How Do You Calculate the Initial Velocity of a Bullet in a Momentum Problem?
  • Thread starter Thread starter physics noob
To calculate the initial velocity of a bullet in a momentum problem, the scenario involves a 20 g bullet passing through a 0.5 kg block, with the block traveling 1 m before stopping due to friction. The friction force, calculated using the coefficient of friction, is 0.98 N, which does 0.98 J of work on the block, equating to an initial kinetic energy of 0.98 J. This leads to the block's velocity just after the bullet's impact being approximately 1.980 m/s. Applying the momentum conservation principle, the initial momentum of the bullet is determined to be 4.99 kg m/s, resulting in an initial bullet speed of 249 m/s. The analysis assumes negligible external friction during the bullet's interaction with the block.
physics noob
A 20 g bullet is fired horizontally into a .5 kg wooden block, resting on a horizontal surface ( kinetic friction coefficient is .2), THe bullet goes through the block and comes out the other side with a speed of 200m/s... if the block travels 1 m before coming to rest, what was the Vi of the bullet... (ignore work of gravity on the bullet...ps, this is a momentum problem i think, i just can't get it, i would GREATLY appreciate any help on this... i have the answer but i need to work to get credit... this is what i have so far
i tried using Wnet = change in KE
Fx - .2(.52)(1m)(9.8) = x - 1.02 J but i have no idea what to do next, i think it is a perfectly inelastic collision during the one meter, but than the bullet come out!?! how the heck do you account for that? again any help is appriaciated,,, thanks for y our time
i'm not sure about this... (not really sure about wat kinetic coefficient is) but what i tink u can do is since there is kinetic friction .2 .. let's take as if u'r block is movin so use KE = 1/2 m v^2 to find u'r 'velocity' of u'r block/.. After doing that, u can use M(1) U(1) + M(2) U(2) = M(1) V(1) + M(2) V(2) to find u'r initial speed.. i hope so.. note: u'r V(2)= 0... oso dunnoe y..
May not be rite.. though APOLOGIES! Juz try it.. hope u get u'r answer :biggrin:
Friction force = coefficient of friction * normal force.
thus friction force is 0.5*9.8*0.2=0.98 N
this acts through 1 m, so the work done by friction is
work done = F*s = 0.98 * 1 = 0.98 J.
this work done by friction is absorbing the kinetic energy of the block initially,
so the initial kinetic energy of the block is 0.98 J
thus 0.98 = 0.5*m*v^2.
so the velocity of the block just after impact is 1.980 m/s.
now, apply momentum equation,
momentum initial = momentum final
= 0.5*1.980 + 0.020 * 200 = 4.99 kg m/s.
initial momentum of the bullet is 4.99 kg m/s also, so
the speed of the bullet is 4.99/0.02 = 249 m/s.
the BIG assumption we adopt here is the external friction is negligible during the interaction process which happens very-very fast, otherwise momentum is not conserved.
maybe that helps.
Sniffer (poor physicist)
thank a bunch, that's exactly the answer that was given, thanks again...
  • · Replies 25 ·
9K
