Potential energy and turning points
The discussion revolves around a physics problem involving potential energy and turning points, specifically concerning a block sliding on a frictionless loop track. The original poster seeks to determine the minimum height from which the block can start to successfully complete the loop.
  • The original poster presents two different approaches to the problem, leading to different conclusions regarding the minimum height. Some participants question the assumptions made about the velocity at the top of the loop and suggest that further analysis of forces is necessary. Others discuss the implications of energy conservation in the context of the problem.
Participants are actively engaging with the problem, offering insights and questioning each other's reasoning. There is no explicit consensus on the correct approach or answer, but some guidance has been provided regarding the need to consider forces at the top of the loop.
There are indications of confusion regarding the application of energy conservation principles and the assumptions about initial conditions, such as starting from rest. The original poster expresses uncertainty about the correctness of their solutions, and some participants mention previous experiences with similar problems.
nightshade123
[SOLVED] potential energy and turning points
A block slides on the frictionless loop the lopp track shown in this img, what is the min height at which it can start from rest and still make it around the loop
I haev solved this problem TWO ways, and i can't decide which way is correct
the eqn...
U0+K0 = K+U
where U = potential energy and K = kinetic energy
first
m * g * h + (1/2) * m * v^2 >= m * g * 2 * R
final answer = h = 2R
the other way is
m * g * h >= (1/2) * m * v^2 + m * g * 2 * R
final answer is h = (5*R) / 2??
if i am way off let me kno, thx
What are you assuming v to be? 0?
I don't think the answer is just 2R. You have to do some analysis on the forces, since at the top, the normal force should be zero, and you find the velocity for which that is required. If velocity were zero at the top, it wouldn't make it around the loop, just fall off.
The 5/2 R answer looks correct.
you can solve the problem for velocity and plug the velocity function in and solve for h, and that is how you derive the formula, and for the 2R velocity cancels out so that wouldn't make sense, thanks
can someone else sovle the two equations i listed at the top of the page and tell me if they got the same thing, i keep solving the 2nd one and getting h=h-2R+2R which is saying the min height is the min height of the radius...
well you are starting from rest with U_i so it makes sense to me that what ever happens after would only be distributions of the energy between kintetic and potential so I would set the equation to what I am starting with
i just did this exact problem in my homework and got the correct answer but i don't kno how to help without breaking a forum rule and giving u the answer
dont worry about it i got it already, had to open a diffrent thread because the titel was wrong
  • · Replies 17 ·
