Potential Difference with Series and Parallel Resistors
4 replies · 7K views
thebert010
In Figure 27-72, an ideal battery with an emf of = 14.0 V is connected to a network of resistances with R1 = 7.00 , R2 = 12.0 , R3 = 4.00 , R4 = 1.00 and R5 = 6.00 . What is the potential difference across R5?
FIGURE:
|----**R1**---|
| |---**R3**---|
|---**R2**----| |
|---**R4**-------**R5**----| |
|-----------+\emf\-----------|--|
V=iR
Parallel R = R12 = (1/R1 + 1/R2)^-1
Series R = R12 = R1 + R2
I just typed a realllllly long attempt at my solution and the page crashed and I lost everything, and I'm at work...so briefly:
R1 and R2 are parallel so R12 = (1/7 + 1/12)^-1 = 4.42ohm
R12 and R3 are in Series so R123 = 4.42ohm + 4ohm = 8.42 ohm
R4 and R5 are in Series so the same = R45 = 7ohm
R123 and R45 are parallel so R12345 = (1/8.42 + 1/7)^-1 = 3.822 ohm
after attempting various things involving V = iR (where R's in Series have same i and R's parallel have same V) I cannot seem to get the potential difference across R5...PLEASE HELPPPPPP
thanks so much
FIGURE:
|----**R1**---|
| |---**R3**---|
|---**R2**----| |
V=iR
thanks so much
awesome so the circuit isn't showing up...BUT...take my word for it that the R's I said were parallel/series actually are...I'm pretty confident that part is absolutely correct
Hi thebert010,
Just as a point of clarification for me, what is the relationship between R1 and R3 and R2 and R3? Or in other words, are R1 and R3 in parallel or series and what about R2 and R3?
Thanks,
KEØM
Hi!
so R1 and R2 are parallel...their equivalent is then in series with R3.
At the same time, R4 and R5 are in series.
===R1=|
|...|==R3==|
===R2=|....|
|===R4===R5==|...|
|===+\EMF\-=======|
sorry that's the best i can do :-(
I think I can help. First thing you need to realize is that for each leg of a parallel circuit, the emf (or difference of potential) across any leg is going to be the same (14V in this case). This means you can "isolate" resistors R4 and R5 and just look at that one leg. So you know that 14 volts are being dropped across this leg. Since you have only one variable you don't know, (i) that's where you want to start. Once you find the current through that leg, you can then find out what the voltage across each resistor is.
