Positive wing wash-in dynamic soaring one side
  • Thread starter ds3227
11 replies · 3K views · last reply
ds3227
Hello,
While dynamic soaring 3 of my rc ships seem faster in left tilted loops with left wing washin not just the tip.
No rolling tendency is noted why is this. This is slow speed just 70 mph.
I wonder what would happen with this setup on a large ds location.
Is a tilted loop the same as a vertical loop.
Why wont it roll right during pull up
Photo of a model glider with a straight, high-aspect-ratio wing flying against a grey-blue sky above a grassy slope and tree line.
When last I soared, it was in a Schweizer 2-22 - 3 or 4 decades ago.
Sail planes are generally aerodynamically left-right symmetric, so the major performance difference between doing dynamic soaring loops with left and right turns should be operator skill.
I have also done some aerobatic flying. In that community, a vertical loop is called an "inside loop" - or, if you're pushing instead of pulling, an "outside loop". RC's may be different, but with sailplanes, inside or outside loops would never be part of a dynamic soaring strategy.
I realize that with RCs, you can't wander too far without loosing control. But with regular soaring, on any clear summer day in Virginia, I was able to find ample thermals to keep me up. I always returned to the airport because my time slot on the rental had expired.
One more thing: You mentioned "wash in". I think what you are saying is that your RC models use wing wash-in control instead of ailerons.
After rereading this OP, I think you are describing a situation where the wash-in roll control is not working properly. Have you tested this on the ground?
Or perhaps the OP is referring to reverse washout.
I have trouble parsing that post though. Is the question about airspeed or vertical speed in the thermals? Or something else perhaps? I assume "left tilted" means "banking left".
Yes. Wing wash-out is used to keep the ailerons useful as the plane enters a stall.
From what I gather, he is using "washin" (ie, flexing the wings beyond the wing roots) in lieu of ailerons - just to make the mechanics of RC glider simpler.
Actually, after re-reading the OP - I notice that "No rolling tendency is noted why is this." isn't just a statement, it's a statement followed by a question.
I'll edit my response - I think his RC is not functioning correctly.
No. The overall context is "Dynamic Soaring" - so he is looking for opportunities to harvest energy from the environment.
The "left tilted loop" is pretty much what it sounds like. Rather than a horizontal circle, one side of the path is much higher than the other side. I have never done this kind of RC work, but if you have a wind coming from the North and a clearing with a tree line to your North, then you can use the the fast wind for power and the still wind as a kind of anchor to hold you in place.
Instead of keeping to a single altitude, the glider is directed to climb over the leeward side of that tree line (or ridge or whatever) where the wind will push it back hard. Then it coasts around and does it again.
That is also what I thought until you mentioned thermals and the text "thermal soaring" in the OP picture. But it sure makes more sense with dynamic soaring.
I have no experience with RC soaring, dynamic or otherwise, only thermal soaring in gliders (decades ago).
I was thinking that anything that kept you up was "dynamic soaring". But you're right Dynamic Soaring refers specifically to crisscrossing wind shear. So, it would be most useful when you have windspeed differences of ten+ MPH per hundred feet. Definitely the RC domain.
I also have my single engine private license, but sail plane were way more fun. Soaring is very opportunistic and there's no engine to worry about. Where I was flying, you could also get a bit of mountain wave on some days.
No I'm using ailerons...just wondering if this work at higher speeds without a rolling out..... I I talked to who set record they theorized it would roll n crash above 200mph....
ds3227 said:
Hello,
Could you please explain what do you mean by "left wing wash in"?
How is the right wing different from the left one?
If both differ, what is the purpose of that intentional lack of aerodynamical symmetry?
Thank you and welcome!
The right wing is warp free. Both wings are positive relative to the stab. Left wing is even more positive. Left turns n thetmaling are more effecient
ds3227 said:
The right wing is warp free. Both wings are positive relative to the stab. Left wing is even more positive. Left turns n thermaling are more efficient
To be clear, you have made left turns more efficient when thermaling by making the plane asymmetric.
When flying the Schweizer, I was equally able to enter a thermal in either direction. I was told by my instructor that should I ever do competitive soaring, I would have an advantage - since whoever enters the thermal first sets the direction. From what he described, most pilots have a preferred direction.
I have seen some discussion in other forums about the direction that thermals turn and whether you should enter one way in the Northern hemisphere and the other way in the Southern hemisphere. The answer is "No".
You probably haven't done this with RC's, but in sailplanes you can often spot thermals because they are topped with a puffy cumulus with a concave bottom. If there was any twisting in the rising air, that would show up in the shape of the base of that cloud. I can imagine a rising column of air being affected by local structures, but I have never detected any thermal-spinning while soaring.
In unstable air, the vertical motion of the rising air from a thermal is amplified. In the extreme case, it will contribute to a cumulonimbus cloud that can, in turn, generate tornadic winds that may touch down and form a tornado. Tornados are generally cyclonic, spinning counterclockwise in the Northern hemisphere. Of course, by that time your sailplane is safely stored.
Sailor has entered the chat.
Welp. There's no prop, so it's not prop walk.
'at's all I got. I'm out.
