Potential of an infinite cylinder
The discussion focuses on calculating the electric potential and electric field of a cylindrical cable system featuring a center rod of diameter 'a', an inner radius 'b', and an outer radius 'c'. The charge distribution on the inner rod is defined as ρ = k cos(sπ/(2a)), while the outer rod maintains a uniform charge density to ensure overall neutrality. The participants debate the validity of using the potential equation V = (1/(4π ε₀)) ∫(ρ(r')/(r-r')) dV' given the infinite extent of the charge distribution, ultimately concluding that the potential does not approach zero at infinity in this scenario.
  • Understanding of electric potential and electric field concepts
  • Familiarity with cylindrical coordinates in electromagnetism
  • Knowledge of charge distributions and their implications on potential
  • Proficiency in integral calculus, particularly in evaluating complex integrals
  • Study the application of Gauss's Law for cylindrical symmetry
  • Learn about the implications of charge distributions on electric fields
  • Explore the concept of boundary conditions in electrostatics
  • Investigate the behavior of potentials and fields at infinity in various charge configurations
Students and professionals in physics, particularly those specializing in electromagnetism, electrical engineers, and anyone involved in theoretical physics or applied mathematics related to electric fields and potentials.
phrygian
A cylindrical cable with a center rod of diameter a surrounded by a gap and
a thick pipe with inner and outer radii b & c. The charge distribution on the inner rod
is Rho = k cos(s Pi /(2a)), and the outer rod has a uniform charge density such that the total
system is neutral.
V= - Integral(E.dL)
or
V= 1/(4Pi E0) Integral (Rho(r')/(r-r') dV')
When using the first equation which uses the electric field, I end up getting an integral with 1/s Cos(s Pi/2a) which I can't integrate. This makes me think that I am supposed to use the second equation which relates the potential to the charge distribution.
My problem is that in Griffiths the text says that this equation does not work when the charge extends to infinity, because the potential doesn't go to zero at infinity. That explanation was based off an infinite plane. Since here the charge extends to infinity but the potential does go to zero at infinity is the second equation valid?
system is neutral.
I don't see a question here. Are you asked to find the potential per unit length a distance s from the axis of the cable? Is a the radius of the center rod?
You shouldn't be getting an integral like that. Show your calculations.
What makes you think the potential goes to zero at infinity? (That's a no, by the way :wink: )
The rational of V and E going approaching zero as r approaches infinite is because the general form of the equations are 1/r and 1/r^2 but this is the distance from a charge so if your charge is "at infinite" then you aren't an infinite distance from the charge.
I'm assuming that the problem is looking for V and E everywhere anyway. You want to set the problem up utilizing cylindrical coordinates. V and E will be in the s-hat direction.
The boundary conditions are hinted at by the fact that the cable as a whole is electrically neutral so V = E = 0 s>c. Use this to solve V for a<s<b and b<s<c.
  • · Replies 19 ·
  • · Replies 16 ·
