be correct but could be affected by significant figures or unit issues. They also provide a link to Wolfram Alpha for verification of the equations. The conversation emphasizes the importance of careful calculation and unit consistency in solving circuit problems.
buddy72192
1. Determine the currents I1, I2, and I3 in the figure. Assume the internal resistance of each battery is 1.3 ohms.
2.What is the terminal voltage of the 6v battery?
Picture http://i945.photobucket.com/albums/ad291/buddy72192/GIANCOLIch19p32.jpg
Ok, so from what I can tell I1=I2+I3 for this equation.
I went around counterclockwise for both loops and came up with:
Loop #1
11.3I2 + 21.3I1 = 24
Loop #2
34.3I3 - 11.3I2 = -6
To get common I's I subbed (I1 - I2) in for I3
So Loop #2 becomes...
34.3I1 - 34.3I2 -11.3I2 = -6
When I solved for that I got (Incorrect)
I1=.755A
I2=.7A
I3=.055A
Please Help! I've been trying for over 2 hours
Loop #1
Loop #2
I1=.755A
I2=.7A
I3=.055A
Hi buddy72192, Welcome to Physics Forums.
As far as I can see your stated results look fine. Perhaps you have a significant figures or required units issue when entering the results?
  • · Replies 31 ·
