Power drawn from capacitor in series w bulb & voltage supply
The discussion revolves around the problem of running a 75 W non-inductive light bulb designed for a 120 V rms supply using a 240 V rms supply by placing a capacitor in series with the bulb. Participants explore the implications of power, charge, and phase differences in an AC circuit, as well as the calculation of the required capacitance.
  • One participant suggests that the bulb needs the same charge to flow across it to maintain power, using the equation for power drawn by the capacitor.
  • Another participant points out the oversight of the phase difference between the voltage across the capacitor and the current through it.
  • There is a discussion about the validity of the original argument regarding charge, with some expressing uncertainty about its correctness.
  • Concerns are raised about the phrasing of "the capacitor draws power," with a participant arguing that ideal capacitors do not draw power.
  • A suggestion is made to draw a diagram to relate the voltages across the lamp, capacitor, and supply, taking into account the phase relationships to find the voltage across the capacitor.
  • One participant acknowledges that their earlier reasoning about charge was coincidental and not a valid approach.
Participants express differing views on the role of charge and power in the context of capacitors in AC circuits. There is no consensus on the validity of the initial argument regarding charge, and the discussion remains unresolved regarding the correct approach to the problem.
Participants highlight the importance of considering phase differences and the relationship between voltage and current in AC circuits, which may not have been fully addressed in the initial reasoning.
RightFresh
Hi again - partially stuck with a question and I'm not sure where to go. Hoping someone would be able to give me a hint :)
A 75 W non-inductive light bulb is designed to run from an ac supply of 120 V rms to 50 Hz. If the only supply available is 240 V rms show that the bulb can be run at the correct power by placing a capacitor C in series with it. Show that the capacitor draws 75 W from the supply and calculate it's capacitance.
So I've said that in order for the bulb to still run at the same power, it will need the same charge to flow across it (I'm not sure if this is the right argument though?) Therefore, the power the capacitor draws will be 0.5*Q*V, where V=240 V and Q=75/120 & this gives 75 W.
For the capacitance, I said that 75 W will be equal to V^2/2Z, where Z=1/(omega*C); the impedance of the capacitor. This gives me 8.3 micro Farads and the answer is 9.6 micro Farads. What have I done wrong?
The main thing you have ignored is the phase difference between the voltage across the capacitor and the current through the capacitor.
Oh I think I see. There's a pi/2 phase difference between them? Not sure how to account for it though?
Also - was my original argument about the charge being the same valid? I wasn't completely convinced that it was :s
To be honest, when I saw the bit about charge, I didn't think too much about it because I thought that was the wrong track.
I also wasn't happy about "the capacitor draws power" neither in your attempt, nor in the question. As far as I'm concerned, ideal capacitors don't draw power, and real ones don't draw much.
But back to the plot, you know the voltage across the lamp, the power dissipated by the lamp and hence the current through it.
For the capacitor you don't know the voltage across it (yet), but you do know the current. You would like to know V because then you could find Z, which as you said, will give you C.
Now can you draw a diagram relating the voltages across the lamp Vr, the capacitor Vc and the supply Vs, taking account of phase?
This will allow you to calculate Vc.
I see - I've got it now!
Think the "charge thing" I used was just a coincience that it worked
Thank you!
  • · Replies 16 ·
  • · Replies 19 ·
