Why Is My Calculation of Current in a 33 Ohm Resistor Incorrect?
  • Thread starter Thread starter CartoonKid
    Function Mind
The discussion centers on calculating the current through a 33 Ohm resistor in a circuit involving both series and parallel resistances. The user initially calculated the equivalent resistance as 13.06 Ohms and the total current as 1.91A, leading to a current of 0.154A through the 33 Ohm resistor. However, this calculation was incorrect due to a misapplication of the current division method. The correct approach involves recognizing the voltage drop across the resistors and applying Kirchhoff's Voltage Law (KVL) to determine the accurate current values.
  • Understanding of Ohm's Law
  • Familiarity with series and parallel resistor combinations
  • Knowledge of Kirchhoff's Voltage Law (KVL)
  • Proficiency in current division method
  • Review the principles of Ohm's Law and its applications
  • Study series and parallel resistor calculations in depth
  • Learn about Kirchhoff's Voltage Law (KVL) and its applications in circuit analysis
  • Practice current division method with various resistor configurations
Electrical engineering students, circuit designers, and anyone involved in analyzing or troubleshooting electrical circuits.
CartoonKid
Consider the circuit shown in Figure P28.9. (R = 33.0 .)
The question ask me to find the current flowing through the 33 ohm resistance and also the potential difference between point a and b.
I consider the 10, 5 and (33+5) to be parallel; 33 is in series with 5.
So the equivalent resistance found by me is 13.06 ohm, thus the total current is 1.91A. Then I apply the current division method and found that the current flowing through the 33 ohm was 0.154A. This answer was wrong!
Somebody please help me. I am quite depressing now. What's wrong with my answer?
13.06 is right as is the 1.91A
Your current through the R leg is wrong though. How exactly did you find that value?
First I sum up the 10 and 5 resistance which are parallel. Then i can treat the circuit as if I have 2 resistances in parallel which are 10||5 = 3.33 ohm and (33+5) = 38 ohm. Then, I apply the current division law to find the current flowing through into the 38 ohm.
Here's another approach(KVL which I'd use this for simple circuits):
You have 1.91A going through the series 10 ohm resistor thus that resistor is dropping 19.1V.
The parallel legs of the circuit will all have the same voltage drop(by KVL) which will be 25-19.1=5.9V
so, V_R=5.9V/38=0.154A
I'm sorry, I used a total resistance of 52 through the parallel elements(adding in ones head can lead to wrong answers).
Your answer appears to be right.
Any chance you miscopied the value R=(33 ohms)? Could it be R=(3.3 ohms)?
Also, what was the answer provided? It may give a clue to the problem here.
I have again submitted the answer. The potential difference appears appear to be correct. But the current is still wrong. What's wrong again? I only have one last attempt only. Please help.
I have double checked the value, it's really 33.0 ohms. It's an online assignment of mine, so there is no answer provided.
Well, 3 people here have all calculated exactly the same results!
  • · Replies 42 ·
