Why is Air Bubbled and Beaker Covered in Plant Root Experiment?
The discussion centers on a high school plant experiment involving nitrate ions, where two beakers are used to assess plant growth under controlled conditions. Air is bubbled into the solution to supply oxygen for root respiration, essential for plant health. The beakers are covered with black paper to simulate the natural soil environment, shielding the roots from light, which is consistent with their growth conditions in nature. The ambiguity of the questions posed has led to confusion among participants regarding the experiment's objectives.
  • Basic understanding of plant biology and respiration
  • Familiarity with experimental design in biology
  • Knowledge of the role of nitrate ions in plant growth
  • Concept of light and its effects on plant development
  • Research the role of oxygen in plant root respiration
  • Study the effects of nitrate ions on plant growth and development
  • Learn about experimental controls and variables in biological experiments
  • Explore the impact of light on plant growth and the significance of photoperiodism
High school biology students, educators designing plant experiments, and anyone interested in understanding plant physiology and experimental methodology.
Barclay
A high school experiment shows a plant immersed in a solution of nitrate ions. The beaker is closed but has an air vent passing into the solution.
Q. Why is air bubbled into the solution
Q. Why is the beaker covered with black paper
My answer Q2. The air will provide oxygen to the root cells for them to respire.
My answer Q2. To mimmic real plant conditions/ environment in soil. The roots are away from light in soil too.
Q2. Is my main problem. I'm just guessing the answer.
Please comment on my answers
Thank you
Unless the question refers to a known experiment that was discussed earlier IMHO it is worded in a way that makes it impossible to give any reasonable answer. It is just way too ambiguous.
Borek said:
Question ... it is worded in a way that makes it impossible to give any reasonable answer ... too ambiguous.
Okay I'll try again. The question says "A student uses apparatus (shown as diagram but I'll describe the set up below) to show if nitrate ions help plants to grow".
Diagram shows two beakers containing minerals in solution. Only one of the brakers contains the nitrate.
The roots of a 2 plants are inserted into the different solution and then the plants are inspected for growth weeks later.
The beakers are closed at the top but have an air vent passing into the solution through which air can be bubbled into the solution.
Q1. Why is air bubbled into the solution
Q2. Why is the beaker covered with black paper
A2. The air will provide oxygen to the root cells for them to respire.
A2. To mimmic real plant conditions/ environment in soil. The roots are away from light in soil too.
Can't think of a better answer.
Thanks. Q2 answer sounds too simplistic so was having doubts
15K
