Point on a Curve: Solving Related Rates Problems
  • Thread starter Thread starter jgens
    Curve Point
4 replies · 4K views
jgens
A particle moves along a path described by y = 4 - x^2. At what point along the curve are x and y changing at the same rate
Simple equations regarding derivatives.
It's been a while before I've done any related rates problems, could someone please let me know if this is correct:
Since, x and y must be changing at the same rate (presumably with respect to time) x' = y' and y' = -2xx'. Therefore, -2x = 1 and x = -1/2. Placing my x value into the original equation yields 15/4. Hence, the point is (-1/2, 15/4).
Thanks.
Of course, it's right. What could go wrong?
Plenty, I could have made an incorrect assumption ultimately leading to false conclusions.
Good answer but you do not need to assume that x and y are varying wrt an external parameter. The derivative y'(x) = dy/dx of y wrt x expresses the instantaneous rate of change of y wrt a change in x.
The points where y and x are changing at the same rate are those where y'(x)=1.
