How Do You Solve the Polar Boundary Value Problem in Sturm-Liouville Form?
  • Context: Graduate
  • Thread starter Thread starter PvtBillPilgri
    Polar
The discussion focuses on solving the polar boundary value problem defined by Laplace's equation for u(r, theta) = 0 within the domain 1 < r < 2 and 0 < theta < a. The problem is approached using the method of separation of variables, leading to a Sturm-Liouville form with p(r) = r, q(r) = 0, and w(r) = 1/r. The user encounters difficulties in determining the form of R(r) due to the boundary condition R'(2) resulting in the equation 2^sqrt(lambda) = 2^-sqrt(lambda). The solution involves complex identities and leads to the eigenvalue lambda = -n^2Pi^2/ln2^2.
  • Understanding of Laplace's equation and boundary value problems
  • Familiarity with Sturm-Liouville theory and its conditions
  • Knowledge of separation of variables technique in differential equations
  • Basic concepts of complex numbers and exponential functions
  • Study the method of separation of variables in depth
  • Learn about Sturm-Liouville eigenvalue problems and their applications
  • Explore complex analysis, particularly Euler's formula and its implications
  • Investigate the use of eigenvalues in solving boundary value problems
Mathematicians, physicists, and engineering students dealing with boundary value problems, particularly those interested in differential equations and Sturm-Liouville theory.
PvtBillPilgri
I want to solve the boundary value problem:
Laplace's equation for u(r, theta) = 0, 1 < r < 2, 0 < theta < a
(i) ur(1,theta) = 0
(ii) ur(2,theta) = 0
(iii) u(r,0) = 0
(iv) u(r,a) = f(r)
I let u(r,theta) = R(r)M(theta) and plug this into the DE.
It's too tough to type out, but I get (r/R)d/dr(r*dR/dr) = lambda which implies that d/dr(r*dR/dr) = lambda*R/r, 1 < r < 2
This is in Sturm-Liouville form with p(r) = r, q(r) = 0, and w(r) = 1/r. I have homogeneous S-L conditions making the operator Hermitian. I solve the Euler-Cauchy equation and find that R(r) = Ar^sqrt(lambda) + Br^(-sqrt(lambda)) and with R'(1) = 0, B = -A.
I'm having trouble with R'(2) since this implies 2^sqrt(lambda) = 2^-sqrt(lambda) Can someone help me find the form for R(r) and what this implies about M(theta). I know how to use the S-L series at the end, but I'm having trouble getting there.
Hi PvtBillPilgri. Welcome to PF.
Not sure whether I can help here.
It look like you are using the method of separation of variables. Probably if you can show how you separate the variables then the problem will be much clearer.
Using separation of variables, One gets A=b (because the -in the swqrt(lambda) cancels and such) Using the second boundary condition as you said one ends up with 2^sqrt(lambda) = 2^-sqrt(lambda).
This let's you solve for lambda but you have to know the identity e^i(pi)+1=0 (complex number i) Also using some identities for complex numbers and the cyclic nature of sines and cosines, u can come up with the identity e^(2ni(pi)) =1, where n is an integer.
Now all you have to do is make your equation look like that.
Take the natural log of both sides and raise it to the power e:
e^(sqrt(lambda)ln(2))=e^-(sqrt(lambda)ln(2))
e^2(sqrt(lambda)ln2)=1...= e^(2ni(pi)) from before
The exponents must equal
2sqrt(lambda)ln2=2niPi cancel the 2 divide by ln2 and square it
lambda = -n^2Pi^2/ln2^2 remember that i^2= -1
Once you have the eigenvalues you can solve ending up having to use the S-L coeficients...I think havnt gone that far.
Its my first time posting here but I sort of remember this stuff.
  • · Replies 36 ·
