Possibilities of Time-Independent Entangled Photons
  • Level: Graduate
  • Thread starter Thread starter DrChinese
140 replies · 14K views
Homework Helper
[Moderator's note: Thread spin off due to topic change. Original thread spin-off point is here.]
You can have entangled photons that do not coexist in time. I would call those biphotons as well, because there is not any particular difference between spatial separation versus temporal separation when it comes to entanglement. Any thoughts?
How do you define entanglement of two photons not coexisting in time?
The Schrödinger equation assumes that complete states are given at fixed times. Without this, the terminology becomes ambiguous.
As @A. Neumaier points out, however, the math doesn't really reflect this. The Schrödinger equation is an equation for the wave function of the total system as a function of time. So any mathematical analysis using the Schrödinger equation will not be able to model the two photons you refer to, which are entangled in the sense of showing the appropriate correlations between their measurements, as entangled in the sense of having the appropriate wave function at a particular time--which is the sense the term "entangled" usually has.
For example, in a previous thread I gave a mathematical analysis of the entanglement swapping scenario for the case where the two photons that are entangled at the end of the experiment never coexist (the first is measured before the second is created by preparation). That analysis had to look different for that case than for the case where the two photons do coexist. The final predictions for correlations were the same, but the way to get there was different.
Agreed, this situation has some difficulty
a. An entanglement swap creates a biphoton (entangled pair) that is "born" separated, usually in different places. But with some clever engineering, a swap can also give "birth" to a biphoton (1 & 4) whose components were created at different times. The trick is syncing laser pulses to create initial biphotons (1 & 2) and (3 & 4) that are in phase but separated in their time of creation (from the same PDC crystal). After the Bell State Measurement (BSM) of the component photons labeled 2 & 3*, we have biphoton (1 & 4).
b. The odd part is: the component photon 1 of the biphoton was already measured before the component photon 4 was created. Yet they demonstrate entanglement the same way any biphoton would after a swap is executed via BSM. In principle, the spatio-temporal separation between the components of an entangled pair of photons can be arbitrarily large in either time or space - or both.
Entanglement Between Photons that have Never Coexisted
So I define the entanglement of biphoton (1 & 4) the same mathematically as any biphoton, it's in one of 4 Bell states. Just prior to the time of the BSM on photons 2 & 3, the photon count is 3. And photon 4 is still entangled with photon 3, and not "yet" with photon 1 (which no longer exists). Not sure how the Schrödinger equation would need to modified to describe the full system evolution. :smile: @PeterDonis explains this better in post #53 above. *The 2 & 3 component photons must overlap at a beam splitter in an indistinguishable manner, so they are routed to make that occur. The 2 photon must be delayed precisely for that to happen.
This means that the biphoton starts to exist only when the Bell State Measurement is completet. Then it is an ordinary fixed-time biphoton.
But for the case @DrChinese described where one photon is measured before the other is created, the BSM takes place after the first photon is measured (and the measurement destroys the photon). So saying that the biphoton "exists" when the BSM is completed is, at the very least, glossing over a very important detail for this experiment.
But mathematically, this is not the case if we look at the state that appears in the Schrödinger equation; if we analyze the experiment using NRQM and the Schrödinger equation, this Bell state never exists. All we have is a prediction of final correlations between photons 1 & 4 that are the same as for that Bell state. But the actual state that appears in the Schrödinger Equation is never that state at any time during the experiment.
Not so sure that I entirely agree, because every alternative ordering of the events in the setup yields the same outcomes. I would say the mathematical descriptions must be equivalent in some reasonable manner. I agree with you in that the Bell state in this particular case does not exist at a single point in time. But I don’t see that as an absolute requirement for a Bell state to be said to exist for (1 & 4). The cited paper says:
"In this work we demonstrate how the time at which quantum measurements are taken and their order, has no effect on the outcome of a quantum mechanical experiment, by entangling two photons that exist at separate times. ... When the two photons of time τ (photons 2 and 3) are projected onto any Bell state, the first and last photons (1 and 4) collapse also into the same [Bell] state and entanglement is swapped."
"The density matrix of the first and last photons was constructed, conditioned on the outcome of the projection of the two photons of time τ. If the projected photons were measured in the |φ+>[τ,τ] state, the first and last photons were entangled in the |φ+>[0,2τ] state (see Fig. 3a). Alternatively, if the projected photons were measured in the |φ−>[τ,τ] state, the first and last photons were entangled in the |φ−>[0,2τ] state (see Fig. 3b)."
Agreeing with both you and @A. Neumaier, I think the "normal" descriptions - mathematical or textual - have difficulty here. It is akin, frankly, to trying to describe entanglement swapping when the swap (BSM) is performed AFTER both photons 1 & 4 were already detected - i.e. the delayed choice scenario (which has also been performed in experiments). In that case, the Bell State for photons (1 & 4) is analogously just as real as when the BSM is executed prior to their detection. The swap casts (2 & 3) into a Bell state, and it casts (1 & 4) into a Bell state... regardless of order. I don't see where there are any published theoretical or experimental treatments saying otherwise.
But again, you can pick a preferred way to describe these situations if you see some significant difference between them. But I don't see anything significantly different because the same rules apply regardless of order, and the result is always identical. In that respect, somewhat akin to an interpretation. :smile:
They are equivalent in that they all give the same probabilities and correlations for the measurement results. That certainly seems to me to qualify as reasonable. :wink:
This depends on one's opinion about how words like "exist" should be used, which is a matter of words, not math or physics. I think we agree on the math and physics (meaning the predictions). I personally would rather avoid words like "exist" altogether in cases like this, but of course many papers in the literature do not share that preference. :wink:
In nonrelativistic QM, an absolute requirement to call something a pure state is that there is an associate wave function. This is not the case in your situation.
The cited paper talks nonsense. What they mean is that the same statistics is obtained, it is not even attempted to construct a Bell state to justify their statement.
Indeed. I hadn't looked at the details.
A. Neumaier said:
1. In nonrelativistic QM, an absolute requirement to call something a pure state is that there is an associate wave function. This is not the case in your situation
2. The cited paper talks nonsense. What they mean is that the same statistics is obtained, it is not even attempted to construct a Bell state to justify their statement.
1. And yet, the Bell state statistics appear. So there must be an associated wave function.
2. Agreed that the same statistics are obtained. But they did indicate the associated Bell states, and I quoted those in the post. We have the same issues when we discuss the delayed choice version of entanglement swapping: Photons (1 & 4) are measured and their Bell state presumably exists prior to the measurement casting them into that Bell state - by a later choice to execute the swap on (2 & 3).
Experimental delayed-choice entanglement swapping
Zeilinger et al (2012)
"When Victor performs a Bell-state measurement and photons 2&3 are found in the state |Φ−〉23, then photons 1&4 were in the entangled state |Φ−〉14, i.e. the entanglement was swapped. When Victor performs a separable-state measurement, projecting photons 2&3 on the mixture of |𝐻𝐻〉23 or |𝑉𝑉〉23, correlations between measurement results on photon pairs 1&2 and 3&4 show that these pairs were entangled in the states |Ψ−〉12 and |Ψ−〉34, i.e. the entanglement was not swapped."
Again, we're recognizing the difficulty of trying to assign consistent descriptions to measurement timing and outcomes when order is not a factor in QM or QFT. While we want to place events into a chronological order and describe evolution accordingly, there is a subjective element to this process. In one case we have entangled photons that never co-existed. And in another, we have entanglement of photons that no longer exist at all - by a measurement performed later. (It has of course been well established that violations of Bell inequalities require the existence of entanglement.)
And in fact all 4 photons were entangled (as biphoton components) at all times they existed. At what time(s), and by which measurement(s), did biphoton (1 & 4) come into existence? I am not sure that can be precisely pinned down except by assumption or definition. My goal would be to consider these swapping examples when defining quantum measurement, else they run the risk of becoming counterexamples to an otherwise consistent definition or interpretation.
No. There are many examples in mathematics where the same statistis arises from very different situations. For example, the Born statistics of a qubit arises from unrelated classical models (Gleason's theorem does not hold for a qubit).
DrChinese said:
2. their Bell state presumably exists prior to the measurement
You and perhaps they presume it but based on no other evidence than the same statistics. To prove that a Bell state exists you must derive its wave function from a mathematical model of the experiment.
Never, since there does not even exist a precise definition of being entangled at different times. Thus the term can only have a figurative meaning.
Only the Bell statistics comes into existence, but the latter is a classical object!
This is simply wrong. I explicitly showed the math in a previous thread for the case where photon 1 is measured (and hence destroyed) before photon 4 is created. In that math there is never a wave function that includes both photons in any joint state, Bell state or otherwise. But the Bell state statistics appear.
But as far as I can tell, they do not do the kind of analysis I did in the previous thread, where they show explicit wave functions at different times. They just write down a single Bell state wave function and wave their hands and say that's how the statistics are obtained.
I disagree. There is no subjectivity at all to an analysis that uses the Schrödinger equation to compute the wave function at different times. It's all just deterministic math.
That’s my point. Those statistics cannot appear without 1 & 4 entanglement, period. Those photons are not represented by an entangled wave function at any single point in time when they both exist. Ergo there is an assumption to be questioned.
In every single published paper on the subject I’ve read, such as the 2 I quoted, they agree the final 1&4 photon pair is in an entangled Bell State. We already established that such entanglement correlations could not occur without the swapping operation, as photon 1 cannot be maximally entangled to both 2 and 4. So either those authors and I have made an unwarranted assumption, or you have, or we both have.
You are certain of your proof of course, but a matching reference would always be nice. Because I say a Bell State is a Bell State, as real as real can be.
I'm not going to keep arguing about this. I already showed the math in a previous thread. If you insist I can try to find it, but we discussed it at the time.
Yes, exactly. That's why "1 & 4 entanglement" has to be interpreted very carefully for this case, so as not to require such a wave function. I am not claiming that such a wave function exists or that "entanglement" in the sense of the appropriate correlations being observed requires one.
Then you should ask the authors how they account for this in the case under discussion, where there is no time at which both the 1 & 4 photons exist (and we can make sure that this is true in any frame by putting the photon 1 measurement in the past light cone of the photon 4 creation), so there is no time at which there is a photon 1 & 4 wave function at all, let alone one in the Bell state.
I am not going to try to speculate in any detail about how they would respond. However, generally speaking, I do not expect published papers, particularly advanced papers on complex topics where the paper is only treating one particular aspect and is relying on many other references (which is the case for the papers on this topic that have been referenced) to laboriously cover every detail or to maintain strict logical rigor and care in every statement. So my off the cuff guess would be that, if challenged, they would say that all they really meant was that photons 1 & 4 were measured to have the appropriate correlations for the Bell state, not that there was an actual Bell state wave function containing those photons at any time.
Then how do you account for the fact that, in the case under discussion, there is never any time where any such Bell state wave function exists? Wouldn't it be simpler just to adopt the solution I gave above, where "Bell state" refers to the measured correlations and does not imply any claim about a wave function at a particular time? And wouldn't you expect the authors of these papers, who certainly know more about the topic than you or I do, to do the same, rather than making a claim that is obviously false?
So you define entanglement in terms of the statistics, not as usual in terms of the decomposition of a wave function!?? This is very strange.
Or do you have a theorem that deduces your claim?
The one to be questioned is your unproved assumption that statistics implies entanglement.
Which argument do they offer? Just claiming something without proof is not a good argument. If the only argument is the resulting statistics, this proves nothing about entanglement unless there is a proof that only entanglement can create Bell statistics.
It seems to me to be the only way to interpret the use of terms like "entanglement" and "Bell state" in the papers @DrChinese has referenced. Otherwise we would have to conclude that the authors were making claims which they must have known were false.
PeterDonis said:
1. I'm not going to keep arguing about this. I already showed the math in a previous thread. If you insist I can try to find it, but we discussed it at the time.
2. Yes, exactly. That's why "1 & 4 entanglement" has to be interpreted very carefully for this case, so as not to require such a wave function. I am not claiming that such a wave function exists or that "entanglement" in the sense of the appropriate correlations being observed requires one.
3. Then you should ask the authors how they account for this in the case under discussion, where there is no time at which both the 1 & 4 photons exist (and we can make sure that this is true in any frame by putting the photon 1 measurement in the past light cone of the photon 4 creation), so there is no time at which there is a photon 1 & 4 wave function at all, let alone one in the Bell state.
4. I am not going to try to speculate in any detail about how they would respond. However, generally speaking, I do not expect published papers, particularly advanced papers on complex topics where the paper is only treating one particular aspect and is relying on many other references (which is the case for the papers on this topic that have been referenced) to laboriously cover every detail or to maintain strict logical rigor and care in every statement. So my off the cuff guess would be that, if challenged, they would say that all they really meant was that photons 1 & 4 were measured to have the appropriate correlations for the Bell state, not that there was an actual Bell state wave function containing those photons at any time.
5. Then how do you account for the fact that, in the case under discussion, there is never any time where any such Bell state wave function exists? Wouldn't it be simpler just to adopt the solution I gave above, where "Bell state" refers to the measured correlations and does not imply any claim about a wave function at a particular time? And wouldn't you expect the authors of these papers, who certainly know more about the topic than you or I do, to do the same, rather than making a claim that is obviously false?
1. I don't want to argue about this or anything. If you feel something is more than a friendly academic discussion, it's not worth pursuing further.
2. Agreed.
3. Agreed that there is no one "time" at which 1 & 4 are in a Bell State. There is also no one time you can say the entanglement between 1 and 2 ended, leaving 1 to be absorbed by a detector and have no further opportunity to influence or be influenced by the context of a measurement on 4 (which will be perfectly correlated to 1). Keep in mind that 4 need not co-exist nor ever exist in a common backward light cone with 1. As to what the authors of all these papers account for this, I think their statements on this are perfectly clear and unambiguous.
4. I'm a little surprised you don't give more weight to their wording, which I believe is chosen quite carefully (given the many papers that say much the same thing). But perhaps you are correct and they agree with you.
5. I would simply say that quantum mechanics does not require a biphoton to either exist within a locally evolved space, nor at a single point in time. The thing we call "quantum nonlocality" includes something called "nonlocality in time" as well. Some versions of this include what are called "Temporal Bell Inequalities" (TBI). The general theme in these papers is that there is no particular theoretical difference between spatially-separated entangled systems as compared to temporally separated entangled systems (or combinations of both).
Admittedly the literature on this is a smaller set than for spatial non-locality, primarily because the research on this is somewhat newer and the experimental setups are quite novel and complex. I did not need to seek out any references on this, because I already had a few saved... :smile:
TBI (2011): Violation of a temporal Bell inequality for single spins in solid by over 50 standard deviations
"Quantum non-locality has been experimentally investigated by testing different forms of Bell's inequality... Much less explored are temporal Bell inequalities, which are not subject to the locality assumption, but impose a constrain on the system's time-correlations. In this paper, we report on the experimental violation of a temporal Bell's inequality..."
Two-photon interference of temporally separated photons (2016)
"We present experimental demonstrations of two-photon interference involving temporally separated photons within two types of interferometers: a Mach-Zehnder interferometer and a polarization-based Michelson interferometer. The two-photon states are probabilistically prepared in a symmetrically superposed state within the two interferometer arms by introducing a large time delay between two input photons; this state is composed of two temporally separated photons, which are in two different or the same spatial modes. We then observe two-photon interference fringes involving both the Hong-Ou-Mandel interference effect and the interference of path-entangled two-photon states simultaneously in a single interferometric setup."
Probing the Non-Classicality of Temporal Correlations (2017)
Here we aim to provide a fair comparison of classical and quantum models of temporal correlations on a single particle, as well as timelike-separated correlations on multiple particles. ... This provides a clearer picture of the role of quantum correlations in timelike separated scenarios..."
Good. This is the primary point I have been making.
I'm a little surprised that, given your agreement on the point above, you don't draw the obvious conclusion that the authors must also know this, and therefore they would not intend to say anything that would contradict it. So any wording they choose would have to be interpreted to not imply the obviously false claim that there is a Bell state at any one time.
In terms of Bell inequality violations, this is obviously true, and the experiments we have been discussing are excellent illustrations of the point.
However, given the point we agree on above, this "quantum nonlocality" obviously cannot depend on a Bell state of photons 1 & 4 existing at any time. So either it doesn't require such a Bell state at all, or somebody needs to develop a different mathematical treatment of these experiments that doesn't use the Schrödinger equation and its time evolution, but instead makes use of the Bell states in a different way that shows how they come into play when the photons never coexist.
A. Neumaier said:
1. So you define entanglement in terms of the statistics, not as usual in terms of the decomposition of a wave function!?? This is very strange.
2. Which argument do they offer? Just claiming something without proof is not a good argument. If the only argument is the resulting statistics, this proves nothing about entanglement unless there is a proof that only entanglement can create Bell statistics.
1. It is generally agreed that violation of Bell/CHSH inequalities or similar is sufficient to demonstrate entanglement. In a N=2 photon state, that would be one of the 4 Bell main Bell states. It is also standard to provide such statistical evidence whenever a paper claims to have created entanglement. Normally, such papers do not start with any kind of Schrödinger equation, although I am sure there are exceptions.
2. There are all kinds of papers that demonstrate that classical (local realistic) systems cannot violate those inequalities, and that violation is itself evidence of entanglement. First of all, that is actually included somewhere in most experimental demonstrations of entanglement. Although I can't find a general purpose proof at the tips of my fingers, I would be glad to provide references of same.
PeterDonis said:
I'm a little surprised that, given your agreement on the point above, you don't draw the obvious conclusion that the authors must also know this, and therefore they would not intend to say anything that would contradict it. So any wording they choose would have to be interpreted to not imply the obviously false claim that there is a Bell state at any one time. ... So either it doesn't require such a Bell state at all, or somebody needs to develop a different mathematical treatment of these experiments that doesn't use the Schrödinger equation and its time evolution, but instead makes use of the Bell states in a different way that shows how they come into play when the photons never coexist.
The ψ+ Bell polarization state HV>ab + VH>ab (for example) for a system of 2 quantum particles (a & b) says it all. Entangled photons a and b (composing a biphoton, Fock N=2) can be anywhere, at anytime. I.e. the biphoton can have both spatial and temporal extent, and there is no particular restriction on one versus the other in standard QM. The pair can also be entangled into a non-separable state before or after they are created, no restriction there either. They don't need to be from a common source, co-exist in a common backward light cone, or in fact even need to be of the same particle type.
I don't think there is anything in the above paragraph that is not generally accepted at this time. That there are unusual time ordering structures in quantum entanglement was deduced - from theory alone - at least by 2000 (Peres). Not sure that can be explained by the Schrödinger equation any better than the earlier citation*.
But how do biphotons in time get to such a state? I think that's the question where we see things differently. You are asking for the Schrödinger equation that leads to this Bell state. I can't answer that properly, I guess because the standard form of the Schrödinger equation only contains a single time parameter (but can accommodate 3N space parameters). This places time on a different footing than space. But this issue has been recognized by a number of authors. Here are some recent papers that touch on exactly that point, not that any of this will necessary satisfy you regarding Bell States across time.
Temporal teleportation with pseudo-density operators: how dynamics emerges from temporal entanglement
Marletto, Vedral, Virzì, Avella, Piacentini, Gramegna, Degiovanni, Genovese (2021)
"Pseudo-density operators (PDOs) were introduced in [1] in order to express quantum spatial and temporal correlations on an equal footing. In usual quantum theory, quantum states, represented as density matrices, are given at a fixed time and then evolved in time through some completely positive (CP) map. This is at odds with relativity, where the line of simultaneity is observer dependent... The PDO formulation seeks to rectify this by representing statistics from events with a unique mathematical object, the pseudo density operator, irrespective of whether the events are space-like, time-like or light-like."*BTW: All 4 of the photons (for each trial) in this experiment are created in the same PDC crystal. That places them in a common light cone. But I could imagine a similar experiment in which photons 1 & 2 are created spacelike separated from 3 & 4, while also insuring 1 & 4 never co-existed. Of course, that would not change the expected outcome.
Is there an explicit mathematical analysis in any of the papers you have referenced that shows how this works for the case where the two photons never coexist?
See formula (2) in the original reference, which shows the explicit 4 photon state prior to the Bell State Measurement. They describe: "In order to generate consecutive photon pairs at well defined times, a pulsed laser is used to pump a single PDC polarization entangled photon source [4]. It is a probabilistic source, and thus there is a probability that two pairs will be created, each pair from one of two consecutive pulses, separated by the laser period time τ. The four-photon state is (2)"
Then, they present the resulting state as formula (3), which contains all 4 possible Bell states (one of which I used as an example in post #72). They describe: "In order to project the second photon of the first pair and the first photon of the second pair onto a Bell state, the former is delayed by τ in a delay line. The same delay is also applied to the second photon of the second pair and the resulting state can be reordered and written as (3)"
I guess I just don't get what's ambiguous or not sufficiently spelled out here. They said:
"In this work we demonstrate how the time at which quantum measurements are taken and their order, has no effect on the outcome of a quantum mechanical experiment, by entangling two photons that exist at separate times..."
They then show the theory, the math, the experiment and results. What's in question? I already said, maybe they agree with you. I guess it's just me reading something into their paper that they didn't intend when they presented their (3). I am not trying to be argumentative, but you have simply rejected every quote and reference I have supplied, and not provided a single quote or reference to the contrary (other than of course your own words).
I may as well bow out, if what I referenced in this post doesn't do the trick. This thread is about quantum measurements, and I believe I have posted the suitable quotes/references on the topic.
I'm not looking for a formula that has a Bell State in it; of course I already know that if you assume that that formula is the correct one, it predicts the correlations. All of the papers you have referenced appear to do the same thing: they assume that that Bell State is the correct one, with no supporting argument. In an experimental paper, that might be fine, if there is a theoretical argument already existing in the literature that explains why the assumption that that Bell State is the correct one is justified.
What I'm looking for is that theoretical argument: a theoretical analysis that explains, starting from first principles (i.e., either using the Schrödinger Equation, or using some other fundamental equation and explaining why you're using that one instead of the Schrödinger Equation, in a regime where, as you yourself have noted, relativistic effects are negligible and so NRQM should be sufficient), why that Bell State is relevant, even though the photons never coexist and so there is never a wave function at any time that includes that Bell State. That is what I have not found in any references that have so far been given.
No, they don't. They assume the theory. They assume that Bell States are the correct ones even though the photons never coexist and there is never a wave function at any time that includes them. They never justify that assumption with any theoretical argument.
The non-coexistence is accommodated for by the use of temporal modes (in this case, ##0##, ##\tau##, and ##2\tau##).
A skim of literature shows temporal modes are often used in photonics. They are presumably uncontroversial given the linear nature of the Schroedinger equation. This paper gives a general form (equation 1). In this paper temporal modes are even used to respresent a single-photon state as a photon-number Bell state.
I'm not sure what you mean by this. You appear to be saying that if I have two solutions of the Schrödinger equation, ##\psi(t)## and ##\phi(t + T)##, where ##T## is some constant time offset, I can superpose them to get another solution. But how would that work? What time is the resulting solution a function of?
In the papers you referenced I don't see any sign of a Schrödinger equation or any analysis that would answer that question. I'll take another look to see if I've missed something.
Not with the standard definition of entanglement. It is only sufficient to demonstrate the violation of local hidden variable assumptions.
yes, but your claim of the converse is mathematically meaningless.
But quantum systems are well-known to be able to violate it, and the experiments were done with quantum systems, not with classical systems!
So we have an entangled 4-photon state in the standard meaning, a tetraphoton, but not an entangled 2-photon state, no biphoton.
The paper just shows that certain tetraphotons measured at different times produce the same correlations as a biphoton in a Bell state, and tries to sell it as ''temporal entanglement''.
But they don't substantiate this claim, and indeed, the claim is meaningless.
But these temporal modes were not used in the experiments cited by Dr. Chinese.
As described in the papers you referenced, these modes are created by carefully chosen operations on a single source (such as a two-level atom in an excited state). But in the experiments we have been discussing, photons 1 & 4, the ones that never coexist, are created from different sources, independently. So the "temporal mode" treatment as described in the papers is not relevant for those experiments.
