Placing a highly viscous liquid drop on a solid surface
The discussion focuses on methods for placing a highly viscous liquid droplet, specifically one 2.5 million times more viscous than water, on a solid surface with a volume of less than 10µL and a radius of less than 1.34mm. Participants suggest using a pipette for precise application, similar to caulking techniques. Alternative methods include screen printing processes with a squeegee or utilizing solder paste dispensers, which are commonly used in surface-mount device (SMD) circuits for dispensing small droplets.
  • Understanding of high-viscosity fluid dynamics
  • Familiarity with pipetting techniques
  • Knowledge of screen printing processes
  • Experience with solder paste application in electronics
  • Research advanced pipetting techniques for high-viscosity liquids
  • Explore screen printing methods for precise droplet placement
  • Investigate solder paste dispensing technologies
  • Study the properties and applications of high-viscosity fluids in manufacturing
Researchers, engineers, and technicians involved in fluid dynamics, manufacturing processes, and electronics assembly who require precise application of highly viscous materials.
Fluido
Hi I'd like to ask how you would put a droplet at high viscosity (say 2.5 million times more viscous than water) on a solid surface? The droplet would have to be small (volume less than 10uL, r<1.34mm)..
Thanks!
Pipette.
According to this you are talking about something like caulking...
http://www.cstsales.com/viscosity.html
Quite hard to control the volume or mass I suspect. perhaps look at some sort of screen printing process? Squeegee the material through a perforated membrane?
Perhaps look at how they fix silicon chips/die? Think they use small balls of solder paste?
sounds like the soldering paste used in SMD circuits, dispensed in Little doplets.
What about a siringe (or a soldering paste dispenser)?
  • · Replies 20 ·
