Pion Detection: Finding a Film for Interference Experiment
  • Context: Undergrad
  • Thread starter Thread starter khelzor
    Detection Pion Pions
3 replies · 2K views
khelzor
I'm a student in high school asking for suggestions for an experiment proposal.
So far, our idea has been to recreate Young's interference experiment, but instead of using electrons, we will use a heavier particle. Charged pions have been the first choice so far. Aluminum is the current delegate for the material used to direct pions into the slits. Right now, we are searching for a film to be used to detect the interference patterns made by the pions.
Are there any materials available to detect pions?
If anyone can also answer if pion decay would become a major problem in our experiment, it would be a great help :) Thanks
A double-slit experiment with pions? What do you want to use as slit? Did you calculate how slow the pions have to be to see an interference pattern with any reasonable slit width? Where do you expect to get the slow pions from?
Yes, but you are starting with the completely wrong step.
If there is a test you can perform in 5 minutes that can show you if your idea is feasible, do it directly. Don't spend hours on some details if this simple test can show you that further work is pointless.
CERN has a pion source, yes: a source of fast pions. Calculate their de-Broglie wavelength, then see which slit diameter you'll need for interference. Compare this to the diameter of an atom, or the diameter of an atomic nucleus.
This is very good advice.
If you want to win this competition, you are going to have to significantly up your game. You're going to have to do your own research, not simply ask a bunch of people on the internet. And you're not even using the internet effectively. This experiment shows interference. If you Google "pion interference" you will get hundreds of hits. Some will be quite technical, but you are asking for a very valuable resource - the custodians of that resource will expect you to do your homework on this.
You should take a look at previous successful proposals. That's wwhat you need to do.
