Physics help- unsure where I went wrong
  • Thread starter Thread starter cpat
    Physics
The discussion focuses on solving two physics problems involving a metal bar and a rolling bowling ball. For the first problem, the user attempts to find the angular speed of the bar after being struck by a ball, using conservation of angular momentum, but struggles with calculation errors. They eventually arrive at an angular speed of approximately 5.71 rad/s after recalculating. The second problem involves determining the acceleration of a bowling ball rolling uphill and the minimum coefficient of static friction required to prevent slipping, with the user seeking advice on the correct approach. The suggestion is made to consider torque about the center of the sphere to relate angular and linear acceleration.
cpat
1. A thin, uniform, metal bar, 2.5 m long and weighing 90 N, is hanging vertically from the ceiling by a frictionless pivot. Suddenly it is struck 1.3 m below the ceiling by a small 4-kg ball, initially traveling horizontally at 14 m/s. The ball rebounds in the opposite direction with a speed of 7 m/s.
Part A. Find the angular speed of the bar just after the collision.
I tried to solve using conservation of angular momentum (it must be a calculation error but I keep getting the same answer):
m1v_0d = -m1vd +(1/3)m2L^2(omega)
(4.0kg)(14m/s)(1.3m) = -(3kg)(7m/s)(1.3m)+(1/3)(90N/9.82m/s)(2.5m)^2(omega)
72.8 = 57.398 + (-27.3)
1001.1 = 57.398
1.7439rad/s = \omega 2. A Ball Rolling Uphill. A bowling ball rolls without slipping up a ramp that slopes upward at an angle beta to the horizontal. Treat the ball as a uniform, solid sphere, ignoring the finger holes.
Part A. What is the acceleration of the center of mass of the ball?
I tried drawing it out, f = mew N, N = wsin(beta)
- (WsinF+ muWcos(beta) = macm
I entered acm = -g(sinF+mucos (beta)
It was incorrect, so I thought I over-did it, and tried just -g(sin(beta)), but that was also incorrect, I'm not sure where to go from here. Part B. What minimum coefficient of static friction is needed to prevent slipping?
I tried mu = tan (beta)
OK
You have
|r X P| = r*m*vi = r*m*(-vf) + I*ω
So r*m*(vi + vf) = 1.3*4*(14 + 7) = 1.3*4*21 = 109.2 = 1/3*90/9.8*L2
So then ...
ω = 109.2*9.8*3/(90*2.5*2.5) = ... ?
thanks!- I've got a calculator now (much easier! Mine stopped working last week so I've been borrowing from a friend), 5.70752.
Any tips on the next question?
For 2) consider the torque about the center of the solid sphere. That might yield "a" angular acceleration which you can then relate to linear acceleration along the incline.
12K
20K
  • · Replies 26 ·
14K
