Planck's Constant and the Work Function
The discussion centers on the application of the equation V = f(h/e) - W/e in calculating Planck's constant and the work function from experimental data. The user graphed their results in Excel, yielding an equation of y = 3e-15x - 1.2163, leading to confusion about the work function value and the correct symbols for frequency. Clarifications indicate that the gradient corresponds to h/e, and the frequency can be denoted by either f or the Greek letter nu (ν). The user calculated a percentage error of approximately 24.4%, which is deemed acceptable, and was advised on reporting significant figures. Overall, the conversation emphasizes the correct application of formulas and the importance of precision in experimental physics.
Procrastinate
I have recently graphed my Planck's Constant data from my Planck's Constant kit on Excel. The R squared value is great but there are a few things that confuse me.
1. I presume that the Equation of V = f(h/e) - W/e can be used with y = mx + c
If so, then I presume that my equation of y = 3e-15x - 1.2163 from excel can solve the equation:
c = -1.2163 = The work function (I find this a bit strange though because the cathode is covered in cesium which is meant to be 2.13 eV)
V = y = backing voltage
f(h/e) = gradient = m
Is this right? Or do are my presumptions wrong?
Also is the letter for frequency f or v? Because there seems to be some variation whenever I attempt to browse sites.
That's the work function for pure cesium. Your cathode could have some cesium oxide or other impurity that lowers the work function.
Note quite. This should be
f(h/e) = mx
The variable in f(h/e) would equate to x, and the constants would equate to the slope m.
Both are used, though it's actually the Greek letter nu, not v.
f is a more general or universal symbol, referring to the frequency of anything that oscillates sinusoidally. ν is used strictly for the frequency of electromagnetic waves -- but the more general f can be used for those as well.
I also calculated my percentage error to be 25.4%. Is this alright or should I consider re-doing it again?
How did you calculate that.
To calculate the experimental Planck’s constant:
V = f(h/e) – W
=3.132×〖10〗^(-15) x - 1.22
This correlates to the equation
y=mx+c
∴m=3.132×〖10〗^(-15) and ∴c=- 1.22
According to theory, the gradient = h/e
∴h/(1.6×〖10〗^(-19) )=3.132×〖10〗^(-15)
∴h=3.132×〖10〗^(-15)×1.600×〖10〗^(-19)
∴h=5.011×〖10〗^(-34) J
Experimental Uncertainty:
Percentage Error=(| Experimental Value-Accepted Value |)/(Accepted Value)×100%
=(| 5.011×〖10〗^(-34)-6.626×〖10〗^(-34) |)/(6.626×〖10〗^(-34) )×100%
=0.244×100%
=24.4%
Your math is correct.
I do wonder how many significant figures are appropriate for your 5.011e-34 value. Did you make the best-fit line by hand, or did you use a calculator or computer to get it?
I used the computer to get the R squared value and the equation. Microsoft Excel 2007.
Looks good then. By the way, errors are usually reported to no more than 2 significant figures.
  • · Replies 25 ·
