Power produced by a rotation disk
9 replies · 4K views · last reply
kenshin6249
how do i calculate the power produced by a rotating disc?
for example given that the constant angular velocity is 30rad/s, diameter of disc is 0.5m, mass is 15kg.
or do u need more data to calculate the power? if yes, what data do u need?
The power generated is Fv, in rotational terms, it turns out as Tω where 'T' is the torque producing the rotation.
You can further get the 'T' by using T=Iα where 'I' is the moment of inertia of the disc about the center of rotation and 'α' is the angular acceleration.
What other parameters do you have to work with?
how do i calculate angular acceleration from the given data?
with constant angular velocity do it have angular acceleration?
nop it is just spinning at that speed from the start to the end.
I am not sure you can get the power just with the angular velocity and the moment of inertia. You can find the rotational energy produced using E=0.5Iω2 though.
yes that one i know.
is something similar to finding the power output of a turbine connected to a shaft onto a flywheel. the flywheel is spining in constant angular velocity by connecting it to a generator or a dynamo to producing a power output.
i need to find the power generated before entering the dynamo or without a dynamo.
Well the most you can get given your information is the kinetic energy (J) and not the power (W).
how about this case?
with the fluid pushing the shaft to turn there is an energy = 0.5mv2 = E1.
the power of the fluid = [tex]\rho[/tex]*g*h*Q = P1
with the rotating shaft energy = 0.5Iω2 = E2
with 2 different energy we can determine the efficiency.
efficiency = [tex]\frac{E2}{E1}[/tex] = [tex]\frac{P2}{P1}[/tex]
from here we determine the P2.
is it correct?
