Possible Values for K in Powers of Matrix
  • Thread starter Thread starter Incand
    Matrix
The discussion revolves around determining the possible values of k for which a non-zero square matrix A satisfies A^k = 0 while A^(k-1) ≠ 0. Participants explore concepts such as eigenvalue decomposition and the Cayley-Hamilton theorem, concluding that 0 must be the only eigenvalue of A. They emphasize the importance of understanding the image of the matrix powers, leading to a decreasing sequence of subspaces. The consensus is that k must equal n, the dimension of the matrix, as this is the only value that ensures A^k results in the zero matrix. Overall, the conversation highlights the relationship between linear transformations and the structure of matrix powers in linear algebra.
Incand
A square matrix ##n\times n##, A, that isn't the zero-matrix have powers ##A^{k-1}## that isn't the zero matrix. ##A^k## is the zero matrix. What are the possible values for ##k##?
N/A
I'm a bit lost here but I figure that maybe I could write the matrix as an eigenvalue decomposition.
##A = PDP^{-1}## and then I get ##A^k = PD^kP^{-1}##.
Since ##D^k## is diagonal we could say that it's weighting the columns of ##P##. So what happends when we get ##A^k = \mathbf 0## is that some rescaling of the columns in ##P## makes ##PP^{-1} = \mathbf{0}##.
That's the only thing I manage to reason out, as far as actually calculating ##k## I'm clueless where to even begin. Any hints on where to start?
Have you see the Cayley-Hamilton theorem?
Likes Incand
The matrix in your OP is not necessarily diagonalizable (and usually isn't except for special cases).
Likes Incand
I haven't but I checked it up on wikipedia now. Assuming I understand this right I would have a charasteristic equation
##p(\lambda ) = \Pi_{i=1}^n (\lambda_i-c_i)## where ##c_i## are some complex constants. The theorem would then give me
##\mathbf 0 = \Pi_{i=1}^n (A-c_i I)##
If ##A^k=\mathbf 0## then ##\mathbf 0 = c_k\Pi_{\notin k}^n (A-c_i I)##.
Edit: Adding to the above I realize that if ##A^k=\mathbf 0## then so is every matrix of higher power. And I could write the above as
##\mathbf 0 = \Pi_{i=k}^n c_i \cdot \Pi_{i=1}^{k-1} (A-c_i I)## and to get the zero-matrix one of ##c_k \to c_n## has to be zero or ##\Pi_{i=1}^{k-1} (A-c_i I)## ?
Not sure If I'm getting anywhere here, am I somewhat on the right track? The question is an old exam question for an introductory linear algebra course covering the basics so maybe there's a simpler way to look at it.
I guess the first thing to do is to find the eigenvalues of ##A##. Show that ##0## is the only eigenvalue.
Not sure I follow. If I have
##Av = \lambda v## and left multiply each side by ##A^{k-1}## I get
##\mathbf 0 = A^kv = A^{k-1}\lambda v##
We know that ##A^{k-1} \ne \mathbf 0## so either ##\lambda = 0## or I have ##A^{k-1}v = \mathbf 0##?
Btw. Eigenvalues isn't part of the course this is in, althought I don't mind using them to solve the problem (have had a course after covering them. I'm just going back to questions I never managed to solve when I took it).
OK, without eigenvalues then. Can you show that you have the following decreasing sequence of sets:
V\supseteq \text{Im}(A)\supseteq \text{Im}(A^2)\supseteq \text{Im}(A^3) \supseteq ...\supseteq \text{Im}(A^k) = \{0\}
Can you show that all these inclusions are strict? Given that ##V## has ##n## dimensions, what are the possibilities for ##k##?
When you write I am (image?) that's the same as the column space right?
Doesn't the statement follow from ##AA = \bigg| Aa_1 \; \; Aa_2 \; \; \dots \; \;Aa_n\bigg|## i.e. ##AA## is a linear combination of ##A## and therefore ##C(A^2) \subseteq C(A)## and the other statements follow the same way. And of course ##C(A)## is in the vectorspace it's embedded.
(sad to say our course didn't cover vector spaces either, it was just a 3 week introduction to vectors, matrices, linear transforms, determinants, subspaces, least squares etc. To me this old exam question is nightmarish compared to the exercises we had in our textbook)
When you say I should show if that they're strict you mean show ##Im(A^2) \subset Im(A) \dots ## (but not equal) right? I don't believe that's true. For example ##rank(A^2) ## could be equal to ##rank(A)## (or less). Isn't it similar for the column space itself that they could always be equal?
Let ##f## be the endomorphism represented by matrix ##A## in basis ##{\cal B} = (e_1,...,e_n) ##
What Micromass is telling you is that in order to reach your constraint, you have to remove at least one basis vector everytime you compound by ##f##.
Assume that there exist a first index ## 1 \le \ell \le n ## that does not remove at least one vector from the previous image subspace :
## f( \text{span}(e_{i_1},...,e_{i_\ell}) )= \text{span}(e_{i_1},...,e_{i_\ell}) ##
You can show by induction that you will never be able to remove any other vector, and therefore, you will never be able to find any ##k## such that ##( f \circ ... \circ f ) (V) = \text{span}(\emptyset) = \{0\} ## (##k## times)
Likes Incand
Thanks for responding geoffrey. I'm afraid both you and micromass is a lot more mathematicaly knowledgeable than me so while it may seem obvious to you it really isn't me.
So what you're saying (perhaps?) is that ##f## is a linear map and that somehow the only thing that matters is the the span. So if I take ##AA## the only thing that matters is the number of base vectors that that span the column room of A. And either they will get reduced or stay the same number. The actual coefficients in the matrix doesn't matter but only the column space?
The thing I don't understand is how do I know that ##f## only a function of the span (it's defined that way, but why is that true for any/my matrix ##A##). Is this because it's a linear map and since ##f(a_1e_1 + \dots a_ne_n) = a_1f(e_1) + \dots + a_nf(e_n)## with ##f(e_i) = cf(e_i)## and I only "lose" a base vector if i get ##c = 0##?
So ##k=n## is the only possibility to get the zero-matrix.
Thanks ! But Micromass is light-years more knowledgeable and capable than me.
Any ##n\times n## square matrix can be interpreted as a linear map from a vector space ##V## of dimension ##n## to itself.
Here, ##f## is a linear map from ##V\rightarrow V##, where ##V = \text{span}(e_1,...,e_n)##.
You know that the matrix of ##f^{(m)} = f\circ ... \circ f## (##m## times) is ## A^m##.
As Micromass said, you have a decreasing sequence of subspaces of ##V## : ## f^{(m)}(V) \subset f^{(m-1)}(V) \subset ... \subset f(V) \subset V ## (prove it).
The question asks you to find the smallest ##m## such that ##A^m = 0_n \iff f^{(m)}(V) = \{0\} ## (prove it).
Micromass told you that these inclusions had to be strict in order to prove your problem. But you did not agree. So in order to convince you, I told you to consider the hypothesis where the inclusion is large, i.e there exist a first ##m_0## for which ## f^{(m_0)}(V) = f^{(m_0-1)}(V) ##, i.e the first time you don't remove vectors from ##f^{(m_0-1)}(V) := \text{span}(e_{i_1}...e_{i_l})##
In that case, you can show by induction that ##f^{(k+m_0)}(V) = f^{(m_0-1)}(V) := \text{span}(e_{i_1}...e_{i_l}) \neq \{0\} , \ \forall k\ge 1 ##
Therefore, you will never achieve ##A^m = 0_n \iff f^{(m)}(V) = \{0\} ##
Maybe someone better than me could give you a better explanation
Likes Incand and micromass
Are you talking about some generic matrix A or a matrix A that satisfies ##A^k=0##? It's true that there are matrices for which rank(A) = rank(A2), but then it wouldn't satisfy ##A^k=0##.
Likes Incand
  • · Replies 18 ·
12K
