Power from mass and acceleration
The discussion focuses on calculating the power required for a 3,219 lb car to achieve a maximum acceleration of 40.2 ft/s², resulting in a 0-60 mph time of 2.19 seconds. The formula used is based on the relationship between force, mass, and acceleration, leading to a calculated power output of approximately 643.5 rear wheel horsepower (rwhp). Key factors include the traction limits of the tires, which dictate maximum acceleration, and the conversion of units from pounds to slugs for accurate calculations. The discussion emphasizes the importance of understanding both initial and maximum acceleration phases in power calculations.
  • Understanding of Newton's Second Law (force = mass x acceleration)
  • Familiarity with unit conversions (pounds to slugs, feet to miles)
  • Knowledge of horsepower and its relation to power (1 horsepower = 550 ft lb/sec)
  • Basic principles of vehicle dynamics and traction limits
  • Research the physics of vehicle acceleration and traction limits
  • Learn about the implications of weight distribution on acceleration
  • Explore advanced power calculation methods for different driving conditions
  • Study the impact of tire specifications on performance metrics
Automotive engineers, performance car enthusiasts, physics students, and anyone interested in the dynamics of vehicle acceleration and power requirements.
LaCalia
Hello everyone, first post! I'm not terribly fluent in these matters, I'll say to start, but I have a problem.
If a 3,219lb car is capable of accelerating at 40.2ft/s^2, or 0-60mph in 2.19 seconds
How much power must it be capable of producing?
Thanks for your time and patience! :)
There's not enough information. What you have is the average acceleration. What's missing is the maximum acceleration possible due to traction limits of the tires.
Technically it takes zero power for the initial acceleration from zero speed. During the period of maximum acceleration, the associated power will increase linearly with speed, since power = force x speed, and force = mass x acceleration.
Not sure I know what to take away from your answer, but I do wish to clarify that 40.2ft/s^2 is the maximum acceleration do to the bounds of the tires.
I calculated the 0-60 time based on that.
OK, so maximum acceleration = average acceleration = 40.2 ft / sec^2, due to traction limits. Then the maximum power required is the power required to accelerate a 3,219lb car at 40.2 ft / sec^2 at 60 mph. Note 1 pound mass = 1/32.174 slug (unit of mass). 1 mile = 5280 feet. 1 hour = 3600 seconds. 1 horsepower = 550 ft lb / sec. Force = mass x acceleration.
power = force x speed = ((3219/32.174) x 40.2 ) x (60 x 5280 / 3600) (1/550) ~= 643.5 rwhp (rear wheel horsepower).
It traction allowed for a greater amount of initial acceleration, the required power would be less. The math would be more complicated.
Likes LaCalia
Having a little trouble following your maths, but otherwise, I am eternally grateful for your answer!
Thank you!
I updated my prior post to show what the constants I used in the formula are based on.
Ah! Well that helps a ton! A million more thanks!
I won't bother doing the math here, but for a similar problem where the traction is limited at the start (called stage 1 in the post linked below), then acceleration limited by power / speed (called stage 2 in the post linked to below). Given a velocity, total time, maximum acceleration, mass, ..., power could be determined using the formula for velocity (v = ... ) from the post linked to below:
https://www.physicsforums.com/threa...-power-requirement.864834/page-2#post-5443890
  • · Replies 41 ·
9K
11K
  • · Replies 29 ·
  • · Replies 28 ·
