Power required to generate waves
  • Thread starter Thread starter gleeson.tim
    Power Waves
The discussion focuses on calculating the power required to generate transverse waves on a string under a tension of 73 N, with a length of 2.1 m and mass of 5.9 g. The speed of the waves is determined to be 161.19 m/s. The power calculation involves using the energy formula E = 1/2 * μ * λ * ω² * A², where μ is the mass per unit length, λ is the wavelength, ω is the angular frequency, and A is the amplitude. The final calculated power is 14.72 kW, with a query regarding the determination of the angular frequency (ω).
  • Understanding of wave mechanics, specifically transverse waves
  • Familiarity with the concepts of tension, mass, and length in string dynamics
  • Knowledge of energy equations related to wave motion
  • Ability to calculate angular frequency (ω) from wave properties
  • Research how to calculate angular frequency (ω) in wave mechanics
  • Study the relationship between frequency, wavelength, and wave speed
  • Explore the derivation and application of the energy equation E = 1/2 * μ * λ * ω² * A²
  • Learn about the implications of tension and mass on wave speed in strings
Students and professionals in physics, particularly those studying wave mechanics, as well as engineers and researchers involved in wave energy calculations and string dynamics.
gleeson.tim
Determine the speed of transverse waves on
a string under a tension of 73 N if the string
has a length of 2.1 m and a mass of 5.9 g
Answer= 161.1925893 m/s
I have a problem with the second part of the question:
Calculate the power required to generate
these waves if they have a wavelength of 29 cm
and an amplitude of 7.3 cm. Answer in units
of kW.
2. Velocity= Square Root [Tension/(mass/length)]
Energy= 2 pi^2 mf^2 A^2
A-amplitude
m-mass
f- frequency
Power= Energy/time
3. I found the frequency by taking the velocity/wavelength and then found the energy using the above equation. I tried to find a value for time by taking the inverse of the frequency (period) and then plugging the values into P=E/t, but was not correct
P = ΔE / Δt
From your Energy equation.
E = 1/2*μ*λ*ω2A2
μ = .0059/2.1 = .00281
And your t can be found by λ/ν
making it
P = 1/2*μ*ν*ω2A2
What did you calculate?
Thanks, that worked. It ended up being 14.72 kW
Hey I have a problem similar to this one. What is the value for the lowercase omega (w)?
I looked everywhere but I don't know how to find it
  • · Replies 29 ·
  • · Replies 23 ·
