Plastic Balls in a Test Tube with Mass
The discussion centers on the equilibrium of two charged plastic balls in a test tube, specifically analyzing the effect of reducing the mass of the upper ball by a factor of four. When the mass is decreased, the distance between the balls increases to maintain equilibrium due to the balance of gravitational and electrostatic forces. The final conclusion drawn from the analysis indicates that the new distance between the balls becomes 2d. Key equations referenced include the gravitational force formula F = G m1m2 / r^2 and the electrostatic force formula F = k q1 q2 / r^2.
  • Understanding of gravitational force (Newton's law of gravitation)
  • Knowledge of electrostatic force (Coulomb's law)
  • Familiarity with equilibrium concepts in physics
  • Basic algebra for manipulating equations
  • Study the relationship between mass and gravitational force in equilibrium systems
  • Learn about electrostatic forces and their role in charged particle interactions
  • Explore the concept of equilibrium in physics, focusing on forces in balance
  • Investigate the mathematical manipulation of ratios in physics equations
Students studying physics, particularly those focusing on electrostatics and gravitational forces, as well as educators seeking to clarify concepts of equilibrium in charged systems.
PeachBanana
One charged plastic ball is vertically above another in a test tube as shown. The balls are in equilibrium a distance "d" apart. If the mass of the upper ball is reduced by a factor of four, the distance between the balls in the test tube would become :
1) 4d
2) 8d
3) 2d
4) square root of 2d
How are charge and mass related? That's what I can't understand.
Charge decides the repulsive force and mass decides the gravitational attractive force. In equilibrium position they are equal amid opposite.
Ok. I'm thinking along the lines of
F initial = G m1m2 / r^2
F final = G 1/4m1m2/ r^2
But I need to put those in terms of "r" and compare, right?
By changing mass of tthe plastic ball, the weight mg changes. Now compare the two weights with the force of repulsion.
Ok. What I just did was
Gm1m2
1/4 Gm1m2
to get a 4:1 ratio. Yet I didn't use anything with "R."
When mass decreases, the weight decreases. To balance this the charges must move farther. What is the formula for the force of repulsion?
F = kq1q2/r^2 ?
Curret. Now if the initial distance for equilibrium is d for mg , what is new distance to balance mg/4?
I'm thinking:
d initial = mg
d final 1/4 mg
solving for d initial I get:
d initial = 4d final
But there's a square involved so shouldn't the answer be "2d?"
Yes.
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 24 ·
