Physics dimensions of acceleration question
Acceleration is defined as the change in velocity over time, expressed mathematically as a = Δv/Δt. To find the dimensions of acceleration, one must first determine the dimensions of velocity, which is length (l) divided by time (t), resulting in dimensions of LT^{-1}. Since acceleration is the change in velocity over time, its dimensions can be calculated as LT^{-1} divided by T, leading to LT^{-2}. Therefore, the dimensions of acceleration are expressed as LT^{-2}.
ProBasket
i have a question from mastering physics(online site that i do my homework on) that i don't get.
Question: Find the dimensions [a] of acceleration.
Express your answer as powers of length (l), mass (m), and time (t).
and here's a small hint they give you for the equation for acceleration:
In physics, acceleration a is defined as the change in velocity in a certain time. This is shown by the a = \triangle v/\triangle t.. The \triangle is a symbol that means "the change in."
[a] = _______ (answer can only be expressed in l,m and/or t)
the change in v has same demension of v... same rule applied to t,too
yea, but the answer can only be in length (l), mass (m), and time (t).
what is the demension of v, then
got the answer, it's LT^{-2}
yup......
  • · Replies 26 ·
  • · Replies 17 ·
