Calculating Horse Power Output for a Sled on an Inclined Hill
  • Thread starter Thread starter mybrohshi5
    Power
The discussion focuses on calculating the power output of a horse pulling a sled up a 15-degree incline with a total mass of 130 kg and a retarding frictional force of 800 N. The horse's power output was determined to be approximately 2.1 horsepower when moving at a constant velocity of 5.0 km/h. The calculation involved using the equations for power (P=W/t and P=F*v) and the forces acting on the sled. Additionally, the participant attempted to calculate the horse's maximum instantaneous power output during acceleration from 5.0 km/h to 19 km/h, ultimately arriving at an incorrect value of 7.4 horsepower.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of power, work, and energy
  • Knowledge of trigonometric functions related to inclined planes
  • Ability to convert units (e.g., km/h to m/s)
  • Learn about calculating work done against friction on an incline
  • Study the relationship between potential energy and work in mechanical systems
  • Explore advanced power calculations in physics, including instantaneous power
  • Investigate the effects of acceleration on power output in dynamic systems
Students studying physics, particularly those focusing on mechanics and energy, as well as educators looking for practical examples of power calculations in inclined planes.
mybrohshi5
A sleigh and driver with a total mass of 130 kg are pulled up a hill with a 15 degree incline by a horse
If the overall retarding frictional force is 800 N and the sled moves up the hill with a constant velocity of 5.0 km/h,
what is the power output of the horse? (Express in horsepower, of course.)
P=W/t
P=F*(v)
I first converted the 5 km/h to m/s
5km/h = 1.389 m/s
Not sure what to do now. I know there is a retarding force of 800N and i know the velocity so i want to say i can find the force by the horse to travel at that velocity with that retarding force but I am not sure how. cause then i believe if that force is found i could multiply that by the velocity to get the power in watts then convert to horsepower.
thanks for any help :)
it is a "block on a ramp, with friction" ; sum the force components parallel to the ramp.
or , see how much PE changes each second,
and how much Work is done against friction each second .
I think i am supposed to solve it using PE and Work because that is what my professor just went over.
The thing is i feel like i don't have enough information to find the Power.
I know potential energy is = m(g)(h)
Im just not sure how to apply that to this problem.
and to find the Work done against friction if the distance is not known how do i find this?
Would i use
W = change in kinetic energy
W = 1/2mv_f^2 - 1/2mv_i^2
v_i = 0 so
W = 1/2mv_f^2
Thanks for the help :)
I understand it using the component forces parallel to the incline.
I used: Ff + Fgx - Fh = 0
800 + 130(9.8)sin(15) = Fh
Fh = 1129.7
P = 1129.7(1.389)
P = 1569.2 watts or 2.1 horsepower.
But I would also really like to know how to use PE and W to find it though :) any tips?
Could i get some help with this next part. I thought i did it right but its wrong :(
Suppose that in a spurt of energy, the horse accelerates the sled uniformly from 5.0 km/h to 19 km/h in 6.0 s. What is the horse’s maximum instantaneous power output? Assume the same force of friction.
I found the acceleration
a = 5.278 - 1.389 / 6
a = 0.648
then i found the force of the horse (Fh)
Ff + Fgx - Fh = ma
800 + 130(9.8)sin15 - 130(0.648) = Fh
Fh = 1045.495
then i found the power
P = Fh * V_avg
P = 1045.495 ( 5.278 - 1.389 / 2)
P = 2032.96 W
P = 2.1 hp
that was wrong so i thought maybe since it says the max power output i thought to use just the velocity max so...
P = 1045.495(5.278) = 5518 W
P = 7.4 hp
but that was wrong also :(
Any suggestions? Thank you
  • · Replies 20 ·
