Physics friction incline question
The problem involves two blocks, A and B, connected by a cord, with block A on an incline experiencing friction and block B on a frictionless surface. The scenario includes forces acting at angles, and the objective is to find various forces including tension and friction while the system moves at constant velocity.
  • Participants discuss the forces acting on both blocks, including tension, weight, normal forces, and friction. There is an emphasis on drawing free body diagrams and setting up equations based on the balance of forces due to the constant velocity condition.
Some participants have provided guidance on how to approach the problem, suggesting the use of free body diagrams and the relationship between the forces. However, there is a lack of consensus on the value of the friction coefficient, which remains a point of contention and inquiry.
Participants note the absence of the friction coefficient (µ) in the problem statement, leading to questions about the completeness of the problem and suggestions to clarify with the instructor.
Kevin1199959
Block B on a frictionless table top (1.5kg) is connected by a cord to block A (3.8kg) with friction on an incline of 40degrees above the horizontal.
Block B is being pulled at and angle 15degrees above the horizontal
Block A is moving up the incline at constant velocity.
Find Pulling force (on B at 15degrees), Tension in the cord, Friction and normal forces on A.
F=ma
F=uN
I found the X and Y components of block A, and i figured that Wx+Friction=F(on blobk B)
But i don't know how to find the rest.
TY in advance!
Welcome to PF!
HI Kevin1199959! Welcome to PF! :smile:
(have a mu: µ and a degree: ° :wink:)
(i assume there's a pulley, to keep the cord level?)
You mean Wx+Friction = tension (in the cord)?
ok, so there are four forces on block B: tension, weight, normal reaction force, and pulling force …
draw a free body diagram and solve …
what do you get? :smile:
(have a mu: µ and a degree: ° :wink:)(i assume there's a pulley, to keep the cord level?)
Lol, Thanks ;)
Umm, as i mentioned, there is a force pulling on block b at 15° above horizontal, and if the system is moving at constant velocity, (a=0) the opposite forces have to be equal. Therefore left (in my case, friction+Wx of block A) = Right (pull at 15° on block B).
If I am right, Tension-Friction-Wx= 0 (ma=0) for block A and Force(15°)-Tension=0(ma=0) for block B
Yes (if you mean Force*cos15°) …
now put in the values of Wx and Friction and solve. :smile:
Yeah, i didn't mean *15°, i was just saying that it's the force at 15°. Sry :P
But i don't have the value of friction... How can i solve it?
Usual way …
find the normal force, and multiply by µ :wink:
tiny-tim said:
Usual way …
find the normal force, and multiply by :wink:
But i don't have µ, I only have numbers that i gave in my first post...
ooh, I never noticed that! :biggrin:
You'd better call the friction "µ", and get an answer with µ in it. :smile:
(or email the professor … I assume it's a misprint!)
But it was a question on the test lol... Here, i took a picture of the question in case i missed something.
Thx!
hmm … I still think it's misprint! :redface:
It can't be... It was on the test and many people got it right
  • · Replies 19 ·
