Placement of an object and magnification
To produce a sharp image on the screen with a 0.05 m focal length lens placed 1 m away, the lens must be positioned 0.05 m from the screen. This results in an image distance of 0.95 m from the lens. The corresponding magnification calculated is -0.05, indicating a reduced inverted image. The sum of the object and image distances must equal 1 m, confirming the placement is correct. The calculations align with the lens maker equation and magnification formula.
Violagirl
An object is 1 m from a screen. At what points may a 0.05-m focal length lens be placed so as to produce a sharp image on the screen? What are the corresponding magnifications?
Lens maker equation:
1/s + 1/s' = 1/f
Magnification equation:
m = -s'/s = -f/s
For the first question:
1/s' = 1/f -1/s = 1/0.05 m-1 = -.95 m.
1 m - .95 m = 0.05 m away from the screen.
Magnification:
m = -0.05 m / 1 m = -0.05
Is this right?
Use the fact that the sum of the object and image distances is 100 cm.
  • · Replies 19 ·
10K
