Finding the nth Power of a 2x2 Matrix | A^n = PD^nP^-1 Formula Not Required
  • Thread starter Thread starter tracedinair
    Matrix
To find the nth power of the matrix A = |1 1| |0 0| without using the A^n = PD^nP^-1 formula, one can calculate successive powers of the matrix and identify a pattern. The matrix remains the same when multiplied by itself, indicating that the nth power will be consistent for n ≥ 1. This approach is particularly suitable for this specific matrix and aligns with the expectations of a Calculus 4 course, where simpler solutions are often preferred. While more complex matrices may not exhibit clear patterns, this case allows for straightforward calculations. Ultimately, identifying a pattern through direct computation is an effective strategy for solving this problem.
tracedinair
Find the nth power of the matrix A,
|1 1|
|0 0|
My guess is the A^n = PD^nP^-1 formula. But my prof says not use to eigenvalues and eigenvectors. Is it possible to solve this without using the formula A^n = PD^nP^-1 ?
Is it specifically {1\, 1 \choose 0\, 0} or a more general problem?
Have you tried calculating any powers of that particular matrix?
{1\, 1 \choose 0\, 0}{1\, 1 \choose 0\, 0} = {1\, 1 \choose 0\, 0}
So...
Let's say more general.
Is it just calculating successive powers and finding some pattern to base a formula off of?
It depends what level a course the problem is being asked in, really. For something like this, the pattern is incredibly obvious. In general, there may not be a pattern though... But, if your teacher/professor is looking for a simple solution without much technical mathematics, which it sounds like, doing some sample calculations and finding a pattern is a solid plan (especially for this particular matrix).
This is Calculus 4. Pattern finding is probably the most obvious solution. Thanks for the help.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
14K
