Polarization vectors for spin-2 particles
The discussion centers on the formula for polarization vectors of spin-2 particles, specifically the expression $$ e_i \otimes e_j + e_j \otimes e_i - \frac{2}{3}( \sum_{\substack{k}} e_k \otimes e_k )\delta_{ij} $$ which relates to the off-diagonal elements of a quadrupole tensor. Participants clarify that this formula is derived from group theory and tensor decomposition, illustrating how the tensor product of two spin-1 vectors results in irreducible representations of spins 2, 1, and 0. The conversation also emphasizes the significance of symmetric and antisymmetric tensors in this context and suggests resources for further study, including H. Georgi's "Lie Algebras and Particle Physics."
  • Understanding of tensor products and irreducible representations in quantum mechanics
  • Familiarity with group theory, particularly SU(2) and SO(d) algebras
  • Knowledge of angular momentum operators and their mathematical formulations
  • Basic concepts of spin and particle physics
  • Study H. Georgi's "Lie Algebras and Particle Physics" for insights on group theory applications in particle physics
  • Explore the decomposition of tensors into irreducible representations in quantum mechanics
  • Learn about the properties of symmetric and antisymmetric tensors in the context of angular momentum
  • Investigate the role of Casimir invariants in the representation theory of Lie algebras
Physicists, mathematicians, and students specializing in quantum mechanics, particle physics, and group theory who seek to deepen their understanding of spin-2 particles and tensor representations.
Breo
Who knows where this formula comes?
)\delta_{ij} $$
Where does it appear?
The structure reminds me of the off-diagonal elements of a quadrupol tensor.
this equation reminds to to group rotations or symmetries. Something of group theory.
)\delta_{ij} $$
Ok, If you couple two spin 1 vectors, you get the following spins
\vec{ 1 } + \vec{ 1 } = ( \vec{ 2 } , \vec{ 1 } , \vec{ 0 } ) . \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ (1)
In components, this means
[ 3 ] \otimes [ 3 ] = [ 5 ] \oplus [ 3 ] \oplus [ 1 ]. \ \ \ \ (1a)
What does this equation means? Well, the LHS is the (reducible) tensor product of two 3-vectors, e_{ i } \otimes e_{ j }. The RHS, which consists of irreducible tensors, is obtained by the decomposing the tensor product into (direct)sum of independent tensors. In general, you decompose a tensor into irreducible tensors by forming symmetric and antisymmetric combinations and subtracting all possible traces. So, your example is the simplest one:
<br /> e_{ i } \otimes e_{ j } = \frac{ 1 }{ 2 } G_{ i j } + \frac{ 1 }{ 2 } A_{ i j } + \frac{ 1 }{ 3 } \delta_{ i j } e_{ k } \otimes e_{ k } ,<br /> \ \ \ (1b)
where the tensor
G_{ i j } = e_{ i } \otimes e_{ j } + e_{ j } \otimes e_{ i } - \frac{ 2 }{ 3 } \delta_{ i j } e_{ k } \otimes e_{ k } ,
is symmetric, G_{ i j } = G_{ j i } and traceless \delta_{ i j } G_{ i j } = 0. Therefore, it has (3/2)(3 + 1) - 1= [5] components and can represent a massive spin \vec{ 2 } particle,
A_{ i j } = e_{ i } \otimes e_{ j } - e_{ j } \otimes e_{ i } ,
is anti-symmetric tensor. In 3-dimension, it has (3/2)(3 - 1 ) = [3] components. Therefore, it is equivalent to spin \vec{1} represented by the 3-vector v_{ i } \equiv \epsilon_{ i j k} A_{ j k }, and finally
e_{ k } \otimes e_{ k } = \mbox{ Tr } ( e_{ i } \otimes e_{ j } ) = \delta_{ m n} e_{ m } \otimes e_{ n } ,
is the invariant trace, i.e., [ 1 ] component scalar representing spin \vec{ 0 }.
So, equations eq(1), eq(1a) and eq(1b) all have the same meaning.
Likes dextercioby, Breo and arivero
Guys, you are being very helpful this week :) great!
Has symmetry or antisymmetry some deeper significance, beyond building the irreps? From the notation in the irrep sum it seems that this A_{ij} with two indexes is still the same thing, [3], that the initial vector e_i... is it? And we could also get a spin 1 vector from a product 1/2 x 1/2, and then it would be in the symmetric representation, but still be just a spin 1 vector as the others.
Infinite thanks! Do you know a good textbook which talks more about this?
No, that is deep enough. The point is this, symmetric and anti-symmetric tensors do not mix under the transformations in the question, i.e., they belong to different multiplets (invariant subspaces).
Yes, they are (as I said) equivalent, because of the invariant tensor \epsilon_{ i j k }
The above construction has no spin (1/2) object! For that, you need to consider the group SU(2).
Try textbooks on group theory and particle physics.
Try first H. Georgi's <Lie Algebras and Particle Physics>.
uh? "Learn mathematics from books written by mathematicians" :-D
Well, for this topic, it is true that physicist books are usual bussiness. I'd add Slansky's Report, which is scanned in the KEK database and surely also at SLAC, and some modern ones. Ramond? Cvitanovic?
For 2 and 3 dimensions, there is a connection between spin n and symmetric traceless n-tensors.
Let's consider rotation / angular momentum operators for vectors and tensors. ## (L_{ab})_{ij} = \delta_{ai} \delta_{bj} - \delta_{bi} \delta_{aj} ## with
L(total) = L(index 1) + L(index 2) + ... + L(index n)
The square ## L^2 = - \frac12 L_{ab} L_{ab} ## where the -1/2 is for identifying it with quantum-mechanical spin. Its general expression for a tensor is
$$ (L^2)_{(i)(j)} = n (d - 1) \delta_{(i)(j)} + \sum_{q != p} ( \delta_{p:i,q:j} \delta_{q:i,p:j} - \delta_{p:i,p:j} \delta_{q:i,q:j} ) \delta_{other (i)(j)} $$
for indices p and q and values i and j of them, and also d dimensions of of vector index.
It is evident that the largest L2 is for a symmetric traceless tensor, and in that case, we get L2 = n*(n+d-2). That's the right value for the square of the spin for both d = 2 and d = 3.
What does that garbage mean, exactly?
The Lab's are generators of the SO(d) algebra for d dimensions, appropriately extended to n-tensors. The L2 is the square Casimir invariant of that algebra, and it gives the total spin. This n-tensor representation of SO(d) is reducible, and one of its parts is for a symmetric traceless n-tensor.
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 23 ·
  • · Replies 35 ·
  • · Replies 18 ·
