Potato Launcher with Constant Velocity
apierron
As a participant in a robotic competition, you must launch a potato from a moving cart and strike a target. The potato must reach the apex of flight just as it travels over a screen, then it must pass through the center of an opening in a wall. The cart moves at a steady speed of 20cm/s (+x). The potato is launched from a height of 10 cm above the floor. The screen is 85 cm tall. The center of the opening in the wall is 20cm from the floor. The wall is 125cm to the right of the screen. The situation is diagrammed below (I attached a picture) How far from the screen should the potato be launched in order to make the shot?
So I used the information from the right side to find time from apex to the opening of the window and that help me find the velocity in the x direction and the angle but I don't know how any of this relates to the cart and now I'm stuck!
Since you have calculated an initial velocity and angle of launch for a potato launched from the center of the wall opening, you should be able to calculate how far away it would be from that launch point when it reaches the 10cm height on the other side of the screen.
apierron said:
So kind of like going backwards?
Yes, just like going backwards! Projectile trajectories are reversible in this sense; if you have the "landing" parameters including speed and angle, you can fire a shot back along the original trajectory using that speed and angle to launch a projectile from that landing point.
Ok thanks! I think I have it figured out. I was wondering what did the velocity of the cart have to do with anything?
Apparently, nothing at all. But I bet it distracted you :smile:
