How to Calculate the Series Resistor for a Potentiometer Measuring 2.5 mV?
The discussion focuses on calculating the series resistor value needed for a potentiometer to measure an emf of 2.5 mV from a copper-constantan thermocouple. The potentiometer has a slide wire resistance of 5.0 ohms and is powered by a 2.0V cell with negligible internal resistance. The relationship established is given by the equation \(\frac{2}{R+5}(R)=2.5 \times 10^{-3}\), which requires solving for the series resistance R. The circuit diagram is essential for visualizing the setup and understanding the current flow through the potentiometer.
  • Understanding of Ohm's Law and circuit analysis
  • Familiarity with potentiometers and their applications
  • Basic knowledge of thermocouples and their emf characteristics
  • Ability to manipulate algebraic equations for resistance calculations
  • Learn about the principles of potentiometry and its applications in measuring small voltages
  • Study the characteristics and applications of copper-constantan thermocouples
  • Explore circuit diagram creation and analysis for potentiometric measurements
  • Investigate the effects of series and parallel resistances in electrical circuits
Students in physics or electrical engineering, educators teaching circuit theory, and hobbyists interested in precise voltage measurements using potentiometers.
thereddevils
The slide wire of a simple potentiometer has a resistance of 5.0 ohm . The current source for the potentiometer is a cell of emf of 2.0V and of negligible internal resistance . Draw a labelled circuit diagram showing how the potentiometer might be used to measure an emf of up to about 2.5 mV from a copper-constantan thermocouple . Calculate a suitable value for the resistor which should be placed in series in the slide wire .
I have drawn a diagram (attached) . Let resistance of the resistor be R .
the pd across AJ = pd of thermocouple
\frac{2}{R+5}(R)=2.5\times 10^{-3}
solving that doesn't lead me to the answer .
maybe i made a mistake in calculating the resistance of AJ , do i have to add the resistance of the wire as well , or the resistance is simply R .
The potentiometer is used to yield a variable potential difference between one end of the slide wire and the sliding contact. The ends of the wire are connected into a circuit, so that current I flows through it. The variable potential difference is then
U=IRx
where Rx is the resistance between the terminal and the sliding contact. If the resistance of the slide wire is Rs and R is the constant resistance of a series resistor,
I=Emf(battery)/ (Rs+R).
Rx changes from zero to Rs.
The thermometer is connected in series with a very sensitive ammeter between the end of the slide wire and the sliding contact, and zero current is set by the slide. The unknown emf of the thermocouple is equal to
Emf(unknown)=IRx=Emf(battery) Rx/(Rs+R).
Try to draw the circuit. You need an output voltage that varies between 0 to 25 mV. The Emf of the battery is 2 V, Rs=5 ohm, what should be the series resistance R?
ehild
12K
  • · Replies 32 ·
9K
  • · Replies 60 ·
10K
9K
