Potential -- Find the potential at node 3
  • Thread starter Thread starter Rectifier
    Potential
3 replies · 1K views · last reply
Rectifier
The problem
What is the potential at node 3, if the potential at node 1 is 0?
Circuit diagram of a rectangular loop with nodes 1, 2, 3 and 4 at the corners, containing four voltage sources: 5 V across the top between 1 and 2, 9 V on the left between 1 and 4, -3 V on the right between 2 and 3, and 17 V across the bottom between 4 and 3.
The attempt
If I start at node 1 and move towards node 3
1->2
-5V
2->3
+(-3V)
1->3
-5+(-3)=-8V
If I start at node 3 and move towards node 1
3->2
-(-3)
2->1
3->1
3+5=8V
I am not really sure what is right here.
Rectifier said:
The problem
Circuit schematic of a closed loop with four nodes labelled 1, 2, 3 and 4 at the corners. Voltage sources marked 5 V on the top branch, 9 V on the left branch, -3 V on the right branch and 17 V on the bottom branch, with + and - polarity signs shown.
The attempt
1->2
-5V
2->3
+(-3V)
1->3
-5+(-3)=-8V
3->2
-(-3)
2->1
3->1
3+5=8V
The problem looks overconstrained and inconsistent. Where is it from?
And when you go in the direction of - to +, that is an increase in potential. I get 2 different answers for going the 2 different ways from node 1 to node 3...
KVL in the loop, starting at 3..
3->2
-3v(rise)
2->1
-5v(fall)
1->4
-9v(fall)
4->3
17V(rise)
-3-5-9+17=0, so the voltage in the loop adds up.
Now from V3->V2->V1
V3-3-5=0
V3=8V
Now from V3->V4->V1
V3-17+9=0
V3=8V
Seems okay to me?
3->2
-3v(rise)
2->1
-5v(fall)
1->4
-9v(fall)
4->3
17V(rise)
Now from V3->V2->V1
V3-3-5=0
V3=8V
Now from V3->V4->V1
V3-17+9=0
V3=8V
Seems okay to me?
Ah, I see what fooled me. They labeled the right-hand voltage as negative, instead of relying on the +/- signs to determine the direction of the voltage. That's very non-standard in electronics, but I guess I should have seen that trick part of the question. Thanks for clearing that up! :smile:
