How can objects have negative potential energy at 0 height?
The discussion centers on the concept of potential energy, specifically addressing how objects can possess negative potential energy at a height of zero. Participants clarify that potential energy is relative and depends on the chosen reference point. By redefining the zero point, such as at the bottom of a hole or at infinity, one can illustrate that potential energy can be negative. The conversation emphasizes that the critical factor is the change in potential energy rather than its absolute value, with references to Newton's law of gravitation and the implications of using different reference points.
  • Understanding of gravitational potential energy, specifically the formula U = mgh.
  • Familiarity with Newton's law of gravitation, F = G(m1m2)/r^2.
  • Knowledge of the concept of reference points in physics.
  • Basic grasp of energy conservation principles in mechanics.
  • Explore the implications of Newton's shell theorem on gravitational potential energy.
  • Study the concept of reference frames in physics and their impact on energy calculations.
  • Learn about the relationship between kinetic energy and potential energy in bound systems.
  • Investigate the use of negative potential energy in astrophysical contexts, such as in gravitational fields of celestial bodies.
Students of physics, educators explaining energy concepts, and anyone interested in the principles of gravitational potential energy and its applications in various physical systems.
adjacent
As we all know,Potential energy =mgh.If someone digs a hole and place a ball at 0 height,the potential energy should be zero but it falls somehow.How is this possible?
The choice is arbitrary and though there is nothing wrong with what you did, if you find it distasteful, you can just redefine the zero point as the bottom of the hole.
I think the zero point should be the center of the earth.If I keep a ball on the ground,we can say it has no potential energy because of zero height.If I suddenly dig a hole,the ball suddenly gains potential energy?This is confusing
There's nothing wrong with negative potential energy, because the only thing that matters is the difference between the potential energy at different levels.
If I choose the zero point to be the bottom of the hole then the top of the hole will have positive potential energy ##mgh## and the energy released by dropping the weight into the hole will be ##E = E_{top}-E_{bot} = mgh - 0 = mgh##. If I choose the zero point to be the top of the hole then the bottom of the hole will have potential energy ##-mgh## and the energy released by dropping the weight into the hole will be ##E = E_{top}-E_{bot} = 0 - (-mgh)= mgh##. Either way, the energy released comes out to be ##mgh##.
In some problems it's actually convenient to set things up so that all the potentials are negative. If you're looking at objects moving in the Sun's gravitational field, we want to use Newton's law for the gravitational force ##F=\frac{Gm_1m_2}{r^2}## and that goes to infinity at ##r=0##. Thus, it's easiest to define the zero of potential energy to be an infinite distance away from the sun, and anything at any finite distance from the sun has a negative potential that gets ever more negative as you move closer to the sun.
So,the h should be the difference between the two level.It makes sense.Thanks
The point at which potential energy is zero is completely arbitrary and hence has no special meaning. All that matters how potential energy changes. Adding an arbitrary constant to some potential function has no impact on those changes in potential. You could make the potential at infinity be the zero point, and then anything at a finite distance will have a negative potential. In fact, making the zero be at an infinite distance is a very widely used choice for gravitational potential energy.
That won't work. There are two problems:
1) It's not even slightly convenient to use that as the zero point for many problems, such as for example, the movement of our sun around the galactic center.
2) The gravitational force changes with distance from the center of the earth, so ##mgh## only works when you're reasonably close (within a few hundred kilometers) to the Earth's surface so we don't need to worry about the changes in field strength. If you're going to extend the height change all the way to the center of the earth, you have to use the more general formula for the potential energy ##\frac{GmM_E}{r}## (##M_E## is the mass of the earth, ##r## is the distance from the center of the earth, and ##G## is Newton's gravitational constant - if you plug in the numbers you'll see that this gives you the ##mgh## that you expect at the surface of the earth). And that ##1/r## term means that you cannot use the center of the Earth as the zero point - the potential isn't even defined there.
Sure it is. You haven't taken Newton's shell theorem into account.
No, just assuming a point source for simplicity. There's no singularity at r=0 if you don't have a point source so can apply the shell theorem, but that doesn't make ##r=0## a natural place to set the zero point of potential energy in a central force problem... And I think that's the issue when OP (who seems to have figured all this out in the meantime) reaches for it as a natural zero point.
The way conservation of energy works for macroscopic objects is kinetic energy added to potential energy is always constant (conservation of energy, of course). So the potential energy of an object can be any arbitrary value and the kinetic energy will compensate depending on how you define the system.
The ball falls because its potential energy becomes more negative as it is converted to kinetic energy. That is, the total energy of the ball stays the same.
Negative potential energy is actually essential for bound systems. Any system on earth, for instance, will have a negative gravitational potential energy. A bound electron to a hydrogen nucleus has an energy of -13.6 eV. And so on.
  • · Replies 64 ·
  • · Replies 54 ·
  • · Replies 29 ·
  • · Replies 46 ·
